nv-t350
so slow 420
110
Feb 18, 2015
Detroit, Michigan
Nv-t350 manual transmission fwd where is the input shaft bearing located as well as output bearing is one on the bell housing but on the back side cause I see a roller bearing their
Both the front input shaft bearing and the front output shaft bearing are located behind the bell housing. You will have to remove the bell housing to see them. The bell housing case contains the larger front output shaft bearing (which is located in the center) and the smaller front input shaft bearing (off to the side). The input and output shafts are pressed in the rear bearings as well as having a snap ring, so the snap rings will have to be removed and the shafts must be pressed out.
