NT ECU and NT Engine with Turbo Harness
mulldawg
52
May 7, 2006
Mount Pleasant, Michigan
The links provided explain exactly how it can be made "plug-n-play". Find a second injector resistor pack, cut the wires going to the pack itself (the aluminum case where the resistors are) and solder them all together.
That way, all that is needed is to disconnect this "new" bypass and plug an unmolested injector resistor pack back in. That is all that RTM has done and if you don't think you can do it cheaper than $25, by all means, go that way.
