NT ECU runing turbo engine
tkelly27
1,712
27
Mar 11, 2007
Gresham, Oregon
I've searched and searched and I've never heard of anyone running a NT ecu in a turbo vehicle. While my turbo eprom unit is out being socketed I decided to try it. I found a 93 2.0 NT in a junkyard and snagged the ECU for $25. Using these two
ECU Wiring
ECU Wiring
the only wires that need to be swapped are 6 and 14. After doing that it ran ok, but was very rich. In a perfect world I would have used an AFC to tune that out, but I don't have the money for that and this is a very temporary fix (the car might see 5 miles of driving before I get the other ECU back). So I pulled the recirculation hose off to allow air in behind the MAS. All things considered, the car runs really good now. It is a little lean sometimes, and of course I have the venting issue, but I've been staying out of boost as much as possible.
With eprom and even nonturbo eprom ECUs running $100-$XXX In my eyes the next step would be to find one with an e prom and see if running the turbo code is possible. Anyone tried this?
You can run the stock NT ecu. Different fuel maps, etc. and NO knock circuit. You can run a link chip on it but you still do NOT have a knock circuit. Crazy Dave from Bat Cave, NC is the only guy I have known to run the NT ecu chipped.
