Not good... Crankwalk?
trapspeed
1,187
3
Jun 16, 2004
Sacramento, California
The other day my car decided not to start. All electrical components were fine but when I turned the key the car wouldn't turn over. A few seconds later my CEL came on and I plugged my pocketlogger in. The code is under stored errors : P0335 : Crankwalk Position Sensor A and then Circuit underneath it. WTF
Okay freaked out a little but did some searching and came up with : starter solenoid "trigger wire" isn't making a good connection at the solenoid.
So does that mean you were able to get the problem fixed, or what?
No but I found out it's not as serious as I thought it was. I'm going to take a look at it tomorrow.
Crankwalk is so overrated. Since most 7 bolts are almost 10 years old crankwalk is going to be a thing of the past in the next few years.
You are so correct! :thumb: :thumb:
