Not building boost
check your wastegate make sure it is able to shut if your not building any boost at all, it could be stuck open,
and by not building boost is this when you are driving?
do you have a boost gauge?
Agree with lasershark, check your waste gate out. Also make sure the pressure line is hooked up with no kinks or holes. Make sure the waste gate isn't stuck open. Was it building boost before and just randomly stopped?
Check the wastegate arm. Check to see if you blew off a coupler. If none of those work try a full boost leak test.
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
