Northwest 2010 1g build...
eeeewidner
342
Jun 20, 2008
portland, Oregon
For starters I purchased this car in Illiopolis Illinois in 2009. It has since then made it's way to Portland Oregon.... My goals for the car is to be a good 350 to 400 awhp d.d. but be show quality at the same time....
This engine spun rod bearings 2 and 3 2 hours after I performed all the maintenance on it (including the timing belt and water pump).:ohdamn: After tearing it down I found a lot of hardware in the crankcase from when the previous owner installed the engine. Since then The car has slowly but surely been going through a complete teardown and rebuild...
Here are before pics of the firewall....
Here's some of the progress on it after cleaning and the start of tucking everything.....
Here's some of the parts that have shaved and polished.
This is the 6bolt that's going in when the rest of the work is done...
View attachment 2146[
Thanks, this car has seen more miles on a trailer than I have driven it.....When its finished I hope the Portland DEQ is forgiving on where I'm stuffing all the emissions. Right now I have already relocated the charcoal canister under the pass/side fender.....The engine isn't assembled yet...I'm still in limbo on what stage of a port job on the head. Right now it is very mildly ported with a three angle cut.
So far the block has been decked honed and hot tanked. I am using the 2g piston 6 bolt rod setup. I have tri-metal acl rod and main bearings....The rotating assembly has been balanced by Capital Machine in Springfield IL...
