2010 into 2011 Northwest build.
I will do a write up on how to do main harness wiring tucks easy using a Cadillac bus connector on the passenger side. It took longer to label everything than soldering the cannon plug in. The plug can mount to the existing hole where the right front abs harness is in the fenderwell. If the harness needs to be removed it can be in about 15 minutes and plugs back in.
