turboglenn
- 6,375
- 123
- Nov 5, 2007
RIpley,
West Virginia
In prepping for dyno pulls on my friends car that should be making in the 700hp range, we had to pull the new 4 spider CD and replace it with a welded one since we couldn't find the VCE the owner has. Well in all this he remembered the fact that if we put cups in the front we could run it as a rear drive only car.
I know the rear drive setups break kinda easy but is it launching that breaks them or can they not handle say 400-500hp? We both were sorta excited to maybe do some reardrive rolling tire roasts as wellas some RWD "Driftin" (a.k.a. powerlisdes
can a 2g 97-99 t-case and rear end handle the power? I figured if the shock from launching was kept off then the tires would most likely spin before breaking anything but i cna't be sure and thought i'd ask for some feed back. I have done this before but it was on cars making no more than 350hpand boy was it a lot of fun.. WE plan to limit the boost while playing on the closed course parking lot.. BUT can the rear end handle the power to dyno the car that will be in excess of 600hp???
I've talked a lot about this car in the past and in case there's doubts of it's existance here's a few snaps from putting it together the other day..99 GXX wqith only 47thousand miles because it's always down to upgrade the next part he breaks
.. the easiest way to put it is to say the AC compressor, alternator and PS pump are still stock..the rest = not so much
it's hard to see because the body has been blocked out and needs cleared again but anything that couldn't be bought in carbon fiber was wrapped in carbon fiber cloth, resin'ed in and clear coated. it's truely a beautifull car in person, and the powertrain is now slouch either.. 9;1 aluminum rod engine, 280 cams with kiggly beehives, PTE6765 turbo, Link stand alone ECU, 250hp direct port N2o, TRE "high torque" trans with evo 1-4 gears (Stock 5th) OEM T-case, OEM rear end, 4" aluminum driveshaft (had a carbon one but it broke).. Last dyno was 682hp on my old PTE6776RS, looking to break 700 this go round
)can a 2g 97-99 t-case and rear end handle the power? I figured if the shock from launching was kept off then the tires would most likely spin before breaking anything but i cna't be sure and thought i'd ask for some feed back. I have done this before but it was on cars making no more than 350hpand boy was it a lot of fun.. WE plan to limit the boost while playing on the closed course parking lot.. BUT can the rear end handle the power to dyno the car that will be in excess of 600hp???
