Resolved Axle Spline Info Needed
spyderdrifter
5,434
864
Jul 11, 2009
Somewhere in, Colorado
I'm in need of some 2G GST axle specs. I need to know diameter of the splined end of the axle cups, and overall length of each axle. I don't have the proper tools to measure the diameter unfortunately.
This should help.
www.rockauto.com
Well if you don't have a tool to measure diameter then count the splines. Its fairly straight forward.
A 2g GST uses 27 spline axles and has brown axle seals as an identifier.
27-splined end (transmission side) measures about 1.097" in diameter at the splines. Should be noted that I did not ensure that I was measuring across the crown of the splines so actual OD may be a little larger than this. Sorry about that. :coy:
