Noob Question.
2G-beast
Apr 9, 2007
lake elmo, Minnesota
Alright well I have a 97 gsx with a 6bolt swap done to it. I was wondering when I buy things for my car would I buy it for a 2g or for the 6 bolt. For example clutches, flywheels, short shifter, spark plugs ect.
thanks for all the help
Sam
Well if you have the 6 bolt in your car you would buy parts for the 1g 6 bolt. If you buy for the 2g your buying for the 7 bolt so they wont match up.
Sam
Depends on what you're buying. You'd need a 6 bolt flywheel (the names '6 bolt' and '7 bolt' is actually the number of bolts that hold the flywheel on)
Clutches are the same between the two motors.
Short shifter - you'd still need to buy one for a 2g
Spark plugs - same between the two motors
Ok so for the clutch I can buy for either 2g or 1g, but for the flywheel I would need to buy for 1g correct?
Also when you buy a flywheel just buying one for 1g wont work. You will need to specify that you want one for the 90-92 6 bolt years. In mid 92 the 1g motor was switched to the 7 bolt crankshaft.
