Nonstop bucking no matter what
arabeclipse
119
Sep 23, 2011
detroit, Michigan
This morning on my way to school driving on the highway, 5th gear doing 70mph, i went to pass and i hit 10psi of boost. Right when I hit 10 pounds, my car started bucking like a mad horse. My stupid mistake of a narrowband said i was rich as hell, and that led me to think I needed to lean out the maft a bit.
Well I leaned WOT out 10% (two clicks on the translator) and it STILL bucked under boost. I tightened up all my couplers and did a BLT and there were no leaks. Then I thought maybe i had a bad GM MAF. I took it off and recirculated my BOV and used the OE maf.... STILL bucking. :mad:
And now it bucks even when I'm not in boost. I'll do a 2000rpm take off and it'll buck there all the way until 2500rpm. After that, I can do a good pull....with or without the GM maft. It pretty much bucks in any gear under or not under boost.
I ruled out just two things. Could be more. Either my knock sensor took a dump on me, or TPS? This car had a TPS issue in the past (last owner..he replaced it).
So bucking, with the addition really bad fuel economy, is really killing me right now. I have med school to pay for LOL.
Plugs/wires changed last March 2012. I only use 93 octane.
Update: went to autozone and apparently my CEL was on. I guess one owner removed the bulb. I have a code for P1400 which idr what it is, and I have a bad TPS and IAC (I knew it)..). And it was diagnosed by a dsm owner autozone employee that I have misfire apparently. He determined that by my exhaust sounding like a teleghraph.
I'm gonna change the plugs again to NGK's to see if it solves my apparent misfire. Then I'm gonna scavenge for a TPS at a junkyard and see if that helps the bucking.
So I changed my plugs to NGK's and i tuned my base knob 10% richer. the bucking stopped! :hellyeah:
And I did another BLT, and I found a leak at the TB shaft on both sides. I have a BBK TB (last owner) so I don't know how to stop the leak at the shaft. Guess that's another adventure to journey across.
Also I still have a misfire. Don't know why. And I know for sure the TPS is bad because I get mad jerking when getting on the throttle.
You can send the throttle body out to get rebuilt. There's a couple freelancers on the site that rebuild them.
and you should get rid of that narrowband a/f gauge. :rolleyes: Just saying.
I'll look into those. I'll prob go pick up a 2g TB at a junkyard. I prefer a more firm pedal and the BBK's are really light.
And I know man. I just have it to get by. I learned the hard way not to tune with it. :nono:
See, Mine does this and it's 100% factory from the maf back.
  • Wanted 6 bolt NT water pipe
    • chrisman287
