Killa_dsm
- 2,161
- 22
- Aug 31, 2004
Bay Area,
California
So here is my problem. I am trying to run Palm 'n' Stein on my IIIc to do a couple logs. But every time I try to connect I get a error code saying "no rev". Even when I go to look at my engine codes, the same error pop up. I have tried using different cables but still the same outcome. I even tried using my old palm 100m with no luck.
I have also tried using OBD Gauge but that doesnt connect as well.
The interfaces that plugs into the OBD outlet and hotsync cable looks fine. But is there anyway I can test that?
Does anyone have suggestions on how to fix this problem?
Thanks
Thanks
