Non turbo fireing order??
solisjulian
82
Jan 5, 2013
wooddale, Illinois
Hello thanks for viewing , quick question
I have 1991 non turbo eagle talon
I was wondering if the non turbo has a different fireing order? And If it does, what is it?
Thank you I appreciate it
My ignition coil is just straight its not a box ,
It says 4123 on the coil box , but I just wanted to make sure cause the previous owner had another fireing order
I did search first, but I was getting throwed off cause the different forums posted different fireing orders n some said the non turbo fireing order was diffrent so I got confused
And thanks for your guys help! My order was right then sorry just was confessed
The firing order, and the order of the wires on the coil pack are two different things. The first coil fires cylinders 1, and 4 at the same time, the second coil fires 2, and 3 at the same time. It's wasted spark.
The first coil fires when cylinder 1 is on the compression stroke, and cylinder 4 is on the exhaust stroke. Next the second coil fires when #3 is on the compression, and #2 is on exhaust. Then, the first coil fires again with #4 on compression, and #1 on exhaust. Finally, the second coil fires with #2 on compression, and #3 on exhaust. It takes 2 complete crankshaft revolutions for one complete firing cycle.
