Noises in the motor
tylor110986
Apr 6, 2005
christiansburg, Virginia
i have replaced my block in my car and now the car has no power and it makes a real lound sound after you drive it. the person i got the block from said the only thing that had happened is the motor had jumped time. if you can answer my questions please write me back and let me know what to do about this. and if u have a motor for a 93 eclipse 2.0 non turbo let me know :dsm:
Jumped timing?Some would say bent valves .But I think the balance shaft bearing is gone ,and the oil pump and housing are going.There should be some metal sludge in the oil pan from the balance shaft shaving the block away.You need a good used motor.There are some JDM motor companies that ship. Just search.
