Noise while turning wheel
DeNoZZo
685
Jul 6, 2008
Waterloo, Iowa
I'm hearing a creeking from the front of my car whenever I turn the wheels or go over a bump slowly. It started about 2 weeks ago, and has progressively gotten worse. I am thinking maybe a ball joint, but I don't know. Is there any way to tell if the bj recall has been done online? What else could this sound be?
Check for broken springs. I had a broken spring that made sounds when i hit bumps and turned the wheels. Might help!
NHTSA00V421002 12/15/2000 Recall 00V421002: Lower Lateral Arm Ball Joint Wear
827 07/01/1999 Recall - Lower Lateral Arm Ball Joint Boots
99V066003 04/05/1999 Recall 99V066003: Lower Ball Joint Separation
Call you dealer and give them your VIN they can track it by that. The recall numbers Ive highlighted in RED :hellyeah:
What else could this be??
You might check the strut mounts. They are on top and bolt to the body sometimes the rubber dry rots and they can make noise. I would lean towards ball joints.
Thanks a shit ton man, I hope none of them separate if that is the problem because I need to drive my car for a few days.
yea my one friend has a 95 eclipse an the front lower balljoint seperated an my other friend has a 97 talon and both of the ball joints are bad and they started squeeking really bad yesterday so tmrw were going to order new ones
yea mine are squeeking really bad... Hopefully i'm not making a post about my ball joint separating tomorrow.
