Noise at 2,000 rpm
Evilimports
125
Dec 4, 2008
Elkhart, Indiana
Alright, I know it's next to impossible to diagnose a noise over the internet, I'm just looking for some good logic based ideas of what the possibilities are.
There is a horrible ticking noise coming from the valve cover (already have revised lifters) when I let off the throttle around 2,000 rpm. It won't do it under heavy load and it will do it constantly around 45 mph on a flat road. Really hard to reproduce at idle but can get it to do it for a second. Noise waits a few hundred miles every time I have the cams off. I was convinced it was a weak auto tensioner but the noise cam right back that time (did not have the cams off).
Guessing its a bad rocker arm or a valve floating. Any ideas on what els it could be or how to verify?
You probably have a bad lifter, since it goes away when cams are removed, allowing the lifters to extend st that time.
Nice idea, would make sense. But the first time it started making the noise it still had the original lifters but the engine had been rebuilt. I replaced the lifters and the noise was gone for a while and then slowly cam back. If it was a lifter issue i would think it would be an oil supply to that lifter since its done it with 2 different ones
I should mention that it "ticks" hard enough to set off my knock sensor. After every shift right as I let off the gas it ticks/knocks really loud and my engine light flashes on.
