No vac at idle. None. Searched, fixed leaks, compression tested.
johnwohl
Jun 22, 2005
Fargo, North Dakota
Hey guys, I've been having a problem now for about 2 weeks. I have no vaccum at idle. None. My boost gauge reads a hair more than zero (like 1psi+ not vac), and if I take the line of the boost gauge and put my ear to it or a finger a feel no vac but i instead actually hear and feel a bit of positive pressure.
I searched the forums here and this is what i've done so far.
I've tested from just after the intercooler with a boost leak tester and fixed my leaks. They were the throttle body shaft seals and the lower fuel injector insulators. the leak tester now holds pretty steady at 15psi.
I did a compression test. 152-154 psi on all cylinders. so that seems good.
I've heard of cars having low vaccum but not no vaccum
I do get a tiny bit of vac when changing gears.
Ok, ok im an idiot. I did't realize that not all of the nipples on the top of the TB are vac sources. I switched it up and viola. At least I got those leaks taken care of tho.
