no spark swapped ecu
talontsi98
92
Feb 23, 2007
Roseburg, Oregon
All started when I tried to disable stock security system. I arced a relay that goes to the coil and now the car will turn over but has no spark. Checked coil and it has source voltage. Crankshaft sensor had .0024 for voltage. The power transistor is good also. Is there a way to test the ecu?
I took a plug wire and grounded the plug and turned it over and got no spark on all 4 cylinders. Its getting fuel. I also own a 97 gst. Will the ecu out of that work for a test. They have different part numbers?
I took the stock ecu from my 97 gst and tried it in the gsx and there was still no spark. Another question. The stock security system has been acting wierd lately. Is there any way the security system could be cutting the spark?
