No Spark issue!!
SupremeDsm
614
3
Aug 13, 2008
Indianapolis, Indiana
Ok guys so im kind of stumped on this one! Im not getting any spark coming out of my coil packs. I check the ecu and its fine. I also replaced the coil packs, camshaft angle sensor, crankshaft position sensor, battery, spark plugs, spark plug wires, and power transistor. Im not sure what to check now. Any ideas? And yes I did search!
Grounds are good. And I just opened it up to check and see if any of the caps are leaking. Im going to be putting a new one on it here shortly. Yes we double checked all of the grounds.
I used an led test light to watch the ignition coil control pulses at the ecu harness. For some reason my phone won't allow me to view this file, but i believe it shows the ecu pinout with the ignition coil a and b.
[ATTACH=full]469642[/ATTACH]
You really should test each component separately instead of just throwing other parts on the car. You now have too many variables changed to easily diagnose the problem.
turn the key on and check if your sensors have a 5v supply . if they don't then go back to the ecu and check all your powers and grounds.
Yes the plug is correct in the coil pack. I will go out and test the sensors and see if they are getting a 5v supply.
make sure your crank shaft trigger plate is clean and not all bent up. It can dig into the crank sensor and tear it up almost immediately. I had a timing tensioner lose tension and the belt slipped and bent the trigger plate. I couldnt get it to spark and it ended up being that trigger plate.
Im not getting any spark let alone it running! Lol. I changed each sensor individually and still got nothing. I didnt just go slapping new parts on.
:ohdamn: Sorry about that. I've been flipping back and forth between threads. The ecu will send a pulse to the transistor while its turning over. Have someone turn the key while you probe the harness. Once you know if the ecu is trying to trigger your ignition you can continue to follow the troubleshooting path.
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
