92_talonGsXt
- 117
- 1
- Jan 1, 2009
lake forest,
California
I'm having a hard time starting my car,I checked for spark and my cylinder 3 and 2 didn't have any spark,what can it be????
Start with your coil. 2 & 3 are companion cyls, so they are batch fired. That means if that coil goes bad neither of them will fire.
Have you swapped Power Transistors? That would prob be the next most likely cause. Also check for broken wires to the coil pack, if the trigger wire for the Cyl 2/3 coil is broken than obviously it won't fire.
