Cooljock
- 49
- 1
- Sep 17, 2002
Phoenix,
Arizona
HI there I helped a friend buy a 93 awd talon with jdm motor swap, it wasnt running cause the bellhousing was cracked and was rubbing on the flywheel. So we pulled the tranny and replaced the clutch while we were in there. I bought A 90 tranny that was shot and swapped the bellhousings. Then I put it back togeather. I didnt put the little metal gasget you could say that goes between the block and the bellhousing so I had to get some spacers on the starter motor so it wouldn't grind aginst the flywheel. So I have the car cranking good now but I have no spark!!! So now I am checking out the igntion pack and Coil. I hooked up my palm with mmcd on it and it tells the tps and cas error codes I am getting those two erros now but heres a catch, the biggest plug of three that plug into the ecu was cutoff just cut off seriously. So i went to a junk yard and cut off the group of 23 wires then there was like 3 wires within that loom, it came off a 91 gst laser. When I went to hook up the wires to mine that were cut off I have all 23 wires and then i went to do the 3 inside of that loom and there were like 5 more wires that had no place to go on the set I just cut off. and when I looked at the diagram on http://www.vfaq.com/mods/ecu-harness-1G.html I saw that this has both of the cel error im getting with in the wirring on its plug. Im im getting a cas error would that be why im not getting a spark? or did I wire it up wrong but all the wire were match up right all the colors match up perfectly I just have 5 wires that have no home did they change something on the wiring harnes? if every thing works like is suppoest to and cas is bad or whatever can I get a spark or sence it bad or getting the error it wouldn't know when to right? Sorry for poor gramer and spelling and composure of sentances.
