no radio, wipers, cigarette lighter, or power mirrors
Birt96gst
117
4
Aug 28, 2005
black diamond, Washington
Installed a turbo timer and everything worked then I install 3 gauges now all the listed dont work.
I hooked up the APEX-I turbo timer to the ignition switch like the instructions said, then I hooked the power up on the gauges and went to check them. The gauges powered up and then the radio and everthing else stopped working. I hooked up the gauges to the acc on the ignition switch. HELP it rains alot up here and I need those to work.
Thank you all for any of your help.
p.s. I have checked all of the fuses and they are fine
hook the gauges up to the existing dash power and the problem should be fixed. I believe there is a how to on vfaqs about this.
Do yourself a favor and run a power source directly form your battery to power you gauge set. By taping another circuit for power you are decreasing resistance, and increasing the amperage of that circuit. I'll bet you pulled too much juice from the circuit you tapped and popped a fuse. Check your fuses again and don't forget the ones under the hood. Make sure you are using solder connections and weather proofing each wire even if it is inside the car. Corrosion is like plague.
Good luck...
    • george bromwell
    • pma1123
    • Sdcryan1
