no oil on dipstick
spyderdrifter
5,434
864
Jul 11, 2009
Somewhere in, Colorado
Before anyone gets the idea that I don't know how to add oil when there's none on the stick, don't think it. Was driving home yesterday because I left work for being sick, and the spyder shut down on the highway. It cranked, but wouldn't start up again. Turned out to be a wire connector. However, I checked my oil and there was none on the dipstick. Even though I know the oil pressure gauge isn't accurate, it did read good pressure. There are no oil leaks on my engine at all, and I know for damn surely I put oil in it before dropping the engine back in the car. Anyone have ideas to this issue? I did a search but couldn't end useful info. Thanks.
Soooo.... Top it off and continue to monitor it for a while to see if it continues to use oil. If there is nothing on the stick, you'll be safe starting with a quart and hopefully that is enough to get it up where it needs to be. Good luck.:)
When you park it consider putting newspaper or card board down to visually spot leaks easier.
You're can also get some one to drive behind you and monitor your exhaust under different conditions to see if it is smoking.
Yeah. One of my friends, who's a member on here, mentioned the cardboard idea. Just haven't done it yet. I thought about having someone follow me, but got moons that would be able to keep ip when I get on the throttle.
They don't need to keep up nor should you need to be speeding to check for burning oil.
if it was a fresh build then it probably burned it if it didn't leak it. During the time it took for the rings to seat properly though thats at least 1 1/2 2 quarts. you think if it burned you would know.
What break-in method did you use? I went with something like Motoman and burnt/used a good half quart in the first 30 min. But otherwise I only need a small top-off between changes thanks to the piston/ring specs. So like others are saying, just make sure its not leaking or burning excessively.
I've driven it pretty much like described on Motoman's web page. I don't think I'm capable of prolonged easy driving. Too many retarded drivers out there to be stuck behind.
LOL I don't think people know what "defensive driving" is till they live in Colorado Springs.
May check the oil filter, this happend on an old car of mine. I changed the oil and the seal on the filter was bad and it leaked it all out.
hay you should checked your turbo was it also replace when you rebuild you engine you just might be pushing oil out of the turbo
on a new build oil has to fill everything like the filter and the oil cooler. normal for it to be low and need to be topped off. since you did an oil change just keep an eye on it.
also spend the 50 bucks and get a real oil pressure gauge
The oil pressure gauge will come in time. I have other little replacement parts I need to get first. I'm in no way blowing off the thought of getting that gauge, along with other 'more accurate than stock' gauges, but other parts have to come first unfortunately.
    • klipschaudio
    2g pass front rocker corner
    • dsmmario
  • Wanted 1g Fuel Pump Hanger Assembly, MPI Relay
    Current one is rounded off, kinked and crusty. Looking for a good condition 1G AWD hanger and a...
    • Gabe92RTTT
