no heat or any air blowing at all ### help
jdunbar10
133
Jan 30, 2007
edmonton, AB, Canada
ok so here is my problem i have no heat, no cold air no nothing, all my lights turn on dials move and turn, fresh new rebuild motor so its got a new thermostat and proper coolant any ideas here?
no heat
no cold
no air flow
new thermostat
new coolant
dash lights as well as heater lights work
I would start with the fuse :p
I think it has it's own separate fuse, so it's not tied in with the lights. If I remember correctly it's a fairly high amperage fuse... 20 or 30A
i say blower motor too, check the relay...
He already fixed the problem, as stated in the previous post.
My guess is that some little rodent, (probably a squirrel, they're mean little bastards) saw the car and decided he didn't want you to have air or heat since he couldn't have any.... So he then went on a suicide mission into the blower motor, unbeknownst to the squirrel however, you were on DSMtuners and had helpful info and a good rundown of the problem within minutes.
Will these squirrels ever learn? :tease:
blahahahaha
i be this guy is bang on the money!
damn squirrels!:ohdamn:
Hey, where is the relay? My front wheel drive has an intermetant blower issue. I checked the fuse and blower and both work fine and I chalked it up to wiring demons like the rest of that cars problems.
