420A No crank no start help
CrimDjinn
Sep 4, 2026
Visalia, California
I have a 2g Eclipse GS I bought on FB marketplace (first mistake). He said it ran recently but the transmission "got stuck in 3rd while driving" and he never got around to replacing the transmission and the airbags went off when he was messing with electrical but that he was getting rid of it cause the wife was making him.
I take the car home and take the front bumper off to find out it had front frame damage and so I've spent the last month and a half trying to at least get it to start so I can begin proper repair of everything.
I replaced the battery and the radio/dash seem to run well. I took off the center console to check the relay and it also seems to be good. Fuses are fine but I wasn't able to get the alternator fuse (120A), turned the engine clockwise and it moves easily so that's not cooked at least, replaced the starter with one from a parts car, the only other thing I can think of i haven't done is the neutral safety switch but that's cause I can't figure out how to unplug it.
Any and all advice is welcome
Verify that there is 12v at the starter solenoid when you turn the key to crank/start position. Would help narrow the problem down
Hi sorry for the super late reply i've been super busy with work. I finally had time to look at the car again and asked a mechanic friend of mine to help me out. it took him an entire 5 minutes to say the starter was going bad but i was in denial because i had it tested when i took it from the parts car but took it off anyways to check it and it was filthy. i went to autozone and bought electronics cleaner, sprayed it down and brushed the inside, and voila!! the car kicked right on!!! new problem now though. She's leaking oil pretty bad so i'll have to look into that. I really appreciate the help especially since it did make me take a second look at the starter and its components.
I would like to mention i also did end up cutting the clutch safety switch wires. I wanted to unplug it like i should but i genuinely could not figure out the lock and my hands are too large to fit so i snipped em since i read in a bunch of places it helps keep transmissions alive longer and i plan to keep this car permanently so my shenanigans won't effect anyone else
