no accessory power unless running
Mike Marnik
349
6
Mar 5, 2004
Omaha, Nebraska
Ok this just randomly started happening yesterday.... When I turn the key to the on or accessory position I get no power to the accessories like radio etc etc. Also when the key is out and I open the door the seatbelt is supposed to move to the front or w/e but it doesnt, but if i start the car i get power to everything, but the radio will cut out sometimes and come right back on........... no blown fuses, and I havent touched anything electrical on the car in a long time other than uninstalling a wideband o2.
Sounds like your battery is almost done for, take a multimeter, set it on voltage and it should test over 12 volts. When you run your car the the alternator is helping power everything else.
Atleast this is what happened to me when my battery died, it wasn't but a day or two longer and that was all it had left in it.
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
  • For sale 1g 1990 Turbo Throttle Body ( rebuilt )
    1990 Turbo Throttle Body $85 shipping & paypal fees* this throttle has been rebuilt and is in...
