Nitrous!?!
kronix0420
43
Sep 29, 2005
post falls, Idaho
ok whenever i get to the point of wanting that little extra push, i am considering a 50 shot of N2O, but unsure of the right brand, and what kid of setup shoud i run, i have heard that ZEX is the most car friendly, and i can set it to run only in 5th gear and an wide open throttle, is this ture, and if so, is it a good idea, or what othe way should it be
dry? wet? or how should i run?
thanx
Since you have a turbo, get a wet system. A wet system comes with nitrous and fuel solenoids and injects fuel and nitrous into the intake pipe. Zex is the only system out there that uses a "BOX" to determine the amount of fuel to put in by comparing it to the pressue in the nitrous bottle. Zex HP is rated at the flywheel, so if they say 50 shot it means approx 40HP at the wheels. NX and NOS are rated at the wheels, if they say 50 shot, it means 50HP at the wheels.
Since you are not a FWD you can wire it to run at WOT using the WOT switch. I don't see why you would hook it up to only run in the 5th gear. If the kit you buy doesn't come with a WOT switch or if you don't want to buy one, you can hook it up to a switch to activate it whenever you want nitrous.
What about an intercooler spray? Less dangerous...less expensive.
If you have a bottle leak of industrial grade nitrous...you'll be sorry...
If you have a bottle leak of C02...roll down the windows and you'll live.
Plus then you dont really have to worry about rich ####ups and burning metal.
Or getting a pool of N20 in your intake.
[Posted by 206.100.227.72. This is added while posting a message to avoid misuse of WebWarper: see http://webwarper.net/han Example of using WebWarper: http://webwarper.net/ww/www.dsmtuners.com/forums/showthread.php?t=208198 ]
Here's a thread I started about intercooler spray - http://www.dsmtuners.com/forums/showthread.php?t=206296
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
  • For sale 4G63 4 Port Mac Boost Solenoid with RaceArt Mount
    4 Port Mac Boost Solenoid with RaceArt Mount $60 + shipping & paypal fees* these RaceArt mount...
