Newbie Tuner!
BLKGSX23
91
May 1, 2009
Sullivan, Missouri
Im trying to learn how to tune on my own and have lil hard time! I wanna learn how to tune on my own and not rely on a buddie of mine thats super busy! Every and little advice would help! Im gunna post a log and could you guys tell me whats not right and why and what to change it to and why? thanks
Mods-
Ported EB16g
FIC 1000cc Inj.
255 FP
AEM AFPR- Base Fuel Pressure is 39 I believe
E85
I think thats all that matter for you guys to figure out whats needed!
1. You have a 2g MAS, so the massive adjustments in the MAF Comp table are a bit excessive. Also, this is causing your AFRatioEst to become incorrect and not match up with the LC-1 reading. You can use this to help get it dialed in, which shouldn't take much adjustment.
v3mafadjcombft [ECMTuning - wiki]
2. Take a look at this to adjust your TPS - v3tpsadj [ECMTuning - wiki]
3. I'd put back some of the timing you took away, especially around 3500-4000 RPMs. This will help smooth out your timing curve and give you back more timing. Unless you end up knocking, then pull it back out.
4. I might also pull some fuel out from 3000-4500 RPM to smooth out the LC-1 reading around 11:1.
I did put some timing back in and I got 1.1 to 1.4 counts of knock. I was just trying to get my afr's set were I read they should be about 12.5! So I pulled alot of full out and got my AFR's around 11.7 to 12.6 with only a couple little blimps of .4 knock!
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
