newbie to dsm,s many q's
CrazyLaser
Aug 17, 2005
chippewa falls, Wisconsin
hey every on im from chippewa falls wisconsin and im new to the dsm world recently changed over for the honda world. well im going to be buying maybe a 90 laser fwd with turbo for a 1000 dollars well the only thing wrong with it is a cluth pedal assmbely???? can i get some pics of this maybe so i know what it exactly is can it be drivin with out it or rigged to get it home any suggestions would be great.. thanks alot for all your help
later
adam
ummm, it would depend on what's wrong with the clutch pedal assembly. If you can manage to get the car into gear and rolling you can get it home by floating the shifter into each gear, but if you have to stop you're gonna be hurtin. You're bein a little too vague with the problem here.
later
adam
You need to be more descriptive with the clutch problem. Is it a slave cyl? Is the clutch toast? Is the rod missing or something weird? Find out exactly what the problem is and get back to us for some help. Its hard to tell with your description. Welcome to the site and Welcome to a fellow WIDSM'er!
well the deal is, is that the clutch assembly the guy said something about bolts stripped out i dont know exactly im gonna go look at it this weekend and maybe buy it depending on exactly what the problem is he said its got a new clutch in it but i dont know the problem in a detail but if you cant help me from here ill try to contact you back on the rest of the problem thanks alot
later adam
