DSM buying Q's
01QuadDak
157
Jan 6, 2004
Glenolden, Pennsylvania
I am looking into buying a DSM, as i'd like to have a 12-13 second daily driver. I've taken my kota to the limit, for the amount of money i'd need to put it into the 12's i could have another car.
First question, when looking at a used AWD DSM, what are some key points to look for, when starting, driving, and general appearance?
Secondly, what can i expect to pay for a stock DSM, or even a mildly modified one?
Thirdly, where can i get a good price on a Wideband O2reader/logger, as this would be the first mod to the car.
Thanks for any replies.
Eric Louie
First thing I look for are the obvious things.
Rust
leaking fluids
any parts missing
tires
interior (can tell a lot)
e test
can it be safetied
Then I look for DSM related problems
crank walk
ball joints
T- case leaking or invidence of a T- case lock up.
Eric Louie
Make sure you check all the fluid pressures (oil, etc.)
Another thing too, doa compression test right before you pick it up, make sure nothing is wrong with the head or block (valves bent, head gasket, etc.)
I would also check what "Staytuned" wrote, it was well written.
As far as a wideband o2 sensor, i would except to pay about $200 brand new.
If you have any other problems or questions, let us know!
-Alex
Also never buy at night or buy with emotion. If it is not exactly what you want walk away. Just because it looks like show car ........it might still be a lemon. Everybody has their reason for selling something, some sell to get rid of a headache.
How much would a car like the following be worth?
1991 Eclipse GSX
engine rebuilt, ARP head studs,4 layer metal head gasket,balance shafts removed
Ported polished head,Full Crower Valve train
T3/T4 .60 A/R turbo
Huge front mount I/C
Mass air flow translator
3 in. GM mass air flow sensor
Full 3 in. exh. with N1 muffler
arospeed cam gears
Apex-i turbo timer
Tial sport 38mm ext. wastegate and dump tube
Greddy type S BOV
race clutch and lightweight flywheel
Sheppherd Race Trans
KYB GR2 Struts and Sprint lowering springs
Autometer Boost,air fuel,and fuel pressure gauges
B&M fuel pressure regulator
720cc injectors
Short shifter with OBX Shift knob
