newbie stuff
jaredo
Feb 26, 2005
Fort Myers, Florida
I just installed my egt (was afraid to tune before hand when i got my first cel), did a log of my idle just to get an idea for a starting point. This is -3% across the board idle(550s, 190 pump, 1g regulator/rail, stock IC, stock maf, s-afcII)
Check out timing advance at idle, and o2 readings. I must be way off :( Also whats up with the TPS?
oh, i picked up a GM maf and maft, should I just wait till then to start?
Well the 02 reading looks fine .94. The TPS is probabaly just out of adj. The timing looks just fine, it should be around 8-10 idle. It looks like your only problem is your TPS is out of Adj
Kurt
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
