newbie gsx ?s
liveyoungdieold
Mar 5, 2010
greenfield, Indiana
this is my first gst. i have a couple basic questions. What are the simplest of mods for the gst? and what all do i need to change if i swap stock turbo for a 16g?
Do maintenance your car is 11 years old or older.
Maintenance. Then do a compression test. If your numbers are good after that then look at running a bigger turbo.
Remember your intake and exhuast system was designed for the turbo you have now. Look at upgrading that stuff first.
Check the upgrade paths. Just click TECH in the upper left corner of the webpage and select UPGRADE PATHS. They will have multiple upgrades starting fromt the basics up.
Welcome. DSM Forums - FAQ. First and formost you are going to want to read through the rules and learn the search function. DSM Forums - Search Forums. Make sure to change it to Search Titles. From there jus type in 16g install or anything like that and you will get your results. DSM Forums - Search Results. That is just a 2g 16g install search. These threads have been asked dozens of times and you can search and get great idea's and feedback from what other people did and tried. We also have an upgrade path as well. Tech Guide - DSMtuners. Also the Tech and VFAQ is an awesome place for write-ups. Tech Article Archives - DSM Forums
alright thanks guys and i have the 16g turbo already and a kandN intake im jus slowly but surley getting my mods to have all work done at once. Since were on the subject what exhaust should i invest in for a bassy sound and 3in tip? i dnt want the weed eater sound
I liked the Megan system i had on my old 98 GST. No cat and the Megan cat back system, sounded great
These arent honda's you not going to get a "weed eater" sound at all with these cars.
with everything you will read when trying to upgrade these cars, MAINTENANCE, MAINTENANCE, MAINTENANCE is usually attached to every post. DO IT. and most any 3" exhaust will be fine, get a full exhaust, not a tip.
