Newb logging questions...12 counts of knock
16vdohcturboawd
447
Apr 15, 2003
the moon, Maine
I would of posted this in the log section but its rather noobish and I cant get my logs on my pc yet so here goes.
I just plugged in the logger for the first time and did a few runs and I have a few questions.
At WOT im getting 3-4 counts of knock and im wondering if everything looks normal so here is the WOT log copied from my palm.
RPM 5812
INJP 16.63ms
Knock 3
02R .95v
TPS 53.5
IN duty cycle 80.4
Timing advance 20 degrees
Maf 1603hz
On that run thats the highest I got the engine revved to and the highest I saw the Injector duty cycle at. Now my cars almost stock is it normal to see that knock?
On one of my second runs I belive I was in 4th gear and I pulled 12 counts of knock, this was the highest knock I recorded. Heres the log, does it look like everythings ok?
RPM 2843
INJP 4.60ms
Knock 12
02R .80
TPS 27.7
Injector duty cycle 10.9
Timing advance 25 degrees
Maf 339.6
The car is almost stock, heres the mod list
Hacked mas
K and n filter
Stock bcs with restrictor removed
2.5" turbo back with test pipe
walbro 190
stock 14b, boosts 14-16psi in 3rd
has a new fuel filter, plugs, wires.
I also have a set of evo 560s and an safc but havent installed them yet, I just want to make sure everything looks ok before I go further.
Im still working on that, I cant figure out how to get it from a .pdb file to something readable. I tried the program off Pocketloggers website to no avail. Its weird though because im not getting any or very little knock at WOT. The only time I get knock anywhere between 7-12 counts usally is at low rpm such as 2500-3500. Im not sure if this is phantom knock or what. I suppose part of it could be this crap 91 octane that we have to live with up here now.
Heres my log
Code:
   TIME  	FLG0  	FLG1  	TIMA  	COOL  	FTRL  	FTRM  	FTRH  	FTO2  	EGRT  	O2-R  	BATT  	BARO  	ISC   	TPS   	MAFS  	ACLE  	ERPM  	KNCK  	INJP  	---   	AIRT  	O2-F  	---   	CUS0  	CUS1  	CUS2  	CUS3  	CUS4  	CUS5  	CUS6  	CUS7
######## 		1.79 		109 	2.96
######## 	175 	244 	8 	26 	118.56 	87.36 	81.12 	155.22 	228 	0.8 	13.93 	201 	36 	10.2 	25.16 	0 	750 	0 	1.79 	1 	109 	2.96
######## 	175 	240 	10 	26 	118.56 	87.36 	81.12 	152.88 	228 	0.64 	14 	201 	36 	10.2 	25.16 	0 	718.75 	0 	1.79 	1 	109 	2.96
######## 	174 	244 	8 	26 	118.56 	87.36 	81.12 	150.54 	228 	0.78 	14 	201 	36 	10.2 	25.16 	0 	750 	0 	1.79 	1 	109 	2.96
######## 	174 	244 	10 	26 	118.56 	87.36 	81.12 	147.42 	228 	0.72 	14 	201 	37 	10.2 	25.16 	0 	687.5 	0 	1.79 	1 	109 	2.96
######## 	174 	240 	12 	26 	118.56 	87.36 	81.12 	147.42 	228 	0.25 	14 	201 	37 	10.2 	25.16 	0 	750 	0 	1.79 	1 	109 	2.96
######## 	174 	244 	7 	26 	118.56 	87.36 	81.12 	149.76 	228 	0.16 	14 	201 	37 	10.2 	25.16 	0 	781.25 	0 	1.79 	1 	109 	2.96
######## 	175 	244 	7 	26 	118.56 	87.36 	81.12 	152.1 	228 	0.14 	14 	201 	38 	10.2 	25.16 	0 	750 	0 	1.79 	1 	109 	2.96
######## 	175 	244 	9 	26 	118.56 	87.36 	81.12 	155.22 	228 	0.12 	14 	201 	38 	10.2 	25.16 	0 	750 	0 	1.79 	1 	109 	2.96
######## 	174 	240 	8 	26 	118.56 	87.36 	81.12 	157.56 	228 	0.14 	14 	201 	38 	10.2 	25.16 	0 	781.25 	0 	1.79 	1 	109 	2.96
######## 	174 	244 	7 	26 	118.56 	87.36 	81.12 	159.9 	228 	0.53 	14 	201 	38 	10.2 	25.16 	0 	781.25 	0 	1.79 	1 	109 	2.96
######## 	174 	244 	7 	26 	118.56 	87.36 	81.12 	157.56 	228 	0.76 	12.61 	201 	37 	10.2 	25.16 	0 	750 	0 	1.79 	1 	109 	2.96
######## 	175 	240 	15 	25 	118.56 	87.36 	81.12 	155.22 	228 	0.72 	13.12 	201 	37 	10.2 	25.16 	0 	625 	0 	2.05 	1 	109 	2.96
######## 	167 	240 	18 	25 	118.56 	87.36 	81.12 	155.22 	228 	0.18 	13.85 	201 	44 	10.2 	25.16 	0 	656.25 	0 	2.05 	1 	109 	2.96
######## 	175 	244 	14 	25 	118.56 	87.36 	81.12 	157.56 	228 	0.16 	13.93 	201 	44 	10.2 	31.45 	0 	750 	0 	2.05 	1 	109 	2.96
######## 	174 	244 	5 	25 	118.56 	87.36 	81.12 	157.56 	228 	0.76 	13.93 	201 	44 	10.2 	31.45 	0 	781.25 	0 	2.05 	1 	109 	2.96
######## 	174 	244 	7 	25 	118.56 	87.36 	81.12 	155.22 	228 	0.66 	13.93 	201 	43 	10.2 	31.45 	0 	781.25 	0 	1.79 	1 	109 	2.96
######## 	174 	244 	7 	25 	118.56 	87.36 	81.12 	155.22 	228 	0.2 	13.93 	201 	43 	10.2 	31.45 	0 	750 	0 	2.05 	1 	109 	2.96
######## 	175 	244 	8 	25 	118.56 	87.36 	81.12 	157.56 	228 	0.14 	13.93 	201 	43 	10.2 	31.45 	0 	781.25 	0 	2.05 	1 	109 	2.96
######## 	174 	244 	8 	25 	118.56 	87.36 	81.12 	160.68 	228 	0.49 	13.93 	201 	43 	10.2 	31.45 	0 	781.25 	0 	2.05 	1 	109 	2.96
######## 	174 	240 	8 	25 	118.56 	87.36 	81.12 	158.34 	228 	0.82 	13.93 	201 	42 	10.2 	25.16 	0 	781.25 	0 	1.79 	1 	109 	2.96
######## 	175 	244 	8 	25 	118.56 	87.36 	81.12 	156 	228 	0.86 	13.93 	201 	42 	10.2 	31.45 	0 	781.25 	0 	1.79 	1 	109 	2.96
######## 	175 	244 	9 	25 	118.56 	87.36 	81.12 	152.88 	228 	0.88 	13.93 	201 	42 	10.2 	31.45 	0 	781.25 	0 	1.79 	1 	109 	2.96
######## 	174 	240 	9 	25 	118.56 	87.36 	81.12 	150.54 	228 	0.84 	13.93 	201 	42 	10.2 	25.16 	0 	750 	0 	2.05 	1 	109 	2.96
######## 	175 	240 	9 	25 	118.56 	87.36 	81.12 	148.2 	228 	0.84 	13.93 	201 	42 	10.2 	31.45 	0 	718.75 	0 	2.05 	1 	109 	2.96
######## 	175 	244 	8 	25 	118.56 	87.36 	81.12 	145.86 	228 	0.88 	13.93 	201 	42 	10.2 	31.45 	0 	750 	0 	2.05 	1 	109 	2.96
######## 	174 	240 	8 	25 	118.56 	87.36 	81.12 	142.74 	228 	0.88 	13.85 	201 	42 	10.2 	25.16 	0 	718.75 	0 	2.05 	1 	109 	2.96
######## 	174 	244 	11 	25 	118.56 	87.36 	81.12 	140.4 	228 	0.62 	13.85 	201 	42 	10.2 	31.45 	0 	750 	0 	2.05 	1 	109 	2.96
######## 	175 	244 	7 	25 	118.56 	87.36 	81.12 	141.18 	228 	0.29 	13.93 	201 	41 	10.2 	31.45 	0 	781.25 	0 	1.79 	1 	109 	2.96
######## 	174 	240 	10 	25 	118.56 	87.36 	81.12 	144.3 	228 	0.23 	13.85 	201 	41 	10.2 	25.16 	0 	750 	0 	1.79 	1 	109 	2.96
######## 	174 	240 	8 	25 	118.56 	87.36 	81.12 	146.64 	228 	0.16 	13.93 	201 	41 	10.2 	25.16 	0 	750 	0 	2.05 	1 	109 	2.96
######## 	175 	244 	8 	25 	118.56 	87.36 	81.12 	148.98 	228 	0.16 	13.93 	201 	41 	10.2 	25.16 	0 	750 	0 	1.79 	1 	109 	2.96
######## 	175 	240 	8 	25 	118.56 	87.36 	81.12 	149.76 	228 	0.66 	13.93 	201 	41 	10.2 	31.45 	0 	750 	0 	1.79 	1 	109 	2.96
######## 	171 	244 	8 	25 	118.56 	87.36 	81.12 	147.42 	228 	0.78 	13.85 	201 	41 	10.2 	31.45 	0 	750 	0 	2.05 	1 	109 	2.96
######## 	175 	244 	8 	25 	118.56 	87.36 	81.12 	145.08 	228 	0.72 	13.85 	201 	41 	10.2 	31.45 	0 	750 	0 	2.05 	1 	109 	2.96
######## 	175 	244 	8 	25 	118.56 	87.36 	81.12 	141.96 	228 	0.76 	13.85 	201 	41 	10.2 	31.45 	0 	750 	0 	2.05 	1 	109 	2.96
######## 	175 	244 	8 	25 	118.56 	87.36 	81.12 	139.62 	228 	0.86 	13.93 	201 	41 	10.2 	31.45 	0 	750 	0 	2.05 	1 	109 	2.96
######## 	175 	244 	8 	25 	118.56 	87.36 	81.12 	137.28 	228 	0.84 	13.93 	201 	41 	10.2 	31.45 	0 	750 	0 	0.77 	0 	109 	2.96
######## 	174 	112 	8 	25 	118.56 	87.36 	81.12 	134.16 	228 	0.9 	13.93 	201 	54 	15.69 	169.83 	0 	1500 	0 	3.33 	5 	109 	2.96
######## 	174 	244 	29 	25 	118.56 	87.36 	81.12 	122.46 	228 	0.92 	13.85 	201 	41 	10.2 	50.32 	0 	2000 	0 	1.28 	2 	109 	2.96
######## 	174 	240 	35 	25 	118.56 	87.36 	81.12 	99.84 	228 	0.25 	13.93 	201 	41 	10.2 	31.45 	0 	1531.25 	0 	0 	0 	109 	2.96
######## 	174 	244 	27 	25 	118.56 	87.36 	81.12 	99.84 	228 	0.16 	13.93 	201 	41 	10.2 	31.45 	0 	1062.5 	0 	1.54 	1 	109 	2.96
######## 	175 	244 	18 	25 	118.56 	87.36 	81.12 	102.18 	228 	0.12 	13.85 	201 	41 	10.2 	31.45 	0 	875 	0 	1.79 	1 	109 	2.96
######## 	174 	244 	11 	25 	118.56 	87.36 	81.12 	107.64 	228 	0.1 	13.85 	201 	41 	10.2 	31.45 	0 	781.25 	0 	1.79 	1 	109 	2.96
######## 	175 	240 	10 	25 	118.56 	87.36 	81.12 	113.1 	228 	0.35 	13.85 	201 	41 	10.2 	31.45 	0 	718.75 	0 	2.05 	1 	109 	2.96
######## 	175 	244 	11 	25 	118.56 	87.36 	81.12 	109.2 	228 	0.86 	13.85 	201 	42 	10.2 	31.45 	0 	750 	0 	2.05 	1 	109 	2.96
######## 	175 	244 	8 	25 	118.56 	87.36 	81.12 	104.52 	228 	0.92 	13.93 	201 	42 	10.2 	31.45 	0 	750 	0 	2.05 	1 	109 	2.96
######## 	175 	240 	7 	25 	118.56 	87.36 	81.12 	99.06 	228 	0.92 	13.85 	201 	42 	10.2 	31.45 	0 	750 	0 	2.05 	1 	109 	2.96
######## 	174 	244 	7 	25 	118.56 	87.36 	81.12 	94.38 	228 	0.86 	13.93 	201 	42 	10.2 	31.45 	0 	718.75 	0 	2.05 	1 	109 	2.96
######## 	174 	244 	9 	25 	118.56 	87.36 	81.12 	89.7 	228 	0.62 	13.85 	201 	43 	10.2 	31.45 	0 	718.75 	0 	1.79 	1 	109 	2.96
######## 	175 	244 	8 	25 	118.56 	87.36 	81.12 	90.48 	228 	0.27 	13.85 	201 	43 	10.2 	31.45 	0 	718.75 	0 	2.05 	1 	109 	2.96
######## 	174 	240 	8 	25 	118.56 	87.36 	81.12 	95.94 	228 	0.16 	13.85 	201 	43 	10.2 	37.74 	0 	718.75 	0 	2.05 	1 	109 	2.96
######## 	174 	244 	9 	25 	118.56 	87.36 	81.12 	99.84 	228 	0.12 	13.85 	201 	43 	10.2 	31.45 	0 	750 	0 	2.05 	1 	109 	2.96
######## 	174 	240 	7 	25 	118.56 	87.36 	81.12 	103.74 	228 	0.18 	13.85 	201 	43 	10.2 	31.45 	0 	750 	0 	2.05 	1 	109 	2.96
######## 	175 	244 	7 	25 	118.56 	87.36 	81.12 	105.3 	228 	0.27 	13.85 	201 	43 	10.2 	31.45 	0 	750 	0 	2.05 	1 	109 	2.96
######## 	175 	240 	7 	25 	118.56 	87.36 	81.12 	108.42 	228 	0.37 	13.85 	201 	43 	10.2 	31.45 	0 	750 	0 	1.79 	1 	109 	2.96
######## 	174 	244 	8 	25 	118.56 	87.36 	81.12 	106.86 	228 	0.84 	13.85 	201 	43 	10.2 	31.45 	0 	750 	0 	1.79 	1 	109 	2.96
######## 	175 	240 	12 	25 	118.56 	87.36 	81.12 	104.52 	228 	0.68 	13.85 	201 	44 	10.2 	31.45 	0 	718.75 	0 	2.05 	1 	109 	2.96
######## 	174 	244 	8 	25 	118.56 	87.36 	81.12 	105.3 	228 	0.2 	13.93 	201 	44 	10.2 	31.45 	0 	750 	0 	1.79 	1 	109 	2.96
######## 	175 	240 	5 	25 	118.56 	87.36 	81.12 	107.64 	228 	0.14 	13.93 	201 	44 	10.2 	31.45 	0 	781.25 	0 	1.79 	1 	109 	2.96
######## 	175 	244 	7 	25 	118.56 	87.36 	81.12 	110.76 	228 	0.12 	13.93 	201 	43 	10.2 	31.45 	0 	781.25 	0 	1.79 	1 	109 	2.96
######## 	175 	244 	7 	25 	118.56 	87.36 	81.12 	113.1 	228 	0.1 	13.93 	201 	43 	10.2 	31.45 	0 	781.25 	0 	1.79 	1 	108 	2.96
######## 	174 	240 	8 	25 	118.56 	87.36 	81.12 	115.44 	228 	0.1 	13.93 	201 	43 	10.2 	31.45 	0 	812.5 	0 	1.79 	1 	109 	2.96
######## 	175 	244 	9 	25 	118.56 	87.36 	81.12 	118.56 	228 	0.1 	13.93 	201 	42 	10.2 	31.45 	0 	781.25 	0 	1.79 	1 	108 	2.96
######## 	175 	244 	9 	25 	118.56 	87.36 	81.12 	120.9 	228 	0.1 	13.93 	201 	42 	10.2 	31.45 	0 	781.25 	0 	1.79 	1 	108 	2.96
######## 	174 	240 	9 	25 	118.56 	87.36 	81.12 	123.24 	228 	0.1 	13.93 	201 	42 	10.2 	31.45 	0 	781.25 	0 	1.79 	1 	108 	2.96
######## 	174 	244 	9 	25 	118.56 	87.36 	81.12 	126.36 	228 	0.1 	13.93 	201 	41 	10.2 	31.45 	0 	781.25 	0 	1.79 	1 	108 	2.96
######## 	175 	240 	10 	25 	118.56 	87.36 	81.12 	129.48 	228 	0.1 	13.93 	201 	41 	10.2 	31.45 	0 	781.25 	0 	1.79 	1 	108 	2.96
######## 	174 	244 	9 	25 	118.56 	87.36 	81.12 	131.82 	228 	0.1 	13.93 	201 	41 	11.76 	31.45 	0 	781.25 	0 	2.3 	1 	108 	2.96
######## 	175 	116 	8 	25 	118.56 	87.36 	81.12 	134.16 	228 	0.08 	13.93 	201 	41 	10.2 	81.77 	0 	1187.5 	0 	2.56 	3 	108 	2.96
######## 	167 	240 	18 	25 	118.56 	87.36 	81.12 	134.94 	228 	0.9 	13.93 	201 	41 	10.2 	44.03 	0 	1500 	0 	0 	0 	108 	2.96
######## 	174 	244 	20 	25 	118.56 	87.36 	81.12 	99.84 	228 	0.49 	13.93 	201 	41 	10.2 	31.45 	0 	1125 	0 	1.28 	1 	108 	2.96
######## 	175 	244 	19 	25 	118.56 	87.36 	81.12 	104.52 	228 	0.18 	13.93 	201 	41 	10.2 	25.16 	0 	875 	0 	1.79 	1 	108 	2.96
######## 	174 	240 	13 	25 	118.56 	87.36 	81.12 	110.76 	228 	0.14 	13.93 	201 	41 	10.2 	31.45 	0 	781.25 	0 	1.79 	1 	108 	2.96
######## 	175 	240 	9 	25 	118.56 	87.36 	81.12 	115.44 	228 	0.12 	13.93 	201 	41 	10.2 	31.45 	0 	781.25 	0 	1.79 	1 	108 	2.96
######## 	175 	244 	6 	25 	118.56 	87.36 	81.12 	120.9 	228 	0.53 	13.93 	201 	41 	10.2 	31.45 	0 	781.25 	0 	1.79 	1 	108 	2.96
######## 	174 	244 	7 	25 	118.56 	87.36 	81.12 	116.22 	228 	0.82 	13.93 	201 	40 	10.2 	31.45 	0 	781.25 	0 	1.79 	1 	108 	2.96
######## 	174 	240 	8 	25 	118.56 	87.36 	81.12 	110.76 	228 	0.84 	13.93 	201 	40 	10.2 	31.45 	0 	750 	0 	1.79 	1 	108 	2.96
######## 	175 	244 	7 	25 	118.56 	87.36 	81.12 	106.08 	228 	0.76 	13.93 	201 	40 	10.2 	31.45 	0 	781.25 	0 	1.79 	1 	108 	2.96
######## 	175 	240 	8 	25 	118.56 	87.36 	81.12 	101.4 	228 	0.57 	13.93 	201 	39 	10.2 	25.16 	0 	718.75 	0 	1.79 	1 	108 	2.96
######## 	175 	244 	10 	25 	118.56 	87.36 	81.12 	102.96 	228 	0.2 	13.93 	201 	39 	10.2 	25.16 	0 	718.75 	0 	1.79 	1 	108 	2.96
######## 	174 	240 	8 	25 	118.56 	87.36 	81.12 	107.64 	228 	0.14 	13.93 	201 	39 	10.2 	25.16 	0 	718.75 	0 	1.79 	1 	108 	2.96
######## 	174 	244 	10 	25 	118.56 	87.36 	81.12 	113.1 	228 	0.12 	13.93 	201 	40 	10.2 	25.16 	0 	750 	0 	1.79 	1 	108 	2.96
######## 	174 	240 	7 	25 	118.56 	87.36 	81.12 	117 	228 	0.1 	13.93 	201 	40 	10.2 	31.45 	0 	750 	0 	1.79 	1 	108 	2.96
######## 	175 	244 	8 	25 	118.56 	87.36 	81.12 	119.34 	228 	0.1 	13.93 	201 	40 	10.2 	31.45 	0 	781.25 	0 	1.79 	1 	108 	2.96
######## 	174 	244 	7 	25 	118.56 	87.36 	81.12 	122.46 	228 	0.1 	13.93 	201 	39 	10.2 	25.16 	0 	750 	0 	1.79 	1 	108 	2.96
######## 	174 	244 	8 	25 	118.56 	87.36 	81.12 	124.8 	228 	0.1 	13.93 	201 	39 	10.2 	31.45 	0 	750 	0 	1.79 	1 	108 	2.96
######## 	175 	240 	8 	26 	118.56 	87.36 	81.12 	127.14 	228 	0.1 	13.93 	201 	39 	10.2 	25.16 	0 	781.25 	0 	1.79 	1 	108 	2.96
######## 	175 	244 	8 	26 	118.56 	87.36 	81.12 	130.26 	228 	0.1 	13.93 	201 	39 	10.2 	25.16 	0 	750 	0 	1.79 	1 	108 	2.96
######## 	175 	240 	8 	26 	118.56 	87.36 	81.12 	132.6 	228 	0.1 	13.93 	201 	39 	10.2 	31.45 	0 	750 	0 	1.79 	1 	108 	2.96
######## 	175 	244 	8 	26 	118.56 	87.36 	81.12 	134.94 	228 	0.1 	13.93 	201 	39 	10.2 	25.16 	0 	781.25 	0 	1.79 	1 	108 	2.96
######## 	175 	240 	8 	26 	118.56 	87.36 	81.12 	138.06 	228 	0.1 	13.93 	201 	38 	10.2 	25.16 	0 	781.25 	0 	1.79 	1 	108 	2.96
######## 	175 	244 	9 	26 	118.56 	87.36 	81.12 	140.4 	228 	0.12 	13.93 	201 	38 	10.2 	25.16 	0 	750 	0 	1.79 	1 	108 	2.96
######## 	174 	244 	9 	26 	118.56 	87.36 	81.12 	142.74 	228 	0.1 	13.93 	201 	38 	10.2 	25.16 	0 	750 	0 	1.79 	1 	108 	2.96
######## 	174 	244 	8 	26 	118.56 	87.36 	81.12 	145.08 	228 	0.16 	13.93 	201 	38 	10.2 	25.16 	0 	750 	0 	1.79 	1 	108 	2.96
######## 	174 	240 	9 	26 	118.56 	87.36 	81.12 	145.86 	228 	0.72 	13.93 	201 	38 	10.2 	25.16 	0 	750 	0 	1.79 	1 	108 	2.96
######## 	174 	240 	8 	26 	118.56 	87.36 	81.12 	142.74 	228 	0.72 	13.93 	201 	38 	10.2 	25.16 	0 	718.75 	0 	1.79 	1 	108 	2.96
######## 	174 	244 	10 	26 	118.56 	87.36 	81.12 	141.18 	228 	0.41 	13.93 	201 	38 	10.2 	25.16 	0 	750 	0 	1.79 	1 	108 	2.96
######## 	174 	244 	8 	26 	118.56 	87.36 	81.12 	143.52 	228 	0.2 	13.93 	201 	38 	10.2 	25.16 	0 	750 	0 	1.79 	1 	108 	2.96
######## 	174 	240 	8 	26 	118.56 	87.36 	81.12 	145.86 	228 	0.43 	13.93 	201 	38 	10.2 	25.16 	0 	750 	0 	1.79 	1 	108 	2.96
######## 	174 	244 	7 	26 	118.56 	87.36 	81.12 	148.2 	228 	0.35 	13.93 	201 	38 	10.2 	25.16 	0 	781.25 	0 	1.79 	1 	108 	2.96
######## 	175 	240 	8 	26 	118.56 	87.36 	81.12 	148.98 	228 	0.7 	13.93 	201 	37 	10.2 	25.16 	0 	781.25 	0 	1.79 	1 	108 	2.96
######## 	175 	244 	8 	26 	118.56 	87.36 	81.12 	146.64 	228 	0.78 	13.93 	201 	37 	10.2 	25.16 	0 	750 	0 	1.79 	1 	108 	2.96
######## 	174 	244 	10 	26 	118.56 	87.36 	81.12 	144.3 	228 	0.66 	13.93 	201 	37 	10.2 	25.16 	0 	750 	0 	1.79 	1 	108 	2.96
######## 	174 	244 	8 	26 	118.56 	87.36 	81.12 	142.74 	228 	0.41 	13.71 	201 	37 	10.2 	25.16 	0 	718.75 	0 	1.79 	1 	108 	2.96
######## 	175 	244 	13 	26 	118.56 	87.36 	81.12 	145.08 	228 	0.18 	13.93 	201 	38 	10.2 	25.16 	0 	718.75 	0 	1.79 	1 	108 	2.96
######## 	175 	244 	7 	26 	118.56 	87.36 	81.12 	147.42 	228 	0.14 	13.93 	201 	38 	10.2 	25.16 	0 	718.75 	0 	1.79 	1 	108 	2.96
######## 	175 	244 	9 	26 	118.56 	87.36 	81.12 	149.76 	228 	0.2 	13.78 	201 	38 	10.2 	25.16 	0 	718.75 	0 	1.79 	1 	108 	2.96
######## 	175 	244 	9 	26 	118.56 	87.36 	81.12 	152.1 	228 	0.14 	13.85 	201 	39 	10.2 	25.16 	0 	718.75 	0 	2.05 	1 	108 	2.96
######## 	174 	116 	9 	26 	118.56 	87.36 	81.12 	154.44 	228 	0.14 	13.93 	201 	39 	14.51 	31.45 	8.24 	718.75 	0 	3.07 	2 	108 	2.96
######## 	174 	112 	7 	26 	118.56 	87.36 	81.12 	157.56 	228 	0.12 	13.93 	201 	39 	15.29 	75.48 	0.39 	1125 	0 	3.07 	3 	108 	2.96
######## 	175 	116 	19 	26 	118.56 	87.36 	81.12 	157.56 	228 	0.86 	13.93 	201 	39 	16.08 	88.06 	0 	1562.5 	0 	2.56 	4 	108 	2.96
######## 	175 	116 	23 	26 	118.56 	87.36 	81.12 	145.86 	228 	0.86 	13.93 	201 	39 	19.61 	119.51 	0 	1656.25 	0 	3.07 	5 	108 	2.96
######## 	174 	116 	25 	26 	118.56 	87.36 	81.12 	138.84 	228 	0.29 	13.93 	201 	39 	19.61 	138.38 	0 	1812.5 	0 	3.33 	6 	108 	2.96
######## 	167 	112 	27 	26 	118.56 	87.36 	81.12 	150.54 	228 	0.84 	13.93 	201 	39 	19.61 	138.38 	0 	1875 	2 	3.33 	6 	108 	2.96
######## 	170 	124 	29 	26 	118.56 	87.36 	81.12 	135.72 	228 	0.94 	13.93 	201 	44 	18.82 	138.38 	0 	1843.75 	0 	3.07 	6 	108 	2.96
######## 	175 	116 	29 	26 	118.56 	87.36 	81.12 	121.68 	228 	0.92 	13.93 	201 	39 	18.43 	119.51 	0 	1718.75 	0 	2.82 	5 	108 	2.96
######## 	174 	116 	29 	26 	118.56 	87.36 	81.12 	107.64 	228 	0.92 	13.93 	201 	39 	18.43 	119.51 	0 	1500 	0 	3.07 	4 	108 	2.96
######## 	175 	112 	25 	26 	118.56 	87.36 	81.12 	96.72 	228 	0.68 	13.93 	201 	39 	18.43 	125.8 	0 	1437.5 	0 	3.07 	4 	107 	2.96
######## 	174 	112 	25 	26 	118.56 	87.36 	81.12 	95.94 	228 	0.23 	13.93 	201 	39 	15.69 	100.64 	0 	1437.5 	0 	2.56 	3 	107 	2.96
######## 	174 	116 	20 	26 	118.56 	87.36 	81.12 	93.6 	228 	0.92 	13.93 	201 	39 	12.16 	69.19 	0 	1375 	0 	2.05 	3 	107 	2.96
######## 	174 	112 	18 	26 	118.56 	87.36 	81.12 	85.02 	228 	0.96 	13.93 	201 	39 	11.76 	50.32 	0 	1187.5 	0 	1.79 	2 	107 	2.96
######## 	175 	116 	20 	26 	118.56 	87.36 	81.12 	76.44 	228 	0.96 	13.93 	201 	46 	11.76 	44.03 	0 	968.75 	0 	2.05 	2 	107 	2.96
######## 	174 	124 	17 	26 	118.56 	87.36 	81.12 	70.2 	228 	0.96 	13.93 	201 	39 	11.76 	44.03 	0 	875 	0 	2.05 	1 	107 	2.96
######## 	174 	124 	8 	26 	118.56 	87.36 	81.12 	64.74 	228 	0.94 	13.93 	201 	54 	11.76 	50.32 	0 	875 	0 	2.3 	2 	107 	2.96
######## 	174 	244 	7 	26 	118.56 	87.36 	81.12 	58.5 	228 	0.9 	13.93 	201 	39 	10.2 	44.03 	0 	1000 	0 	1.79 	1 	107 	2.96
######## 	174 	244 	10 	26 	118.56 	87.36 	81.12 	53.04 	228 	0.9 	13.93 	201 	39 	10.2 	37.74 	0 	937.5 	0 	1.54 	1 	107 	2.96
######## 	175 	244 	14 	26 	118.56 	87.36 	81.12 	46.02 	228 	0.68 	13.93 	201 	39 	10.2 	31.45 	0 	750 	0 	1.54 	1 	107 	2.96
######## 	174 	244 	17 	26 	118.56 	87.36 	81.12 	46.02 	228 	0.21 	13.34 	201 	39 	10.2 	25.16 	0 	531.25 	0 	2.05 	1 	108 	2.96
######## 	175 	244 	12 	26 	118.56 	87.36 	81.12 	49.92 	228 	0.14 	12.9 	201 	39 	10.2 	31.45 	0 	531.25 	0 	2.05 	1 	108 	2.96
######## 	171 	248 	11 	26 	118.56 	87.36 	81.12 	53.82 	228 	0.12 	13.93 	201 	54 	10.2 	31.45 	0 	593.75 	0 	2.3 	1 	108 	2.96
######## 	174 	248 	14 	26 	118.56 	87.36 	81.12 	57.72 	228 	0.1 	13.93 	201 	54 	13.73 	50.32 	0 	843.75 	0 	2.3 	2 	108 	2.96
######## 	174 	124 	7 	26 	118.56 	87.36 	81.12 	63.96 	228 	0.1 	14 	201 	54 	21.57 	106.93 	7.45 	1125 	0 	3.84 	4 	107 	2.96
######## 	174 	124 	23 	26 	118.56 	87.36 	81.12 	74.88 	228 	0.08 	13.93 	201 	54 	21.96 	188.7 	0 	2062.5 	0 	3.33 	7 	107 	2.96
######## 	174 	124 	32 	26 	118.56 	87.36 	81.12 	95.94 	228 	0.08 	13.93 	201 	54 	21.96 	188.7 	0 	2218.75 	0 	3.33 	7 	107 	2.96
######## 	166 	124 	33 	26 	118.56 	87.36 	81.12 	119.34 	228 	0.08 	13.93 	201 	54 	21.96 	201.28 	0 	2218.75 	0 	3.58 	8 	107 	2.96
######## 	174 	124 	32 	26 	118.56 	87.36 	81.12 	124.02 	228 	0.88 	13.93 	201 	54 	21.96 	194.99 	0 	2000 	0 	3.84 	8 	107 	2.96
######## 	174 	124 	29 	26 	118.56 	87.36 	81.12 	109.2 	228 	0.84 	13.93 	201 	54 	21.96 	194.99 	0 	1875 	0 	3.84 	7 	107 	2.96
######## 	175 	120 	27 	26 	118.56 	87.36 	81.12 	94.38 	228 	0.86 	13.93 	201 	54 	20.78 	176.12 	0 	1718.75 	0 	3.58 	6 	107 	2.96
######## 	173 	112 	25 	26 	118.56 	87.36 	81.12 	81.12 	228 	0.64 	13.93 	201 	39 	20 	169.83 	0 	1593.75 	0 	3.58 	6 	107 	2.96
######## 	170 	116 	24 	26 	118.56 	87.36 	81.12 	69.42 	228 	0.8 	13.93 	201 	39 	18.04 	132.09 	0 	1437.5 	0 	3.07 	4 	107 	2.96
######## 	175 	112 	23 	26 	118.56 	87.36 	81.12 	58.5 	228 	0.58 	13.93 	201 	39 	17.65 	132.09 	0 	1468.75 	0 	3.07 	4 	107 	2.96
######## 	175 	116 	25 	26 	118.56 	87.36 	81.12 	64.74 	228 	0.2 	13.93 	201 	39 	17.65 	132.09 	0 	1562.5 	0 	3.07 	5 	107 	2.96
######## 	175 	116 	27 	26 	118.56 	87.36 	81.12 	66.3 	228 	0.82 	13.93 	201 	39 	18.04 	132.09 	0 	1656.25 	0 	2.82 	4 	107 	2.96
######## 	175 	116 	28 	26 	118.56 	87.36 	81.12 	53.82 	228 	0.43 	13.93 	201 	39 	19.22 	138.38 	0 	1750 	0 	2.82 	5 	107 	2.96
######## 	170 	116 	29 	26 	118.56 	87.36 	81.12 	71.76 	228 	0.14 	13.93 	201 	39 	19.22 	150.96 	0 	1843.75 	0 	3.07 	6 	107 	2.96
######## 	175 	116 	31 	26 	118.56 	87.36 	81.12 	88.92 	228 	0.18 	13.93 	201 	39 	19.22 	150.96 	0 	1937.5 	0 	2.82 	5 	107 	2.96
######## 	174 	116 	30 	26 	118.56 	87.36 	81.12 	84.24 	228 	0.94 	13.93 	201 	39 	14.9 	100.64 	0 	2000 	1 	1.79 	3 	106 	2.96
######## 	175 	112 	37 	26 	118.56 	87.36 	81.12 	70.2 	228 	0.96 	13.93 	201 	39 	10.2 	44.03 	0 	1875 	0 	1.28 	2 	107 	2.96
######## 	174 	244 	31 	26 	118.56 	87.36 	81.12 	56.16 	228 	0.66 	13.93 	201 	39 	10.2 	37.74 	0 	1593.75 	0 	0 	0 	107 	2.96
######## 	174 	244 	29 	26 	118.56 	87.36 	81.12 	99.84 	228 	0.18 	13.93 	201 	39 	10.2 	31.45 	0 	1093.75 	0 	1.54 	1 	107 	2.96
######## 	174 	240 	20 	26 	118.56 	87.36 	81.12 	105.3 	228 	0.12 	13.93 	201 	39 	10.2 	31.45 	0 	937.5 	0 	1.79 	1 	107 	2.96
######## 	174 	240 	15 	26 	118.56 	87.36 	81.12 	110.76 	228 	0.1 	13.93 	201 	39 	10.2 	31.45 	0 	812.5 	0 	1.79 	1 	107 	2.96
######## 	175 	244 	12 	26 	118.56 	87.36 	81.12 	110.76 	228 	0.9 	13.93 	201 	39 	10.2 	31.45 	0 	750 	0 	2.05 	1 	107 	2.96
######## 	174 	244 	10 	26 	118.56 	87.36 	81.12 	106.08 	228 	0.96 	13.93 	201 	39 	10.2 	31.45 	0 	718.75 	0 	2.05 	1 	107 	2.96
######## 	175 	244 	11 	26 	118.56 	87.36 	81.12 	101.4 	228 	0.96 	13.93 	201 	39 	10.2 	31.45 	0 	750 	0 	2.05 	1 	107 	2.96
######## 	175 	240 	7 	26 	118.56 	87.36 	81.12 	96.72 	228 	0.96 	13.93 	201 	38 	10.2 	31.45 	0 	781.25 	0 	1.79 	1 	107 	2.96
######## 	175 	244 	6 	26 	118.56 	87.36 	81.12 	91.26 	228 	0.96 	13.93 	201 	38 	10.2 	31.45 	0 	750 	0 	1.79 	1 	107 	2.96
######## 	175 	240 	10 	26 	118.56 	87.36 	81.12 	86.58 	228 	0.92 	13.93 	201 	38 	10.2 	31.45 	0 	718.75 	0 	1.79 	1 	107 	2.96
######## 	174 	244 	10 	26 	118.56 	87.36 	81.12 	81.9 	228 	0.8 	13.85 	201 	39 	10.2 	31.45 	0 	718.75 	0 	1.79 	1 	107 	2.96
######## 	175 	252 	9 	26 	118.56 	87.36 	81.12 	77.22 	228 	0.66 	13.93 	201 	54 	17.25 	56.61 	9.8 	812.5 	0 	3.33 	2 	107 	2.96
######## 	175 	124 	15 	26 	118.56 	87.36 	81.12 	70.2 	228 	0.66 	13.93 	201 	54 	21.96 	157.25 	0 	1531.25 	0 	3.84 	6 	107 	2.96
######## 	174 	124 	26 	26 	118.56 	87.36 	81.12 	80.34 	228 	0.14 	13.93 	201 	54 	21.96 	182.41 	0 	1906.25 	0 	3.58 	7 	106 	2.96
######## 	175 	120 	29 	26 	118.56 	87.36 	81.12 	99.84 	228 	0.1 	13.93 	201 	54 	22.35 	194.99 	0 	1875 	0 	4.1 	8 	106 	2.96
######## 	175 	124 	26 	26 	118.56 	87.36 	81.12 	118.56 	228 	0.08 	13.85 	201 	54 	22.35 	194.99 	0 	1750 	0 	4.35 	8 	106 	2.96
######## 	173 	124 	25 	26 	118.56 	87.36 	81.12 	120.12 	228 	0.88 	13.85 	201 	48 	22.35 	207.57 	0 	1812.5 	0 	4.1 	7 	106 	2.96
######## 	174 	116 	26 	26 	118.56 	87.36 	81.12 	105.3 	228 	0.9 	13.85 	201 	50 	21.96 	201.28 	0 	1812.5 	0 	4.1 	7 	106 	2.96
######## 	175 	120 	26 	26 	118.56 	87.36 	81.12 	91.26 	228 	0.88 	13.85 	201 	39 	18.43 	157.25 	0 	1656.25 	0 	3.33 	5 	106 	2.96
######## 	167 	112 	27 	26 	118.56 	87.36 	81.12 	79.56 	228 	0.92 	13.85 	201 	39 	18.04 	144.67 	0 	1750 	0 	2.82 	5 	106 	2.96
######## 	174 	116 	30 	26 	118.56 	87.36 	81.12 	65.52 	228 	0.9 	13.85 	201 	39 	16.86 	125.8 	0 	1812.5 	0 	2.3 	4 	106 	2.96
######## 	174 	116 	27 	26 	118.56 	87.36 	81.12 	51.48 	228 	0.7 	13.85 	201 	39 	16.86 	113.22 	0 	1843.75 	0 	2.3 	4 	106 	2.96
######## 	174 	112 	28 	26 	118.56 	87.36 	81.12 	53.82 	228 	0.16 	13.85 	201 	39 	18.82 	125.8 	0 	1875 	0 	2.56 	5 	106 	2.96
######## 	174 	116 	29 	26 	118.56 	87.36 	81.12 	71.76 	228 	0.1 	13.85 	201 	39 	19.22 	138.38 	0 	1906.25 	0 	2.82 	5 	106 	2.96
######## 	175 	124 	29 	25 	118.56 	87.36 	81.12 	90.48 	228 	0.08 	13.85 	201 	39 	20 	157.25 	0 	1968.75 	0 	3.07 	6 	105 	2.96
######## 	174 	116 	33 	25 	118.56 	87.36 	81.12 	109.98 	228 	0.25 	13.85 	201 	39 	20.39 	163.54 	0 	2093.75 	0 	3.07 	6 	105 	2.96
######## 	175 	116 	33 	25 	118.56 	87.36 	81.12 	100.62 	228 	0.82 	13.85 	201 	39 	20.39 	169.83 	0 	2187.5 	0 	3.07 	7 	105 	2.96
######## 	175 	116 	33 	25 	118.56 	87.36 	81.12 	85.02 	228 	0.43 	13.85 	201 	39 	20.39 	169.83 	0 	2281.25 	0 	2.82 	6 	105 	2.96
######## 	175 	112 	34 	25 	118.56 	87.36 	81.12 	109.2 	228 	0.41 	13.85 	201 	39 	20.39 	169.83 	0 	2343.75 	0 	2.82 	7 	105 	2.96
######## 	170 	112 	34 	25 	118.56 	87.36 	81.12 	96.72 	228 	0.84 	13.85 	201 	39 	21.18 	176.12 	0 	2468.75 	0 	2.82 	7 	105 	2.96
######## 	174 	116 	34 	25 	118.56 	87.36 	81.12 	93.6 	228 	0.2 	13.85 	201 	39 	20.78 	176.12 	0 	2531.25 	0 	2.82 	7 	105 	2.96
######## 	175 	116 	34 	25 	118.56 	87.36 	81.12 	99.84 	228 	0.86 	13.85 	201 	39 	20.78 	176.12 	0 	2625 	0 	2.56 	7 	105 	2.96
######## 	175 	116 	35 	25 	118.56 	87.36 	81.12 	82.68 	228 	0.64 	13.85 	201 	39 	20.39 	169.83 	0 	2687.5 	0 	2.56 	7 	105 	2.96
######## 	166 	116 	35 	25 	118.56 	87.36 	81.12 	92.82 	228 	0.2 	13.85 	201 	39 	17.65 	138.38 	0 	2718.75 	0 	2.05 	5 	105 	2.96
######## 	175 	112 	37 	25 	118.56 	87.36 	81.12 	81.12 	228 	0.76 	13.85 	201 	39 	16.47 	100.64 	0 	2718.75 	0 	1.79 	5 	105 	2.96
######## 	175 	116 	39 	25 	118.56 	87.36 	81.12 	93.6 	228 	0.14 	13.85 	201 	39 	16.47 	100.64 	0 	2656.25 	0 	1.79 	5 	105 	2.96
######## 	174 	116 	38 	25 	118.56 	87.36 	81.12 	102.18 	228 	0.92 	13.85 	201 	39 	16.86 	106.93 	0 	2687.5 	0 	1.79 	5 	105 	2.96
######## 	174 	112 	37 	25 	118.56 	87.36 	81.12 	84.24 	228 	0.9 	13.85 	201 	39 	17.65 	113.22 	0 	2593.75 	0 	1.79 	4 	105 	2.96
######## 	175 	112 	37 	25 	118.56 	87.36 	81.12 	84.24 	228 	0.14 	13.85 	201 	39 	18.82 	125.8 	0 	2656.25 	0 	2.05 	5 	105 	2.96
######## 	175 	116 	36 	25 	118.56 	87.36 	81.12 	106.86 	228 	0.1 	13.85 	201 	39 	19.22 	138.38 	0 	2625 	0 	2.56 	7 	105 	2.96
######## 	174 	116 	35 	25 	118.56 	87.36 	81.12 	116.22 	228 	0.84 	13.85 	201 	39 	20.39 	157.25 	0 	2656.25 	0 	2.56 	7 	105 	2.96
######## 	166 	116 	35 	25 	118.56 	87.36 	81.12 	101.4 	228 	0.33 	13.85 	201 	39 	20.39 	157.25 	0 	2718.75 	0 	2.56 	7 	105 	2.96
######## 	175 	116 	35 	25 	118.56 	87.36 	81.12 	109.98 	228 	0.9 	13.85 	201 	39 	20.39 	163.54 	0 	2718.75 	0 	2.56 	7 	104 	2.96
######## 	174 	112 	35 	25 	118.56 	87.36 	81.12 	92.04 	228 	0.66 	13.85 	201 	39 	20.39 	163.54 	0 	2750 	0 	2.56 	7 	104 	2.96
######## 	175 	116 	35 	25 	118.56 	87.36 	81.12 	106.08 	228 	0.53 	13.85 	201 	39 	19.61 	150.96 	0 	2750 	0 	2.3 	6 	104 	2.96
######## 	175 	116 	36 	25 	118.56 	87.36 	81.12 	89.7 	228 	0.88 	13.85 	201 	39 	19.22 	144.67 	0 	2718.75 	0 	2.05 	5 	104 	2.96
######## 	175 	116 	35 	25 	118.56 	87.36 	81.12 	87.36 	228 	0.14 	13.85 	201 	39 	19.22 	144.67 	0 	2718.75 	0 	2.3 	6 	104 	2.96
######## 	174 	116 	36 	25 	118.56 	87.36 	81.12 	109.98 	228 	0.49 	13.78 	201 	39 	19.22 	144.67 	0 	2687.5 	0 	2.3 	6 	104 	2.96
######## 	175 	116 	35 	25 	118.56 	87.36 	81.12 	96.72 	228 	0.88 	13.78 	201 	39 	19.22 	144.67 	0 	2656.25 	0 	2.3 	6 	104 	2.96
######## 	174 	116 	36 	25 	118.56 	87.36 	81.12 	92.82 	228 	0.16 	13.78 	201 	39 	18.04 	132.09 	0 	2687.5 	0 	2.05 	5 	104 	2.96
######## 	175 	116 	37 	25 	118.56 	87.36 	81.12 	99.06 	228 	0.88 	13.78 	201 	39 	18.04 	119.51 	0 	2625 	0 	2.05 	5 	104 	2.96
######## 	170 	116 	37 	25 	118.56 	87.36 	81.12 	97.5 	228 	0.16 	13.85 	201 	39 	18.04 	119.51 	0 	2625 	0 	2.05 	5 	104 	2.96
######## 	175 	116 	37 	25 	118.56 	87.36 	81.12 	106.08 	228 	0.86 	13.78 	201 	39 	18.04 	119.51 	0 	2625 	0 	2.05 	5 	104 	2.96
######## 	174 	112 	37 	25 	118.56 	87.36 	81.12 	88.92 	228 	0.37 	13.78 	201 	39 	17.65 	119.51 	0 	2593.75 	0 	2.05 	5 	104 	2.96
######## 	174 	116 	37 	25 	118.56 	87.36 	81.12 	109.98 	228 	0.41 	13.78 	201 	39 	17.25 	113.22 	0 	2562.5 	0 	1.79 	4 	104 	2.96
######## 	175 	116 	37 	25 	118.56 	87.36 	81.12 	99.06 	228 	0.76 	13.78 	201 	39 	17.25 	113.22 	0 	2531.25 	0 	1.79 	4 	104 	2.96
######## 	175 	116 	37 	25 	118.56 	87.36 	81.12 	103.74 	228 	0.12 	13.78 	201 	39 	17.25 	106.93 	0 	2343.75 	0 	2.05 	5 	104 	2.96
######## 	175 	116 	37 	25 	118.56 	87.36 	81.12 	114.66 	228 	0.88 	13.78 	201 	39 	17.65 	113.22 	0 	2500 	0 	2.05 	5 	104 	2.96
######## 	175 	116 	37 	25 	118.56 	87.36 	81.12 	99.06 	228 	0.68 	13.78 	201 	39 	17.65 	119.51 	0 	2437.5 	0 	2.05 	5 	104 	2.96
######## 	174 	116 	37 	25 	118.56 	87.36 	81.12 	106.08 	228 	0.16 	13.78 	201 	39 	17.65 	119.51 	0 	2406.25 	0 	2.05 	5 	104 	2.96
######## 	173 	112 	36 	25 	118.56 	87.36 	81.12 	104.52 	228
######## 		117.78 	87.36 	81.12 	104.52 	228 	0.76 	14 	201 	42 	18.43 	125.8 	0 	3187.5 	0 	1.79 	6 	119 	2.94
######## 	175 	116 	39 	28 	117.78 	87.36 	81.12 	102.96 	228 	0.06 	14 	201 	42 	18.43 	125.8 	0 	3218.75 	0 	1.79 	6 	119 	2.94
######## 	175 	116 	39 	28 	117.78 	87.36 	81.12 	102.18 	228 	0.72 	14 	201 	42 	18.43 	125.8 	0 	3218.75 	0 	1.79 	6 	119 	2.94
######## 	167 	116 	39 	28 	117.78 	87.36 	81.12 	117.78 	228 	0.76 	14 	201 	42 	18.43 	125.8 	0 	3218.75 	0 	1.79 	6 	119 	2.94
######## 	175 	116 	39 	28 	117.78 	87.36 	81.12 	99.06 	228 	0.2 	14 	201 	42 	18.43 	125.8 	0 	3187.5 	0 	1.79 	6 	119 	2.94
######## 	175 	116 	39 	28 	117.78 	87.36 	81.12 	101.4 	228 	0.84 	14 	201 	42 	18.82 	132.09 	0 	3187.5 	0 	1.79 	6 	119 	2.94
######## 	174 	112 	38 	28 	117.78 	87.36 	81.12 	109.2 	228 	0.06 	13.93 	201 	42 	20.39 	150.96 	0 	3187.5 	0 	2.3 	7 	119 	2.94
######## 	174 	112 	37 	28 	117.78 	87.36 	81.12 	127.14 	228 	0.78 	14 	201 	42 	21.18 	163.54 	0 	3218.75 	0 	2.3 	7 	119 	2.94
######## 	175 	116 	36 	28 	117.78 	87.36 	81.12 	126.36 	228 	0.12 	14 	201 	42 	21.57 	176.12 	0 	3281.25 	0 	2.3 	8 	119 	2.94
######## 	174 	116 	36 	28 	117.78 	87.36 	81.12 	113.88 	228 	0.7 	13.93 	201 	42 	21.57 	176.12 	0 	3281.25 	0 	2.3 	8 	119 	2.94
######## 	174 	116 	35 	28 	117.78 	87.36 	81.12 	120.9 	228 	0.16 	13.93 	201 	42 	22.35 	188.7 	0 	3281.25 	0 	2.56 	8 	119 	2.94
######## 	171 	116 	35 	28 	117.78 	87.36 	81.12 	123.24 	228 	0.08 	13.93 	201 	69 	47.84 	484.33 	0 	3406.25 	0 	7.17 	26 	120 	2.94
######## 	171 	116 	26 	28 	117.78 	87.36 	81.12 	99.84 	228 	0.94 	13.93 	201 	79 	48.63 	710.77 	0 	3500 	0 	10.75 	40 	121 	2.94
######## 	165 	116 	21 	28 	117.78 	87.36 	81.12 	99.84 	228 	0.96 	13.85 	201 	79 	48.63 	1000.11 	0 	3625 	0 	15.36 	59 	123 	2.94
######## 	173 	116 	18 	28 	117.78 	87.36 	81.12 	99.84 	228 	0.96 	13.78 	201 	79 	48.63 	1188.81 	0 	3875 	0 	16.38 	67 	125 	2.94
######## 	165 	116 	17 	28 	117.78 	87.36 	81.12 	99.84 	228 	0.96 	13.78 	201 	79 	48.63 	1213.97 	0 	4062.5 	1 	16.38 	71 	126 	2.94
######## 	163 	116 	18 	28 	117.78 	87.36 	81.12 	99.84 	228 	0.96 	13.78 	202 	79 	48.63 	1276.87 	0 	4250 	0 	16.38 	74 	127 	2.94
######## 	164 	116 	19 	28 	117.78 	87.36 	81.12 	99.84 	228 	0.96 	13.78 	201 	70 	32.55 	918.34 	0 	4375 	0 	4.1 	19 	127 	2.94
######## 	174 	116 	39 	28 	117.78 	87.36 	81.12 	99.84 	228 	0.84 	14 	201 	42 	10.2 	119.51 	0 	4375 	0 	1.28 	5 	127 	2.94
######## 	175 	244 	43 	28 	117.78 	87.36 	81.12 	99.84 	228 	0.72 	14 	201 	42 	10.2 	31.45 	0 	4281.25 	0 	0 	0 	127 	2.94
######## 	175 	244 	43 	28 	117.78 	87.36 	81.12 	99.84 	228 	0.29 	14 	201 	42 	10.2 	44.03 	0 	4218.75 	0 	0 	0 	128 	2.94
######## 	175 	244 	42 	28 	117.78 	87.36 	81.12 	99.84 	228 	0 	14 	201 	42 	10.2 	50.32 	0 	4187.5 	0 	0 	0 	128 	2.94
######## 	174 	244 	42 	28 	117.78 	87.36 	81.12 	99.84 	228 	0 	14 	201 	42 	10.2 	50.32 	0 	4125 	0 	0 	0 	128 	2.94
######## 	174 	244 	42 	28 	117.78 	87.36 	81.12 	99.84 	228 	0 	14 	201 	42 	10.2 	44.03 	0 	4062.5 	0 	0 	0 	129 	2.94
######## 	174 	244 	41 	28 	117.78 	87.36 	81.12 	99.84 	228 	0 	14 	201 	42 	10.2 	44.03 	0 	4000 	0 	0 	0 	129 	2.94
######## 	175 	244 	41 	28 	117.78 	87.36 	81.12 	99.84 	228 	0 	14 	201 	42 	10.2 	44.03 	0 	3906.25 	0 	0 	0 	129 	2.94
######## 	174 	244 	41 	28 	117.78 	87.36 	81.12 	99.84 	228 	0 	14 	201 	42 	10.2 	44.03 	0 	3781.25 	0 	0 	0 	129 	2.94
######## 	175 	240 	40 	28 	117.78 	87.36 	81.12 	99.84 	228 	0 	14 	201 	42 	10.2 	37.74 	0 	3656.25 	0 	0 	0 	129 	2.94
######## 	175 	240 	40 	28 	117.78 	87.36 	81.12 	99.84 	228 	0 	14 	201 	42 	10.2 	37.74 	0 	3531.25 	0 	0 	0 	129 	2.94
######## 	174 	244 	40 	28 	117.78 	87.36 	81.12 	99.84 	228 	0 	14 	201 	42 	10.2 	37.74 	0 	3437.5 	0 	0 	0 	129 	2.94
######## 	175 	244 	40 	28 	117.78 	87.36 	81.12 	99.84 	228 	0 	14 	201 	42 	10.2 	37.74 	0 	3375 	0 	0 	0 	129 	2.94
######## 	175 	244 	40 	28 	117.78 	87.36 	81.12 	99.84 	228 	0 	14 	201 	27 	10.2 	31.45 	0 	3250 	0 	0 	0 	129 	2.94
######## 	175 	244 	39 	28 	117.78 	87.36 	81.12 	99.84 	228 	0 	14.15 	201 	27 	10.2 	37.74 	0 	3187.5 	0 	0 	0 	129 	2.94
######## 	175 	244 	39 	28 	117.78 	87.36 	81.12 	99.84 	228 	0 	14.07 	201 	12 	13.73 	56.61 	0 	3125 	0 	0 	0 	129 	2.94
######## 	174 	116 	39 	28 	117.78 	87.36 	81.12 	99.84 	228 	0 	14 	201 	13 	23.53 	182.41 	0 	3031.25 	0 	2.56 	8 	128 	2.94
######## 	174 	116 	35 	28 	117.78 	87.36 	81.12 	99.84 	228 	0.02 	14 	201 	13 	23.53 	201.28 	0 	3062.5 	0 	2.82 	9 	128 	2.94
######## 	174 	112 	34 	28 	117.78 	87.36 	81.12 	99.84 	228 	0.02 	14 	201 	14 	23.92 	207.57 	0 	3031.25 	0 	2.82 	9 	127 	2.94
######## 	166 	116 	34 	28 	117.78 	87.36 	81.12 	99.84 	228 	0.04 	14 	201 	13 	22.75 	207.57 	0 	3031.25 	0 	2.56 	8 	127 	2.94
######## 	175 	116 	35 	28 	117.78 	87.36 	81.12 	99.84 	228 	0.7 	14 	201 	12 	18.82 	125.8 	0 	3000 	0 	1.79 	5 	126 	2.94
######## 	175 	116 	38 	28 	117.78 	87.36 	81.12 	85.02 	228 	0.86 	14 	201 	20 	28.63 	251.6 	0.78 	2968.75 	0 	3.84 	12 	126 	2.94
######## 	174 	116 	33 	28 	117.78 	87.36 	81.12 	106.08 	228 	0.02 	14 	201 	29 	39.61 	408.85 	2.35 	3031.25 	0 	6.4 	20 	126 	2.94
######## 	174 	116 	26 	28 	117.78 	87.36 	81.12 	115.44 	228 	0.25 	14 	201 	46 	45.88 	578.68 	0 	3062.5 	0 	7.94 	25 	127 	2.94
######## 	171 	116 	22 	28 	117.78 	87.36 	81.12 	99.84 	228 	0.96 	13.93 	201 	46 	45.49 	742.22 	0 	3187.5 	0 	12.29 	41 	128 	2.94
######## 	170 	116 	19 	28 	117.78 	87.36 	81.12 	99.84 	228 	0.96 	13.93 	201 	45 	45.1 	912.05 	0 	3312.5 	0 	14.85 	52 	129 	2.94
######## 	164 	112 	18 	28 	117.78 	87.36 	81.12 	99.84 	228 	0.96 	13.85 	201 	42 	43.14 	1006.4 	0 	3500 	0 	15.1 	56 	129 	2.94
######## 	165 	112 	18 	28 	117.78 	87.36 	81.12 	99.84 	228 	0.97 	14 	201 	29 	20.78 	415.14 	0 	3531.25 	0 	2.3 	8 	130 	2.94
######## 	173 	116 	40 	28 	117.78 	87.36 	81.12 	75.66 	228 	0.88 	14 	201 	12 	10.59 	100.64 	0 	3468.75 	0 	1.28 	4 	129 	2.94
######## 	170 	116 	40 	28 	117.78 	87.36 	81.12 	99.84 	228 	0.74 	14.07 	201 	12 	11.37 	56.61 	0.39 	3468.75 	0 	1.28 	4 	129 	2.94
######## 	167 	244 	40 	28 	117.78 	87.36 	81.12 	99.84 	228 	0.72 	14.07 	201 	12 	10.2 	31.45 	0 	3406.25 	0 	1.28 	4 	129 	2.94
######## 	174 	244 	40 	28 	117.78 	87.36 	81.12 	99.84 	228 	0.78 	14.07 	201 	12 	10.2 	25.16 	0 	3375 	0 	0 	0 	130 	2.94
######## 	175 	244 	40 	28 	117.78 	87.36 	81.12 	99.84 	228 	0.78 	14.07 	201 	12 	10.2 	25.16 	0 	3343.75 	0 	0 	0 	130 	2.94
######## 	174 	244 	40 	28 	117.78 	87.36 	81.12 	99.84 	228 	0.02 	14.07 	201 	12 	10.2 	25.16 	0 	3281.25 	0 	0 	0 	130 	2.94
######## 	174 	244 	40 	28 	117.78 	87.36 	81.12 	99.84 	228 	0 	14.07 	201 	12 	10.2 	31.45 	0 	3218.75 	0 	0 	0 	130 	2.94
######## 	175 	244 	39 	28 	117.78 	87.36 	81.12 	99.84 	228 	0 	14.07 	201 	12 	10.2 	25.16 	0 	3187.5 	0 	0 	0 	130 	2.94
######## 	174 	244 	39 	28 	117.78 	87.36 	81.12 	99.84 	228 	0 	14.07 	201 	12 	10.2 	31.45 	0 	3156.25 	0 	1.28 	4 	130 	2.94
######## 	175 	116 	39 	28 	117.78 	87.36 	81.12 	99.84 	228 	0.02 	14.07 	201 	12 	11.37 	31.45 	0 	3156.25 	0 	1.28 	4 	130 	2.94
######## 	172 	112 	39 	28 	117.78 	87.36 	81.12 	99.84 	228 	0.31 	14.07 	201 	12 	12.16 	44.03 	0 	3062.5 	0 	1.28 	4 	131 	2.94
######## 	174 	116 	39 	28 	117.78 	87.36 	81.12 	99.84 	228 	0.92 	14.07 	201 	12 	16.86 	81.77 	0 	3031.25 	0 	1.54 	4 	131 	2.94
######## 	175 	116 	39 	28 	117.78 	87.36 	81.12 	99.84 	228 	0.74 	14 	201 	12 	20.39 	138.38 	0 	3031.25 	0 	2.05 	6 	130 	2.94
######## 	174 	116 	37 	28 	117.78 	87.36 	81.12 	90.48 	228 	0.29 	14 	201 	12 	20.78 	144.67 	0 	3000 	0 	2.05 	6 	130 	2.94
######## 	175 	116 	37 	28 	117.78 	87.36 	81.12 	117 	228 	0.33 	14 	201 	12 	20.78 	144.67 	0 	3000 	0 	2.05 	6 	129 	2.94
######## 	175 	116 	39 	28 	117.78 	87.36 	81.12 	102.96 	228 	0.9 	14 	201 	12 	17.65 	100.64 	0 	3000 	0 	1.54 	4 	129 	2.94
######## 	174 	112 	39 	28 	117.78 	87.36 	81.12 	102.96 	228 	0.21 	14 	201 	12 	17.65 	100.64 	0 	3000 	0 	1.54 	4 	129 	2.94
######## 	175 	112 	39 	28 	117.78 	87.36 	81.12 	92.04 	228 	0.51 	14 	201 	12 	18.04 	100.64 	0 	2968.75 	0 	1.79 	5 	129 	2.94
######## 	175 	112 	39 	28 	117.78 	87.36 	81.12 	113.1 	228 	0.16 	14 	201 	12 	22.35 	150.96 	0 	3031.25 	0 	2.56 	8 	129 	2.94
######## 	174 	116 	35 	28 	117.78 	87.36 	81.12 	121.68 	228 	0.06 	14 	201 	13 	23.14 	188.7 	0 	3000 	0 	2.82 	9 	128 	2.94
######## 	174 	116 	35 	28 	117.78 	87.36 	81.12 	140.4 	228 	0.88 	14 	201 	13 	23.53 	201.28 	0 	3031.25 	0 	2.82 	9 	128 	2.94
######## 	175 	116 	35 	28 	117.78 	87.36 	81.12 	117.78 	228 	0.8 	14 	201 	13 	23.53 	201.28 	0 	3031.25 	0 	2.82 	9 	128 	2.94
######## 	173 	112 	34 	28 	117.78 	87.36 	81.12 	122.46 	228 	0.47 	14 	201 	13 	23.53 	201.28 	0 	3062.5 	0 	2.82 	9 	128 	2.94
######## 	175 	112 	34 	28 	117.78 	87.36 	81.12 	104.52 	228 	0.76 	14 	201 	13 	23.53 	207.57 	0 	3093.75 	0 	2.82 	9 	128 	2.94
######## 	170 	116 	34 	28 	117.78 	87.36 	81.12 	123.24 	228 	0.76 	14 	201 	13 	22.75 	201.28 	0 	3125 	0 	2.56 	8 	128 	2.94
######## 	175 	116 	37 	28 	117.78 	87.36 	81.12 	100.62 	228 	0.94 	14.07 	201 	12 	17.25 	106.93 	0 	3062.5 	0 	1.54 	5 	128 	2.94
######## 	173 	112 	39 	28 	117.78 	87.36 	81.12 	78.78 	228 	0.9 	14 	201 	12 	17.25 	100.64 	0 	3093.75 	0 	1.54 	5 	128 	2.94
######## 	171 	116 	39 	28 	117.78 	87.36 	81.12 	81.12 	228 	0.06 	14 	201 	12 	18.43 	113.22 	0 	3062.5 	0 	1.79 	5 	128 	2.94
######## 	174 	116 	39 	28 	117.78 	87.36 	81.12 	99.06 	228 	0.88 	14.07 	201 	12 	19.22 	119.51 	0 	3031.25 	0 	1.79 	5 	128 	2.94
######## 	174 	116 	38 	28 	117.78 	87.36 	81.12 	95.16 	228 	0.04 	14 	201 	12 	21.96 	150.96 	0 	3031.25 	0 	2.82 	9 	128 	2.94
######## 	174 	116 	32 	28 	117.78 	87.36 	81.12 	126.36 	228 	0.02 	14 	201 	45 	45.88 	478.04 	0 	3093.75 	0 	7.17 	23 	128 	2.94
######## 	171 	116 	25 	28 	117.78 	87.36 	81.12 	136.5 	228 	0.9 	14 	201 	46 	46.27 	622.71 	0 	3187.5 	0 	9.98 	34 	129 	2.94
######## 	174 	112 	22 	28 	117.78 	87.36 	81.12 	99.84 	228 	0.96 	13.93 	201 	46 	46.27 	811.41 	0 	3312.5 	0 	13.31 	47 	130 	2.94
######## 	167 	116 	18 	28 	117.78 	87.36 	81.12 	99.84 	228 	0.96 	13.85 	201 	46 	45.88 	1025.27 	0 	3500 	0 	15.87 	59 	131 	2.94
######## 	163 	116 	17 	28 	117.78 	87.36 	81.12 	99.84 	228 	0.96 	13.93 	201 	43 	43.53 	1031.56 	0 	3593.75 	0 	15.1 	57 	132 	2.94
######## 	173 	116 	18 	28 	117.78 	87.36 	81.12 	99.84 	228 	0.96 	13.85 	201 	39 	39.22 	949.79 	0 	3687.5 	0 	12.8 	50 	133 	2.94
######## 	171 	116 	21 	28 	117.78 	87.36 	81.12 	99.84 	228 	0.96 	13.93 	201 	26 	21.96 	459.17 	0 	3750 	0 	2.3 	9 	133 	2.94
######## 	175 	112 	41 	28 	117.78 	87.36 	81.12 	78.78 	228 	0.86 	14 	201 	12 	10.2 	94.35 	0 	3687.5 	0 	1.54 	6 	133 	2.94
######## 	174 	244 	41 	28 	117.78 	87.36 	81.12 	99.84 	228 	0.74 	14.07 	201 	12 	10.2 	69.19 	0 	3687.5 	0 	0 	0 	132 	2.94
######## 	174 	240 	40 	28 	117.78 	87.36 	81.12 	99.84 	228 	0.8 	14.07 	201 	12 	10.2 	37.74 	0 	3593.75 	0 	0 	0 	133 	2.94
######## 	175 	240 	40 	28 	117.78 	87.36 	81.12 	99.84 	228 	0.1 	14.07 	201 	12 	10.2 	25.16 	0 	3562.5 	0 	0 	0 	133 	2.94
######## 	174 	244 	40 	28 	117.78 	87.36 	81.12 	99.84 	228 	0 	14.07 	201 	12 	10.2 	25.16 	0 	3500 	0 	0 	0 	133 	2.94
######## 	175 	244 	40 	28 	117.78 	87.36 	81.12 	99.84 	228 	0 	14 	201 	12 	10.2 	25.16 	0 	3406.25 	0 	0 	0 	134 	2.94
######## 	175 	244 	40 	28 	117.78 	87.36 	81.12 	99.84 	228 	0 	14.07 	201 	12 	10.2 	31.45 	0 	3312.5 	0 	0 	0 	134 	2.94
######## 	174 	244 	40 	28 	117.78 	87.36 	81.12 	99.84 	228 	0 	14.07 	201 	12 	10.2 	25.16 	0 	3250 	0 	0 	0 	134 	2.94
######## 	174 	240 	39 	28 	117.78 	87.36 	81.12 	99.84 	228 	0 	14.07 	201 	12 	10.2 	25.16 	0 	3218.75 	0 	0 	0 	134 	2.94
######## 	174 	244 	39 	28 	117.78 	87.36 	81.12 	99.84 	228 	0 	14.07 	201 	12 	10.2 	31.45 	0 	3125 	0 	0 	0 	134 	2.94
######## 	175 	244 	39 	28 	117.78 	87.36 	81.12 	99.84 	228 	0 	14.07 	201 	12 	10.2 	31.45 	0 	3062.5 	0 	0 	0 	134 	2.94
######## 	175 	244 	39 	28 	117.78 	87.36 	81.12 	99.84 	228 	0 	14.07 	201 	11 	10.2 	25.16 	0 	2968.75 	0 	0 	0 	134 	2.94
######## 	175 	244 	39 	28 	117.78 	87.36 	81.12 	99.84 	228 	0 	14 	201 	0 	10.2 	18.87 	0 	2906.25 	0 	0 	0 	134 	2.94
######## 	175 	240 	39 	28 	117.78 	87.36 	81.12 	99.84 	228 	0 	14.07 	201 	0 	10.2 	18.87 	0 	2875 	0 	0 	0 	134 	2.94
######## 	174 	112 	39 	28 	117.78 	87.36 	81.12 	99.84 	228 	0 	14.07 	201 	0 	20 	106.93 	0 	2843.75 	0 	2.05 	6 	134 	2.94
######## 	174 	112 	38 	28 	117.78 	87.36 	81.12 	99.84 	228 	0.02 	14 	201 	0 	23.14 	157.25 	0 	2781.25 	0 	2.56 	7 	134 	2.94
######## 	175 	116 	34 	28 	117.78 	87.36 	81.12 	99.84 	228 	0.02 	14 	201 	3 	24.31 	207.57 	0 	2812.5 	0 	3.07 	9 	133 	2.94
######## 	175 	116 	34 	28 	117.78 	87.36 	81.12 	99.84 	228 	0.02 	14.07 	201 	4 	25.1 	226.44 	0 	2812.5 	0 	3.33 	10 	133 	2.94
######## 	175 	116 	34 	28 	117.78 	87.36 	81.12 	99.84 	228 	0.04 	14 	201 	5 	25.49 	245.31 	0 	2781.25 	0 	3.58 	10 	132 	2.94
######## 	175 	116 	33 	28 	117.78 	87.36 	81.12 	113.88 	228 	0.08 	14 	201 	5 	26.27 	264.18 	0 	2812.5 	0 	3.84 	11 	132 	2.94
######## 	175 	112 	33 	28 	117.78 	87.36 	81.12 	109.2 	228 	0.82 	14 	201 	7 	27.06 	289.34 	0 	2843.75 	0 	4.1 	12 	132 	2.94
######## 	174 	116 	32 	28 	117.78 	87.36 	81.12 	112.32 	228 	0.6 	14 	201 	9 	27.84 	320.79 	0 	2875 	0 	4.35 	13 	132 	2.94
######## 	167 	116 	31 	28 	117.78 	87.36 	81.12 	99.06 	228 	0.14 	14 	201 	9 	28.24 	333.37 	0 	2906.25 	0 	4.61 	14 	133 	2.94
######## 	174 	116 	30 	28 	117.78 	87.36 	81.12 	95.16 	228 	0.72 	14 	201 	9 	28.24 	345.95 	0 	2937.5 	0 	4.86 	15 	133 	2.94
######## 	175 	116 	31 	28 	117.78 	87.36 	81.12 	94.38 	228 	0.76 	14 	201 	9 	27.84 	352.24 	0 	2968.75 	0 	4.61 	14 	133 	2.94
######## 	171 	116 	32 	28 	117.78 	87.36 	81.12 	89.7 	228 	0.86 	14 	201 	3 	24.71 	264.18 	0 	2968.75 	0 	3.33 	10 	133 	2.94
######## 	173 	112 	33 	28 	117.78 	87.36 	81.12 	84.24 	228 	0.06 	14 	201 	0 	21.96 	220.15 	0 	2968.75 	0 	2.56 	8 	133 	2.94
######## 	175 	112 	35 	28 	117.78 	87.36 	81.12 	81.9 	228 	0.86 	14.07 	201 	0 	20.39 	157.25 	0 	2968.75 	0 	2.05 	6 	133 	2.94
######## 	174 	116 	36 	28 	117.78 	87.36 	81.12 	61.62 	228 	0.86 	14.07 	201 	0 	20 	144.67 	0 	2937.5 	0 	2.05 	6 	133 	2.94
######## 	174 	116 	37 	28 	117.78 	87.36 	81.12 	63.96 	228 	0.04 	14.07 	201 	0 	20.39 	138.38 	0 	2906.25 	0 	2.05 	6 	132 	2.94
######## 	172 	112 	36 	28 	117.78 	87.36 	81.12 	88.92 	228 	0.02 	14 	201 	3 	24.71 	201.28 	0 	2937.5 	0 	3.07 	9 	132 	2.94
######## 	171 	116 	34 	28 	117.78 	87.36 	81.12 	120.9 	228 	0.08 	14.07 	201 	4 	25.1 	239.02 	0 	2937.5 	0 	3.33 	10 	132 	2.94
######## 	170 	116 	34 	28 	117.78 	87.36 	81.12 	113.1 	228 	0.47 	14.07 	201 	5 	25.49 	251.6 	0 	2937.5 	0 	3.58 	11 	132 	2.94
######## 	175 	112 	33 	28 	117.78 	87.36 	81.12 	113.88 	228 	0.82 	14 	201 	5 	25.49 	264.18 	0 	2968.75 	0 	3.58 	11 	133 	2.94
######## 	175 	116 	33 	28 	117.78 	87.36 	81.12 	96.72 	228 	0.12 	14 	201 	5 	25.88 	264.18 	0 	2968.75 	0 	3.84 	12 	133 	2.94
######## 	167 	116 	33 	28 	117.78 	87.36 	81.12 	106.08 	228 	0.8 	14 	201 	5 	25.88 	270.47 	0 	3000 	0 	3.58 	11 	133 	2.94
######## 	175 	112 	33 	28 	117.78 	87.36 	81.12 	99.06 	228 	0.8 	14.07 	201 	1 	23.53 	220.15 	0 	3000 	0 	2.82 	9 	133 	2.94
######## 	174 	116 	34 	28 	117.78 	87.36 	81.12 	91.26 	228 	0.08 	14 	201 	3 	24.31 	220.15 	0 	3000 	0 	3.33 	10 	133 	2.94
######## 	175 	116 	34 	28 	117.78 	87.36 	81.12 	125.58 	228 	0.41 	14 	201 	7 	27.06 	276.76 	0 	3031.25 	0 	3.84 	12 	133 	2.94
######## 	167 	112 	33 	28 	117.78 	87.36 	81.12 	108.42 	228 	0.84 	14.07 	201 	7 	27.06 	301.92 	0 	3062.5 	0 	3.84 	12 	134 	2.94
######## 	174 	116 	33 	28 	117.78 	87.36 	81.12 	106.08 	228 	0.74 	14.07 	201 	0 	20.78 	213.86 	0 	3062.5 	0 	2.56 	8 	134 	2.94
######## 	175 	112 	36 	28 	117.78 	87.36 	81.12 	84.24 	228 	0.92 	14 	201 	0 	18.82 	132.09 	0 	3062.5 	0 	1.79 	5 	134 	2.94
######## 	174 	112 	39 	28 	117.78 	87.36 	81.12 	63.18 	228 	0.92 	14.07 	201 	0 	16.08 	88.06 	0 	3062.5 	0 	1.28 	4 	134 	2.94
######## 	173 	112 	39 	28 	117.78 	87.36 	81.12 	42.9 	228 	0.9 	14.07 	201 	0 	15.69 	75.48 	0 	3031.25 	0 	1.28 	4 	134 	2.94
######## 	175 	116 	39 	28 	117.78 	87.36 	81.12 	29.64 	228 	0.14 	14.07 	201 	0 	15.69 	75.48 	0 	3000 	0 	1.28 	4 	134 	2.94
######## 	175 	116 	39 	28 	117.78 	87.36 	81.12 	46.02 	228 	0.08 	14.07 	201 	0 	12.94 	56.61 	0 	2968.75 	0 	1.28 	4 	134 	2.94
######## 	174 	116 	39 	28 	117.78 	87.36 	81.12 	99.84 	228 	0.21 	14.07 	201 	0 	12.55 	44.03 	0 	2937.5 	0 	1.28 	4 	134 	2.94
######## 	174 	116 	39 	28 	117.78 	87.36 	81.12 	99.84 	228 	0.78 	14.07 	201 	0 	12.55 	44.03 	0 	2937.5 	0 	1.28 	4 	135 	2.94
######## 	174 	116 	39 	28 	117.78 	87.36 	81.12 	99.84 	228 	0.78 	14.07 	201 	0 	12.55 	44.03 	0 	2875 	0 	1.28 	3 	135 	2.94
######## 	175 	116 	39 	28 	117.78 	87.36 	81.12 	99.84 	228 	0.76 	14.07 	201 	0 	11.76 	37.74 	0 	2843.75 	0 	1.28 	3 	135 	2.94
######## 	173 	112 	39 	28 	117.78 	87.36 	81.12 	99.84 	228 	0.72 	14.07 	201 	0 	10.98 	25.16 	0 	2812.5 	0 	1.28 	3 	135 	2.94
######## 	174 	112 	39 	28 	117.78 	87.36 	81.12 	99.84 	228 	0.72 	14.07 	201 	0 	11.76 	31.45 	0 	2812.5 	0 	1.28 	3 	135 	2.94
######## 	175 	116 	39 	28 	117.78 	87.36 	81.12 	99.84 	228 	0.72 	14.07 	201 	0 	12.94 	44.03 	0 	2781.25 	0 	1.28 	3 	135 	2.94
######## 	166 	116 	39 	28 	117.78 	87.36 	81.12 	99.84 	228 	0.84 	14.07 	201 	0 	13.33 	50.32 	0 	2750 	0 	1.28 	3 	136 	2.94
######## 	174 	116 	39 	28 	117.78 	87.36 	81.12 	99.84 	228 	0.88 	14.07 	201 	0 	13.73 	50.32 	0 	2750 	0 	1.28 	3 	136 	2.94
######## 	174 	116 	38 	28 	117.78 	87.36 	81.12 	99.84 	228 	0.88 	14.07 	201 	0 	14.51 	56.61 	0 	2718.75 	0 	1.28 	3 	136 	2.94
######## 	174 	116 	38 	28 	117.78 	87.36 	81.12 	99.84 	228 	0.88 	14.07 	201 	0 	14.9 	62.9 	0 	2718.75 	0 	1.28 	3 	137 	2.94
######## 	174 	116 	38 	28 	117.78 	87.36 	81.12 	99.84 	228 	0.86 	14.07 	201 	0 	14.9 	62.9 	0 	2718.75 	0 	0 	0 	137 	2.94
######## 	174 	112 	38 	28 	117.78 	87.36 	81.12 	99.84 	228 	0 	14.07 	201 	0 	14.9 	62.9 	0 	2687.5 	0 	0 	0 	138 	2.94
######## 	174 	116 	38 	28 	117.78 	87.36 	81.12 	99.84 	228 	0 	14.07 	201 	0 	15.69 	69.19 	0 	2656.25 	0 	0 	0 	138 	2.94
######## 	174 	116 	38 	28 	117.78 	87.36 	81.12 	99.84 	228 	0 	14.07 	201 	0 	20.39 	119.51 	0 	2687.5 	0 	2.05 	5 	137 	2.94
######## 	175 	116 	36 	28 	117.78 	87.36 	81.12 	99.84 	228 	0.02 	14.07 	201 	0 	22.35 	163.54 	0 	2687.5 	0 	2.82 	8 	137 	2.94
######## 	167 	116 	34 	28 	117.78 	87.36 	81.12 	99.84 	228 	0.02 	14.07 	201 	3 	25.1 	213.86 	0 	2718.75 	0 	3.33 	9 	136 	2.94
######## 	174 	116 	33 	28 	117.78 	87.36 	81.12 	99.84 	228 	0.02 	14 	201 	4 	25.1 	232.73 	0 	2750 	0 	3.58 	10 	136 	2.94
######## 	175 	116 	33 	28 	117.78 	87.36 	81.12 	99.84 	228 	0.04 	14 	201 	4 	25.1 	245.31 	0 	2781.25 	4 	3.58 	10 	135 	2.94
######## 	174 	112 	34 	28 	117.78 	87.36 	81.12 	113.88 	228 	0.86 	14.07 	201 	0 	22.35 	201.28 	0 	2843.75 	0 	2.82 	8 	135 	2.94
######## 	166 	116 	35 	28 	117.78 	87.36 	81.12 	92.82 	228 	0.72 	14.07 	201 	0 	21.18 	163.54 	0 	2875 	0 	2.56 	7 	135 	2.94
######## 	174 	112 	35 	28 	117.78 	87.36 	81.12 	92.82 	228 	0.84 	14.07 	201 	0 	21.18 	157.25 	0 	2906.25 	0 	2.3 	7 	135 	2.94
######## 	174 	116 	36 	28 	117.78 	87.36 	81.12 	83.46 	228 	0.08 	14.07 	201 	0 	21.57 	157.25 	0 	2937.5 	0 	2.56 	8 	134 	2.94
######## 	175 	116 	34 	28 	117.78 	87.36 	81.12 	112.32 	228 	0.04 	14.07 	201 	5 	25.49 	245.31 	0 	2968.75 	0 	3.58 	11 	134 	2.94
######## 	175 	116 	33 	28 	117.78 	87.36 	81.12 	126.36 	228 	0.84 	14.07 	201 	6 	26.27 	270.47 	0 	3000 	0 	3.84 	12 	134 	2.94
######## 	174 	116 	33 	28 	117.78 	87.36 	81.12 	102.96 	228 	0.64 	14 	201 	7 	26.67 	283.05 	0 	3062.5 	0 	3.84 	12 	134 	2.94
######## 	174 	116 	33 	28 	117.78 	87.36 	81.12 	105.3 	228 	0.82 	14 	201 	7 	26.67 	295.63 	0 	3093.75 	0 	3.84 	12 	135 	2.94
######## 	175 	112 	33 	28 	117.78 	87.36 	81.12 	100.62 	228 	0.12 	14 	201 	5 	25.1 	276.76 	0 	3156.25 	0 	3.33 	11 	135 	2.94
######## 	174 	116 	34 	28 	117.78 	87.36 	81.12 	92.82 	228 	0.9 	14.07 	201 	0 	21.57 	182.41 	0 	3218.75 	0 	2.3 	7 	135 	2.94
######## 	174 	112 	35 	28 	117.78 	87.36 	81.12 	82.68 	228 	0.08 	14.07 	201 	0 	17.25 	119.51 	0 	3156.25 	0 	1.54 	5 	134 	2.94
######## 	170 	116 	39 	28 	117.78 	87.36 	81.12 	69.42 	228 	0.9 	14.07 	201 	0 	14.12 	75.48 	0 	3156.25 	0 	1.28 	4 	135 	2.94
######## 	174 	112 	39 	28 	117.78 	87.36 	81.12 	99.84 	228 	0.82 	14.07 	201 	0 	10.2 	31.45 	0 	2968.75 	0 	1.28 	4 	135 	2.94
######## 	174 	244 	39 	28 	117.78 	87.36 	81.12 	99.84 	228 	0.74 	14.15 	201 	0 	10.2 	18.87 	0 	2406.25 	0 	0 	0 	136 	2.94
######## 	175 	244 	38 	28 	117.78 	87.36 	81.12 	99.84 	228 	0.82 	14.07 	201 	0 	10.2 	25.16 	0 	1906.25 	0 	0 	0 	136 	2.94
######## 	175 	244 	36 	28 	117.78 	87.36 	81.12 	99.84 	228 	0.41 	14.07 	201 	0 	10.2 	18.87 	0 	1406.25 	0 	0 	0 	136 	2.94
######## 	175 	244 	24 	28 	117.78 	87.36 	81.12 	99.84 	228 	0 	14.07 	201 	0 	10.2 	18.87 	0 	968.75 	0 	1.28 	1 	137 	2.94
######## 	174 	244 	17 	28 	117.78 	87.36 	81.12 	99.84 	228 	0 	14 	201 	0 	10.2 	12.58 	0 	656.25 	0 	1.28 	0 	137 	2.94
######## 	175 	244 	18 	28 	117.78 	87.36 	81.12 	99.84 	228 	0.02 	12.61 	201 	15 	10.2 	12.58 	0 	343.75 	0 	2.05 	0 	137 	2.94
######## 	174 	240 	5 	28 	117.78 	87.36 	81.12 	99.84 	228 	0.02 	12.46 	201 	34 	10.2 	12.58 	0 	218.75 	0 	3.07 	0 	137 	2.94
######## 	174 	244 	5 	28 	117.78 	87.36 	81.12 	99.84 	228 	0.02 	12.46 	201 	34 	10.2 	18.87 	0 	218.75 	0 	3.84 	0 	137 	2.94
######## 	175 	240 	5 	28 	117.78 	87.36 	81.12 	99.84 	228 	0.6 	12.39 	201 	34 	10.2 	44.03 	0 	531.25 	0 	3.07 	1 	137 	2.94
######## 	174 	240 	13 	28 	117.78 	87.36 	81.12 	95.94 	228 	0.96 	14 	201 	1 	10.2 	44.03 	0 	937.5 	0 	2.05 	2 	137 	2.94
######## 	175 	244 	8 	28 	117.78 	87.36 	81.12 	89.7 	228 	0.94 	14 	201 	0 	10.2 	37.74 	0 	875 	0 	2.05 	1 	137 	2.94
######## 	175 	244 	16 	28 	117.78 	87.36 	81.12 	85.02 	228 	0.94 	12.97 	201 	0 	10.2 	18.87 	0 	468.75 	0 	1.79 	0 	137 	2.94
######## 	175 	240 	14 	28 	117.78 	87.36 	81.12 	81.9 	228 	0.92 	12.31 	201 	34 	10.2 	18.87 	0 	375 	0 	2.05 	0 	137 	2.94
######## 	175 	244 	5 	28 	117.78 	87.36 	81.12 	78.78 	228 	0.94 	12.39 	201 	14 	10.2 	25.16 	0 	468.75 	0 	2.3 	1 	137 	2.94
######## 	175 	244 	5 	28 	117.78 	87.36 	81.12 	74.88 	228 	0.94 	12.83 	201 	14 	10.2 	25.16 	0 	593.75 	0 	1.79 	1 	137 	2.94
######## 	175 	244 	16 	28 	117.78 	87.36 	81.12 	73.32 	228 	0.92 	12.9 	201 	22 	10.2 	18.87 	0 	562.5 	0 	1.79 	1 	137 	2.94
######## 	175 	244 	14 	28 	117.78 	87.36 	81.12 	71.76 	228 	0.72 	12.39 	201 	35 	10.2 	25.16 	0 	468.75 	0 	2.3 	1 	136 	2.94
######## 	173 	244 	12 	28 	117.78 	87.36 	81.12 	72.54 	228 	0.04 	12.68 	201 	35 	10.2 	31.45 	0 	593.75 	0 	2.3 	1 	136 	2.94
######## 	174 	252 	14 	28 	117.78 	87.36 	81.12 	74.1 	228 	0.02 	13.56 	201 	45 	10.2 	31.45 	0 	687.5 	0 	2.05 	1 	136 	2.94
######## 	174 	252 	11 	28 	117.78 	87.36 	81.12 	77.22 	228 	0.02 	13.93 	201 	50 	10.2 	31.45 	0 	718.75 	0 	2.05 	1 	136 	2.94
######## 	174 	252 	7 	28 	117.78 	87.36 	81.12 	78.78 	228 	0.02 	14 	201 	50 	10.2 	31.45 	0 	750 	0 	2.05 	1 	136 	2.94
######## 	174 	248 	6 	28 	117.78 	87.36 	81.12 	81.9 	228 	0.02 	13.93 	201 	50 	10.2 	31.45 	0 	781.25 	0 	2.05 	1 	136 	2.94
######## 	175 	252 	9 	28 	117.78 	87.36 	81.12 	84.24 	228 	0.02 	14 	201 	50 	10.2 	31.45 	0 	750 	0 	2.05 	1 	136 	2.94
######## 	175 	252 	8 	28 	117.78 	87.36 	81.12 	87.36 	228 	0.02 	13.93 	201 	35 	10.2 	31.45 	0 	750 	0 	1.79 	1 	136 	2.94
######## 	166 	252 	8 	28 	117.78 	87.36 	81.12 	89.7 	228 	0.02 	14.07 	201 	45 	10.2 	31.45 	0 	718.75 	0 	2.05 	1 	136 	2.94
######## 	174 	252 	11 	28 	117.78 	87.36 	81.12 	92.04 	228 	0.02 	14 	201 	50 	10.59 	31.45 	0 	750 	0 	2.05 	1 	135 	2.94
######## 	174 	124 	7 	28 	117.78 	87.36 	81.12 	94.38 	228 	0.02 	14 	201 	39 	10.2 	37.74 	0 	812.5 	0 	2.05 	1 	135 	2.94
######## 	175 	240 	6 	28 	117.78 	87.36 	81.12 	97.5 	228 	0.02 	13.71 	201 	35 	10.2 	31.45 	0 	875 	0 	1.79 	1 	135 	2.94
######## 	175 	244 	9 	28 	117.78 	87.36 	81.12 	100.62 	228 	0.02 	14 	201 	35 	10.2 	25.16 	0 	718.75 	0 	1.79 	1 	135 	2.94
######## 	174 	240 	13 	28 	117.78 	87.36 	81.12 	102.96 	228 	0.02 	13.71 	201 	35 	10.2 	25.16 	0 	593.75 	0 	1.79 	1 	135 	2.94
######## 	174 	240 	20 	28 	118.56 	87.36 	81.12 	105.3 	228 	0.02 	14 	201 	151
######## 		0.02 	13.93 	201 	39 	10.2 	25.16 	0 	718.75 	0 	1.79 	1 	135 	2.94
######## 	175 	240 	10 	28 	117.78 	87.36 	81.12 	102.96 	228 	0.02 	13.93 	201 	39 	10.2 	25.16 	0 	718.75 	0 	1.79 	1 	135 	2.96
######## 	174 	244 	11 	28 	118.56 	87.36 	81.12 	105.3 	228 	0.02 	14 	201 	41 	10.2 	31.45 	0 	687.5 	0 	2.05 	1 	135 	2.96
######## 	174 	244 	10 	28 	118.56 	87.36 	81.12 	108.42 	228 	0.02 	13.93 	201 	41 	10.2 	31.45 	0 	718.75 	0 	2.05 	1 	135 	2.96
######## 	174 	244 	7 	28 	118.56 	87.36 	81.12 	110.76 	228 	0.02 	14 	201 	41 	10.2 	31.45 	0 	750 	0 	1.79 	1 	135 	2.96
######## 	174 	244 	7 	28 	118.56 	87.36 	81.12 	113.1 	228 	0.02 	14 	201 	41 	10.2 	31.45 	0 	718.75 	0 	1.79 	1 	135 	2.96
######## 	167 	240 	9 	28 	118.56 	87.36 	81.12 	115.44 	228 	0.02 	14 	201 	42 	10.2 	31.45 	0 	718.75 	0 	2.05 	1 	135 	2.96
######## 	174 	244 	11 	28 	118.56 	87.36 	81.12 	117.78 	228 	0.02 	14 	201 	42 	10.2 	31.45 	0 	750 	0 	2.05 	1 	135 	2.96
######## 	174 	244 	6 	28 	118.56 	87.36 	81.12 	120.12 	228 	0.04 	14 	201 	42 	10.2 	31.45 	0 	750 	0 	2.05 	1 	135 	2.96
######## 	175 	244 	6 	28 	118.56 	87.36 	81.12 	123.24 	228 	0.04 	14 	201 	42 	10.2 	25.16 	0 	718.75 	0 	2.05 	1 	135 	2.96
######## 	175 	240 	9 	28 	118.56 	87.36 	81.12 	125.58 	228 	0.04 	14 	201 	43 	10.2 	31.45 	0 	750 	0 	2.05 	1 	135 	2.96
######## 	174 	244 	6 	28 	118.56 	87.36 	81.12 	127.92 	228 	0.04 	14 	201 	43 	10.2 	31.45 	0 	781.25 	0 	2.05 	1 	135 	2.96
######## 	174 	244 	6 	28 	118.56 	87.36 	81.12 	131.04 	228 	0.04 	14 	201 	42 	10.2 	31.45 	0 	812.5 	0 	1.79 	1 	135 	2.96
######## 	175 	240 	6 	28 	118.56 	87.36 	81.12 	133.38 	228 	0.04 	14 	201 	42 	10.2 	31.45 	0 	781.25 	0 	1.79 	1 	135 	2.96
######## 	175 	252 	8 	28 	118.56 	87.36 	81.12 	135.72 	228 	0.04 	14 	201 	57 	10.2 	31.45 	0 	750 	0 	2.05 	1 	135 	2.96
######## 	174 	124 	7 	28 	118.56 	87.36 	81.12 	138.84 	228 	0.04 	14 	201 	57 	15.29 	56.61 	5.49 	875 	0 	3.07 	2 	135 	2.96
######## 	175 	124 	9 	28 	118.56 	87.36 	81.12 	142.74 	228 	0.04 	14 	201 	57 	21.18 	138.38 	0.39 	1500 	0 	4.35 	6 	135 	2.96
######## 	172 	124 	27 	28 	118.56 	87.36 	81.12 	156.78 	228 	0.16 	14 	201 	57 	21.18 	163.54 	0 	1875 	0 	3.84 	7 	135 	2.96
######## 	174 	120 	30 	28 	118.56 	87.36 	81.12 	148.98 	228 	0.88 	14 	201 	57 	21.18 	169.83 	0 	1843.75 	0 	4.1 	8 	135 	2.96
######## 	175 	120 	29 	28 	118.56 	87.36 	81.12 	135.72 	228 	0.9 	14 	201 	57 	21.18 	176.12 	0 	1843.75 	0 	4.1 	8 	135 	2.96
######## 	175 	124 	27 	28 	118.56 	87.36 	81.12 	120.9 	228 	0.9 	14 	201 	57 	19.22 	163.54 	0 	1750 	0 	3.58 	6 	135 	2.96
######## 	174 	124 	28 	28 	118.56 	87.36 	81.12 	108.42 	228 	0.94 	14 	201 	57 	16.86 	106.93 	0 	1312.5 	0 	3.33 	4 	135 	2.96
######## 	174 	124 	20 	28 	118.56 	87.36 	81.12 	97.5 	228 	0.92 	14 	201 	57 	16.86 	125.8 	0 	1406.25 	0 	3.58 	5 	135 	2.96
######## 	175 	120 	23 	28 	118.56 	87.36 	81.12 	87.36 	228 	0.9 	14 	201 	57 	16.86 	125.8 	0 	1531.25 	0 	3.07 	5 	134 	2.96
######## 	175 	116 	26 	28 	118.56 	87.36 	81.12 	75.66 	228 	0.88 	14 	201 	42 	16.86 	119.51 	0 	1656.25 	0 	2.56 	4 	134 	2.96
######## 	175 	112 	26 	28 	118.56 	87.36 	81.12 	63.18 	228 	0.64 	14 	201 	42 	16.86 	113.22 	0 	1750 	0 	2.56 	4 	134 	2.96
######## 	174 	116 	26 	28 	118.56 	87.36 	81.12 	73.32 	228 	0.08 	14 	201 	42 	17.25 	113.22 	0 	1812.5 	0 	2.56 	4 	134 	2.96
######## 	174 	116 	29 	28 	118.56 	87.36 	81.12 	84.24 	228 	0.62 	14 	201 	42 	17.65 	119.51 	0 	1906.25 	0 	2.56 	5 	134 	2.96
######## 	174 	116 	30 	28 	118.56 	87.36 	81.12 	75.66 	228 	0.1 	14 	201 	42 	18.04 	125.8 	0 	2031.25 	0 	2.56 	5 	134 	2.96
######## 	174 	116 	35 	28 	118.56 	87.36 	81.12 	89.7 	228 	0.1 	14 	201 	42 	20.39 	138.38 	0 	2156.25 	0 	2.82 	6 	134 	2.96
######## 	173 	116 	33 	28 	118.56 	87.36 	81.12 	109.98 	228 	0.62 	14 	201 	42 	21.57 	176.12 	0 	2312.5 	0 	3.07 	7 	134 	2.96
######## 	174 	116 	34 	28 	118.56 	87.36 	81.12 	97.5 	228 	0.21 	14 	201 	42 	21.57 	176.12 	0 	2468.75 	0 	3.07 	8 	134 	2.96
######## 	174 	116 	34 	28 	118.56 	87.36 	81.12 	114.66 	228 	0.9 	14 	201 	42 	10.2 	69.19 	0 	2500 	0 	1.28 	3 	133 	2.96
######## 	175 	240 	38 	28 	118.56 	87.36 	81.12 	99.84 	228 	0.94 	14 	201 	42 	10.2 	44.03 	0 	2093.75 	0 	0 	0 	133 	2.96
######## 	174 	240 	41 	28 	118.56 	87.36 	81.12 	99.84 	228 	0.14 	14 	201 	42 	10.2 	37.74 	0 	1593.75 	0 	0 	0 	133 	2.96
######## 	174 	240 	28 	28 	118.56 	87.36 	81.12 	99.84 	228 	0 	14 	201 	42 	10.2 	37.74 	0 	1125 	0 	1.79 	2 	133 	2.96
######## 	173 	244 	20 	28 	118.56 	87.36 	81.12 	104.52 	228 	0 	14 	201 	42 	10.2 	37.74 	0 	1031.25 	0 	1.79 	1 	133 	2.96
######## 	174 	244 	12 	28 	118.56 	87.36 	81.12 	111.54 	228 	0.7 	14 	201 	42 	10.2 	37.74 	0 	906.25 	0 	1.79 	1 	133 	2.96
######## 	174 	244 	10 	28 	118.56 	87.36 	81.12 	106.08 	228 	0.96 	14 	201 	42 	10.2 	37.74 	0 	843.75 	0 	2.05 	1 	133 	2.96
######## 	175 	244 	9 	28 	118.56 	87.36 	81.12 	100.62 	228 	0.96 	14 	201 	42 	10.2 	37.74 	0 	812.5 	0 	2.05 	1 	133 	2.96
######## 	172 	244 	8 	28 	118.56 	87.36 	81.12 	95.94 	228 	0.96 	14 	201 	42 	10.2 	37.74 	0 	812.5 	0 	2.05 	1 	133 	2.96
######## 	175 	244 	7 	28 	118.56 	87.36 	81.12 	90.48 	228 	0.94 	14 	201 	42 	10.2 	37.74 	0 	812.5 	0 	2.05 	1 	133 	2.96
######## 	174 	244 	9 	28 	118.56 	87.36 	81.12 	85.02 	228 	0.94 	14 	201 	40 	10.2 	31.45 	0 	812.5 	0 	1.79 	1 	133 	2.96
######## 	170 	244 	9 	28 	118.56 	87.36 	81.12 	79.56 	228 	0.92 	14 	201 	40 	10.2 	31.45 	0 	781.25 	0 	1.79 	1 	133 	2.96
######## 	174 	244 	10 	28 	118.56 	87.36 	81.12 	74.1 	228 	0.86 	14 	201 	40 	10.2 	31.45 	0 	750 	0 	1.79 	1 	133 	2.96
######## 	175 	244 	10 	28 	118.56 	87.36 	81.12 	69.42 	228 	0.82 	13.93 	201 	40 	10.2 	31.45 	0 	750 	0 	1.79 	1 	133 	2.96
######## 	174 	240 	9 	28 	118.56 	87.36 	81.12 	64.74 	228 	0.8 	14 	201 	41 	10.2 	31.45 	0 	750 	0 	1.79 	1 	133 	2.96
######## 	174 	244 	14 	28 	118.56 	87.36 	81.12 	60.06 	228 	0.7 	14 	201 	41 	10.2 	31.45 	0 	718.75 	0 	1.79 	1 	133 	2.96
######## 	175 	244 	10 	28 	118.56 	87.36 	81.12 	59.28 	228 	0.12 	14 	201 	41 	10.2 	31.45 	0 	718.75 	0 	1.79 	1 	133 	2.96
######## 	175 	244 	8 	28 	118.56 	87.36 	81.12 	61.62 	228 	0.04 	14 	201 	42 	10.2 	31.45 	0 	718.75 	0 	1.79 	1 	133 	2.96
######## 	174 	244 	11 	28 	118.56 	87.36 	81.12 	63.96 	228 	0.02 	13.93 	201 	42 	10.2 	31.45 	0 	687.5 	0 	1.79 	1 	133 	2.94
######## 	175 	240 	12 	28 	117.78 	87.36 	81.12 	66.3 	228 	0.02 	13.93 	201 	42 	10.2 	31.45 	0 	750 	0 	1.79 	1 	133 	2.94
######## 	175 	244 	9 	28 	117.78 	87.36 	81.12 	69.42 	228 	0.02 	13.93 	201 	42 	10.2 	31.45 	0 	718.75 	0 	1.79 	1 	133 	2.94
######## 	174 	244 	11 	28 	117.78 	87.36 	81.12 	71.76 	228 	0.02 	14 	201 	43 	10.2 	31.45 	0 	718.75 	0 	1.79 	1 	133 	2.94
######## 	175 	244 	8 	28 	117.78 	87.36 	81.12 	74.1 	228 	0.02 	13.93 	201 	43 	10.2 	31.45 	0 	750 	0 	1.79 	1 	133 	2.92
######## 	174 	244 	6 	28 	117 	87.36 	81.12 	76.44 	228 	0.02 	13.93 	201 	43 	10.2 	31.45 	0 	750 	0 	1.79 	1 	133 	2.92
######## 	175 	240 	6 	28 	117 	87.36 	81.12 	78.78 	228 	0.02 	13.93 	201 	43 	10.2 	31.45 	0 	750 	0 	1.79 	1 	133 	2.92
######## 	174 	244 	6 	28 	117 	87.36 	81.12 	81.9 	228 	0.02 	13.93 	201 	43 	10.2 	31.45 	0 	718.75 	0 	1.79 	1 	133 	2.92
######## 	175 	244 	8 	28 	116.22 	87.36 	81.12 	83.46 	228 	0.02 	14 	201 	44 	10.2 	31.45 	0 	718.75 	0 	1.79 	1 	133 	2.91
######## 	174 	244 	8 	28 	116.22 	87.36 	81.12 	86.58 	228 	0.02 	13.93 	201 	44 	10.2 	31.45 	0 	750 	0 	1.79 	1 	133 	2.91
######## 	175 	112 	6 	28 	116.22 	87.36 	81.12 	88.92 	228 	0.02 	13.93 	201 	44 	16.08 	44.03 	10.2 	750 	0 	3.07 	2 	133 	2.91
######## 	174 	116 	6 	28 	116.22 	87.36 	81.12 	92.04 	228 	0.02 	13.93 	201 	53 	19.61 	106.93 	0 	1281.25 	0 	3.58 	4 	133 	2.91
######## 	171 	120 	24 	28 	116.22 	87.36 	81.12 	102.18 	228 	0.02 	14 	201 	60 	23.14 	163.54 	0 	1625 	0 	4.1 	7 	133 	2.91
######## 	175 	124 	25 	28 	116.22 	87.36 	81.12 	118.56 	228 	0.02 	14 	201 	60 	23.53 	201.28 	0 	1906.25 	0 	4.35 	8 	133 	2.91
######## 	167 	120 	27 	28 	116.22 	87.36 	81.12 	137.28 	228 	0.66 	13.93 	201 	60 	23.53 	207.57 	0 	1906.25 	0 	4.61 	9 	132 	2.91
######## 	175 	124 	25 	28 	116.22 	87.36 	81.12 	124.02 	228 	0.86 	13.93 	201 	60 	23.53 	213.86 	0 	1781.25 	0 	4.86 	9 	132 	2.91
######## 	174 	124 	23 	28 	116.22 	87.36 	81.12 	109.2 	228 	0.84 	14 	201 	60 	23.53 	220.15 	0 	1718.75 	0 	4.86 	8 	132 	2.91
######## 	174 	120 	23 	28 	116.22 	87.36 	81.12 	95.94 	228 	0.78 	13.93 	201 	60 	23.53 	226.44 	0 	1812.5 	0 	4.61 	8 	132 	2.91
######## 	175 	124 	25 	28 	116.22 	87.36 	81.12 	81.9 	228 	0.31 	14 	201 	60 	23.53 	245.31 	0 	2031.25 	1 	4.61 	10 	132 	2.91
######## 	175 	124 	28 	28 	116.22 	87.36 	81.12 	88.92 	228 	0.74 	14 	201 	61 	23.92 	251.6 	0 	2281.25 	0 	4.35 	10 	132 	2.91
######## 	174 	116 	28 	28 	116.22 	87.36 	81.12 	97.5 	228 	0.08 	13.93 	201 	51 	27.06 	301.92 	0 	2531.25 	9 	4.86 	13 	131 	2.91
######## 	175 	116 	25 	28 	116.22 	87.36 	81.12 	99.06 	228 	0.8 	13.93 	201 	52 	27.84 	339.66 	0 	2843.75 	12 	4.61 	14 	131 	2.91
######## 	171 	116 	25 	28 	116.22 	87.36 	81.12 	97.5 	228 	0.14 	14 	201 	59 	32.16 	440.3 	0 	3187.5 	12 	5.89 	20 	131 	2.91
######## 	175 	116 	25 	28 	116.22 	87.36 	81.12 	99.06 	228 	0.88 	13.93 	201 	64 	35.29 	578.68 	0 	3687.5 	11 	8.19 	32 	130 	2.91
######## 	174 	112 	23 	28 	116.22 	87.36 	81.12 	99.84 	228 	0.96 	13.85 	201 	71 	40.39 	956.08 	0 	4312.5 	10 	12.8 	58 	129 	2.91
######## 	171 	116 	18 	28 	116.22 	87.36 	81.12 	99.84 	228 	0.96 	13.78 	201 	72 	41.18 	1188.81 	0 	5062.5 	9 	13.31 	72 	126 	2.91
######## 	170 	116 	22 	28 	116.22 	87.36 	81.12 	99.84 	228 	0.94 	13.93 	201 	60 	10.2 	220.15 	0 	4875 	0 	2.05 	10 	125 	2.91
######## 	175 	244 	44 	28 	116.22 	87.36 	81.12 	99.84 	228 	0.72 	14 	201 	44 	16.47 	75.48 	0 	4062.5 	0 	2.3 	10 	125 	2.91
######## 	175 	116 	34 	28 	116.22 	87.36 	81.12 	99.84 	228 	0.86 	13.93 	201 	78 	46.67 	616.42 	0 	3500 	0 	8.96 	33 	125 	2.91
######## 	166 	116 	24 	28 	116.22 	87.36 	81.12 	99.84 	228 	0.96 	13.85 	201 	86 	52.55 	962.37 	0 	3750 	0 	14.85 	59 	123 	2.91
######## 	170 	116 	17 	28 	116.22 	87.36 	81.12 	99.84 	228 	0.96 	13.78 	201 	88 	54.12 	1446.7 	0 	4250 	5 	17.92 	81 	122 	2.91
######## 	172 	116 	17 	28 	116.22 	87.36 	81.12 	99.84 	228 	0.96 	13.71 	201 	88 	54.12 	1528.47 	0 	4625 	4 	17.66 	87 	120 	2.91
######## 	164 	112 	16 	28 	116.22 	87.36 	81.12 	99.84 	228 	0.96 	13.71 	201 	88 	54.12 	1572.5 	0 	5125 	4 	17.66 	96 	119 	2.91
######## 	164 	112 	17 	28 	116.22 	87.36 	81.12 	99.84 	228 	0.96 	13.71 	201 	88 	54.12 	1603.95 	0 	5406.25 	4 	17.66 	102 	118 	2.91
######## 	169 	116 	20 	28 	116.22 	87.36 	81.12 	99.84 	228 	0.96 	13.71 	201 	87 	53.73 	1603.95 	0 	5812.5 	3 	16.64 	103 	117 	2.91
######## 	163 	116 	23 	28 	116.22 	87.36 	81.12 	99.84 	228 	0.94 	13.93 	201 	67 	10.2 	194.99 	0 	5281.25 	0 	1.54 	8 	117 	2.91
######## 	175 	116 	45 	28 	116.22 	87.36 	81.12 	99.84 	228 	0.92 	13.93 	201 	54 	39.61 	503.2 	6.67 	3906.25 	0 	7.94 	33 	119 	2.91
######## 	173 	112 	26 	28 	116.22 	87.36 	81.12 	99.84 	228 	0.94 	13.85 	201 	96 	61.57 	1037.85 	0 	3968.75 	0 	15.62 	66 	119 	2.91
######## 	173 	112 	18 	28 	116.22 	87.36 	81.12 	99.84 	228 	0.94 	13.78 	201 	96 	61.18 	1377.51 	0 	4125 	7 	17.41 	76 	120 	2.91
######## 	169 	116 	16 	28 	116.22 	87.36 	81.12 	99.84 	228 	0.96 	13.78 	201 	83 	50.2 	1264.29 	0 	4281.25 	6 	15.1 	69 	120 	2.91
######## 	165 	116 	18 	28 	116.22 	87.36 	81.12 	99.84 	228 	0.96 	13.85 	201 	66 	35.69 	849.15 	0 	4375 	5 	7.94 	37 	121 	2.91
######## 	166 	116 	29 	28 	116.22 	87.36 	81.12 	99.84 	228 	0.92 	14 	201 	44 	10.2 	113.22 	0 	4281.25 	0 	1.54 	7 	122 	2.91
######## 	174 	244 	42 	28 	116.22 	87.36 	81.12 	99.84 	228 	0.7 	14 	201 	44 	10.2 	44.03 	0 	4250 	0 	0 	0 	122 	2.91
######## 	174 	240 	42 	28 	116.22 	87.36 	81.12 	99.84 	228 	0.78 	14 	201 	44 	10.2 	37.74 	0 	4125 	0 	0 	0 	123 	2.91
######## 	175 	240 	42 	28 	116.22 	87.36 	81.12 	99.84 	228 	0 	14 	201 	44 	10.59 	50.32 	0 	4000 	0 	1.28 	5 	124 	2.91
######## 	171 	244 	41 	28 	116.22 	87.36 	81.12 	99.84 	228 	0.29 	14 	201 	44 	10.2 	44.03 	0 	3593.75 	0 	1.28 	4 	125 	2.91
######## 	174 	244 	40 	28 	116.22 	87.36 	81.12 	99.84 	228 	0.82 	14 	201 	44 	13.73 	62.9 	0 	2812.5 	0 	1.28 	3 	125 	2.91
######## 	175 	116 	39 	28 	116.22 	87.36 	81.12 	99.84 	228 	0.94 	14 	201 	44 	14.9 	81.77 	0 	2875 	0 	1.54 	4 	126 	2.91
######## 	175 	116 	39 	28 	116.22 	87.36 	81.12 	80.34 	228 	0.9 	14 	201 	44 	10.2 	50.32 	0 	2812.5 	0 	1.28 	3 	127 	2.91
######## 	174 	244 	39 	28 	116.22 	87.36 	81.12 	99.84 	228 	0.76 	14 	201 	44 	10.2 	44.03 	0 	2750 	0 	0 	0 	127 	2.91
######## 	174 	244 	38 	27 	116.22 	87.36 	81.12 	99.84 	228 	0.55 	14 	201 	44 	10.2 	44.03 	0 	2718.75 	0 	0 	0 	127 	2.91
######## 	175 	244 	38 	27 	116.22 	87.36 	81.12 	99.84 	228 	0 	14 	201 	44 	10.2 	44.03 	0 	2656.25 	0 	0 	0 	128 	2.91
######## 	174 	240 	38 	27 	116.22 	87.36 	81.12 	99.84 	228 	0 	14 	201 	44 	10.2 	37.74 	0 	2625 	0 	0 	0 	128 	2.91
######## 	175 	240 	38 	27 	116.22 	87.36 	81.12 	99.84 	228 	0 	14 	201 	44 	10.2 	37.74 	0 	2593.75 	0 	1.28 	3 	128 	2.91
######## 	174 	116 	38 	27 	116.22 	87.36 	81.12 	99.84 	228 	0 	14 	201 	44 	14.12 	62.9 	0 	2531.25 	0 	1.28 	3 	128 	2.91
######## 	175 	116 	38 	27 	116.22 	87.36 	81.12 	99.84 	228 	0.66 	14 	201 	44 	16.08 	81.77 	0 	2531.25 	0 	1.79 	4 	129 	2.91
######## 	174 	116 	38 	27 	116.22 	87.36 	81.12 	99.84 	228 	0.84 	14 	201 	44 	18.82 	113.22 	0 	2531.25 	0 	2.05 	5 	129 	2.91
######## 	175 	116 	36 	27 	116.22 	87.36 	81.12 	99.84 	228 	0.04 	14 	201 	44 	19.22 	125.8 	0 	2500 	0 	2.3 	6 	129 	2.91
######## 	175 	116 	36 	27 	116.22 	87.36 	81.12 	99.84 	228 	0.04 	14 	201 	44 	18.43 	125.8 	0 	2468.75 	0 	2.05 	5 	129 	2.91
######## 	175 	116 	37 	27 	116.22 	87.36 	81.12 	109.98 	228 	0.9 	14 	201 	44 	13.73 	75.48 	0 	2437.5 	0 	1.54 	4 	129 	2.91
######## 	175 	116 	38 	27 	116.22 	87.36 	81.12 	94.38 	228 	0.9 	14 	201 	44 	12.94 	62.9 	0 	2406.25 	0 	1.28 	3 	129 	2.91
######## 	175 	116 	38 	27 	116.22 	87.36 	81.12 	78 	228 	0.84 	14 	201 	44 	12.94 	56.61 	0 	2375 	2 	1.28 	3 	130 	2.91
######## 	174 	116 	38 	27 	116.22 	87.36 	81.12 	62.4 	228 	0.8 	14 	201 	44 	12.94 	56.61 	0 	2375 	0 	1.28 	3 	130 	2.91
######## 	174 	116 	38 	27 	116.22 	87.36 	81.12 	62.4 	228 	0.06 	14 	201 	44 	12.94 	56.61 	0 	2343.75 	0 	1.28 	3 	130 	2.91
######## 	174 	116 	38 	27 	116.22 	87.36 	81.12 	81.12 	228 	0.08 	14 	201 	44 	14.9 	75.48 	0 	2343.75 	0 	1.54 	3 	130 	2.91
######## 	175 	116 	38 	27 	116.22 	87.36 	81.12 	79.56 	228 	0.84 	14 	201 	44 	15.69 	88.06 	0 	2312.5 	0 	1.79 	4 	130 	2.91
######## 	174 	116 	38 	27 	116.22 	87.36 	81.12 	85.02 	228 	0.06 	14 	201 	44 	16.86 	94.35 	0 	2312.5 	0 	1.79 	4 	130 	2.91
######## 	175 	116 	37 	27 	116.22 	87.36 	81.12 	102.96 	228 	0.16 	14 	201 	44 	18.04 	106.93 	0 	2312.5 	0 	2.3 	5 	130 	2.91
######## 	175 	116 	35 	27 	116.22 	87.36 	81.12 	112.32 	228 	0.64 	14 	201 	69 	44.71 	327.08 	0 	2343.75 	0 	5.89 	14 	130 	2.91
######## 	167 	116 	24 	27 	116.22 	87.36 	81.12 	129.48 	228 	0.04 	14 	201 	76 	44.71 	389.98 	0 	2375 	0 	7.17 	18 	130 	2.91
######## 	175 	116 	23 	27 	116.22 	87.36 	81.12 	127.92 	228 	0.88 	14 	201 	76 	44.71 	440.3 	0 	2406.25 	0 	7.42 	19 	130 	2.91
######## 	171 	116 	22 	27 	116.22 	87.36 	81.12 	99.84 	228 	0.94 	14 	201 	76 	44.71 	490.62 	0 	2468.75 	0 	9.22 	24 	130 	2.91
######## 	175 	112 	19 	27 	116.22 	87.36 	81.12 	99.84 	228 	0.94 	13.93 	201 	76 	44.31 	547.23 	0 	2531.25 	0 	10.24 	27 	130 	2.91
######## 	175 	116 	18 	27 	116.22 	87.36 	81.12 	99.84 	228 	0.94 	13.93 	201 	76 	44.31 	603.84 	0 	2593.75 	0 	11.52 	31 	131 	2.91
######## 	171 	116 	16 	27 	116.22 	87.36 	81.12 	99.84 	228 	0.96 	13.93 	201 	76 	44.31 	666.74 	0 	2687.5 	0 	12.8 	36 	131 	2.91
######## 	170 	116 	16 	27 	116.22 	87.36 	81.12 	99.84 	228 	0.96 	13.93 	201 	64 	24.71 	522.07 	0 	2718.75 	0 	4.1 	11 	132 	2.91
######## 	173 	112 	34 	27 	116.22 	87.36 	81.12 	86.58 	228 	0.92 	14 	201 	44 	12.16 	125.8 	0 	2687.5 	0 	1.28 	3 	132 	2.91
######## 	175 	116 	39 	27 	116.22 	87.36 	81.12 	67.86 	228 	0.94 	14 	201 	44 	10.98 	37.74 	0 	2687.5 	0 	1.28 	3 	132 	2.91
######## 	174 	116 	38 	27 	116.22 	87.36 	81.12 	99.84 	228 	0.88 	14 	201 	44 	10.98 	44.03 	0 	2718.75 	0 	1.28 	3 	132 	2.91
######## 	175 	112 	38 	27 	116.22 	87.36 	81.12 	99.84 	228 	0.88 	14 	201 	44 	10.98 	50.32 	0 	2687.5 	0 	1.28 	3 	133 	2.91
######## 	174 	116 	38 	27 	116.22 	87.36 	81.12 	99.84 	228 	0.86 	14 	201 	44 	10.98 	50.32 	0 	2687.5 	0 	1.28 	3 	133 	2.91
######## 	175 	244 	38 	27 	116.22 	87.36 	81.12 	99.84 	228 	0.8 	14 	201 	44 	10.2 	44.03 	0 	2625 	0 	1.28 	3 	133 	2.91
######## 	175 	244 	38 	27 	116.22 	87.36 	81.12 	99.84 	228 	0.78 	14 	201 	44 	10.2 	44.03 	0 	2625 	0 	0 	0 	133 	2.91
######## 	174 	244 	38 	27 	116.22 	87.36 	81.12 	99.84 	228 	0.02 	14 	201 	44 	10.2 	44.03 	0 	2593.75 	0 	0 	0 	133 	2.91
######## 	175 	244 	38 	27 	116.22 	87.36 	81.12 	99.84 	228 	0 	14 	201 	44 	10.2 	44.03 	0 	2562.5 	0 	0 	0 	133 	2.91
######## 	174 	244 	38 	27 	116.22 	87.36 	81.12 	99.84 	228 	0 	14 	201 	44 	10.2 	37.74 	0 	2500 	0 	0 	0 	133 	2.91
######## 	174 	244 	38 	27 	116.22 	87.36 	81.12 	99.84 	228 	0 	14 	201 	44 	10.2 	37.74 	0 	2468.75 	0 	0 	0 	134 	2.91
######## 	174 	244 	38 	27 	116.22 	87.36 	81.12 	99.84 	228 	0 	14 	201 	44 	10.2 	37.74 	0 	2437.5 	0 	0 	0 	134 	2.91
######## 	174 	244 	38 	27 	116.22 	87.36 	81.12 	99.84 	228 	0 	14 	201 	44 	10.2 	37.74 	0 	2406.25 	0 	1.28 	3 	134 	2.91
######## 	175 	116 	38 	27 	116.22 	87.36 	81.12 	99.84 	228 	0 	14 	201 	44 	16.47 	81.77 	0 	2437.5 	0 	1.79 	4 	134 	2.91
######## 	175 	116 	36 	27 	116.22 	87.36 	81.12 	99.84 	228 	0.02 	14 	201 	44 	20.39 	144.67 	0 	2406.25 	0 	2.56 	6 	134 	2.91
######## 	174 	116 	35 	28 	116.22 	87.36 	81.12 	99.84 	228 	0.02 	14 	201 	44 	20.78 	157.25 	0 	2406.25 	0 	2.82 	7 	133 	2.91
######## 	173 	112 	35 	27 	116.22 	87.36 	81.12 	99.84 	228 	0.02 	14 	201 	44 	20.78 	157.25 	0 	2406.25 	0 	2.82 	7 	133 	2.91
######## 	174 	116 	35 	28 	116.22 	87.36 	81.12 	99.84 	228 	0.04 	14 	201 	44 	20.78 	163.54 	0 	2406.25 	0 	2.82 	7 	133 	2.91
######## 	175 	116 	34 	28 	116.22 	87.36 	81.12 	119.34 	228 	0.76 	14 	201 	44 	20.78 	163.54 	0 	2437.5 	0 	2.82 	7 	133 	2.91
######## 	172 	112 	34 	28 	116.22 	87.36 	81.12 	102.18 	228 	0.43 	14 	201 	44 	21.18 	169.83 	0 	2437.5 	0 	3.07 	8 	133 	2.91
######## 	174 	116 	34 	28 	116.22 	87.36 	81.12 	111.54 	228 	0.8 	14 	201 	44 	21.18 	169.83 	0 	2468.75 	0 	2.82 	7 	132 	2.91
######## 	174 	112 	34 	28 	116.22 	87.36 	81.12 	106.08 	228 	0.1 	14 	201 	44 	21.18 	169.83 	0 	2468.75 	0 	2.82 	7 	132 	2.91
######## 	174 	116 	34 	28 	116.22 	87.36 	81.12 	106.08 	228 	0.82 	14 	201 	51 	48.63 	339.66 	7.45 	2500 	0 	6.91 	18 	132 	2.91
######## 	175 	116 	24 	28 	116.22 	87.36 	81.12 	99.84 	228 	0.88 	14 	201 	95 	66.27 	465.46 	0 	2531.25 	0 	8.7 	23 	133 	2.91
######## 	175 	116 	21 	28 	116.22 	87.36 	81.12 	99.84 	228 	0.94 	14 	201 	110 	78.82 	572.39 	0 	2625 	0 	10.75 	30 	134 	2.91
######## 	166 	116 	18 	28 	116.22 	87.36 	81.12 	99.84 	228 	0.94 	13.93 	201 	110 	78.82 	673.03 	0 	2718.75 	0 	13.31 	38 	135 	2.91
######## 	171 	116 	15 	28 	116.22 	87.36 	81.12 	99.84 	228 	0.96 	13.93 	201 	109 	77.65 	798.83 	0 	2812.5 	0 	15.36 	46 	136 	2.91
######## 	173 	116 	14 	28 	116.22 	87.36 	81.12 	99.84 	228 	0.96 	13.85 	201 	106 	74.12 	937.21 	0 	2906.25 	0 	17.15 	53 	137 	2.91
######## 	171 	112 	15 	28 	116.22 	87.36 	81.12 	99.84 	228 	0.96 	13.85 	201 	101 	66.67 	974.95 	0 	3031.25 	4 	17.15 	55 	138 	2.91
######## 	162 	116 	14 	28 	116.22 	87.36 	81.12 	99.84 	228 	0.94 	13.85 	201 	95 	60.39 	1018.98 	0 	3125 	3 	16.9 	56 	138 	2.91
######## 	164 	112 	15 	28 	116.22 	87.36 	81.12 	99.84 	228 	0.96 	13.85 	201 	79 	24.31 	691.9 	0 	3062.5 	2 	3.07 	10 	138 	2.91
######## 	175 	244 	35 	28 	116.22 	87.36 	81.12 	85.8 	228 	0.9 	14 	201 	52 	10.2 	119.51 	0 	3187.5 	0 	1.54 	5 	138 	2.91
######## 	174 	244 	39 	28 	116.22 	87.36 	81.12 	99.84 	228 	0.82 	14 	201 	44 	10.2 	31.45 	0 	3062.5 	0 	0 	0 	138 	2.91
######## 	174 	244 	39 	28 	116.22 	87.36 	81.12 	99.84 	228 	0 	14 	201 	44 	10.2 	44.03 	0 	3000 	0 	0 	0 	138 	2.91
######## 	175 	240 	39 	28 	116.22 	87.36 	81.12 	99.84 	228 	0 	14 	201 	44 	10.2 	44.03 	0 	2843.75 	0 	0 	0 	138 	2.91
######## 	175 	244 	39 	28 	116.22 	87.36 	81.12 	99.84 	228 	0 	14 	201 	44 	10.2 	50.32 	0 	2781.25 	0 	0 	0 	138 	2.91
######## 	175 	244 	39 	28 	116.22 	87.36 	81.12 	99.84 	228 	0 	14 	201 	44 	10.2 	44.03 	0 	2718.75 	0 	0 	0 	139 	2.91
######## 	174 	240 	38 	28 	116.22 	87.36 	81.12 	99.84 	228 	0 	14 	201 	44 	10.2 	44.03 	0 	2625 	0 	0 	0 	139 	2.91
######## 	175 	244 	38 	28 	116.22 	87.36 	81.12 	99.84 	228 	0 	14.07 	201 	44 	10.2 	44.03 	0 	2593.75 	0 	0 	0 	139 	2.91
######## 	175 	116 	38 	28 	116.22 	87.36 	81.12 	99.84 	228 	0 	14.07 	201 	44 	12.55 	50.32 	0 	2531.25 	0 	1.28 	3 	139 	2.91
######## 	173 	116 	38 	28 	116.22 	87.36 	81.12 	99.84 	228 	0.45 	14.07 	201 	44 	15.29 	81.77 	0 	2531.25 	0 	1.54 	4 	139 	2.91
######## 	174 	112 	38 	28 	116.22 	87.36 	81.12 	99.84 	228 	0.88 	14.07 	201 	44 	13.33 	69.19 	0 	2500 	0 	1.54 	4 	138 	2.91
######## 	175 	116
######## 		44 	10.2 	44.03 	0 	2906.25 	0 	0 	0 	142 	2.91
######## 	174 	240 	39 	28 	116.22 	87.36 	81.12 	99.84 	228 	0 	14.07 	201 	44 	10.2 	44.03 	0 	2843.75 	0 	0 	0 	143 	2.91
######## 	175 	244 	39 	28 	116.22 	87.36 	81.12 	99.84 	228 	0 	14.07 	201 	44 	10.2 	44.03 	0 	2812.5 	0 	0 	0 	143 	2.91
######## 	174 	244 	39 	28 	116.22 	87.36 	81.12 	99.84 	228 	0 	14.07 	201 	44 	10.2 	37.74 	0 	2781.25 	0 	0 	0 	143 	2.91
######## 	175 	240 	39 	28 	116.22 	87.36 	81.12 	99.84 	228 	0 	14.07 	201 	44 	10.2 	37.74 	0 	2750 	0 	0 	0 	143 	2.91
######## 	175 	240 	39 	28 	116.22 	87.36 	81.12 	99.84 	228 	0 	14.07 	201 	44 	10.2 	37.74 	0 	2718.75 	0 	0 	0 	143 	2.91
######## 	175 	240 	38 	28 	116.22 	87.36 	81.12 	99.84 	228 	0 	14.07 	201 	29 	10.2 	31.45 	0 	2687.5 	0 	0 	0 	143 	2.91
######## 	175 	244 	38 	28 	116.22 	87.36 	81.12 	99.84 	228 	0 	14.07 	201 	29 	10.2 	31.45 	0 	2625 	0 	0 	0 	143 	2.91
######## 	174 	244 	38 	28 	116.22 	87.36 	81.12 	99.84 	228 	0 	14.07 	201 	29 	10.2 	31.45 	0 	2593.75 	0 	0 	0 	143 	2.91
######## 	175 	244 	38 	28 	116.22 	87.36 	81.12 	99.84 	228 	0 	14.07 	201 	14 	10.2 	25.16 	0 	2531.25 	0 	0 	0 	143 	2.91
######## 	174 	244 	38 	28 	116.22 	87.36 	81.12 	99.84 	228 	0 	14.07 	201 	14 	10.2 	25.16 	0 	2468.75 	0 	0 	0 	143 	2.91
######## 	175 	244 	38 	28 	116.22 	87.36 	81.12 	99.84 	228 	0 	14.07 	201 	0 	10.2 	25.16 	0 	2406.25 	0 	0 	0 	143 	2.91
######## 	174 	116 	38 	28 	116.22 	87.36 	81.12 	99.84 	228 	0 	14.07 	201 	0 	10.2 	18.87 	0 	2375 	0 	0 	0 	143 	2.91
######## 	174 	112 	38 	28 	116.22 	87.36 	81.12 	99.84 	228 	0 	14.07 	201 	0 	16.47 	62.9 	0 	2343.75 	0 	1.54 	3 	143 	2.91
######## 	175 	116 	38 	28 	116.22 	87.36 	81.12 	99.84 	228 	0.02 	14.07 	201 	0 	20 	113.22 	0 	2281.25 	0 	2.3 	5 	143 	2.91
######## 	172 	116 	36 	28 	116.22 	87.36 	81.12 	99.84 	228 	0.02 	14 	201 	0 	19.61 	119.51 	0 	2281.25 	0 	2.05 	4 	142 	2.91
######## 	175 	116 	36 	28 	116.22 	87.36 	81.12 	99.84 	228 	0.08 	14.07 	201 	0 	16.47 	81.77 	0 	2250 	0 	1.79 	4 	142 	2.91
######## 	174 	116 	37 	28 	116.22 	87.36 	81.12 	99.84 	228 	0.82 	14.07 	201 	0 	16.47 	75.48 	0 	2218.75 	0 	1.54 	3 	142 	2.91
######## 	175 	116 	37 	28 	116.22 	87.36 	81.12 	99.84 	228 	0.82 	14.07 	201 	0 	16.47 	75.48 	0 	2187.5 	0 	1.54 	3 	142 	2.91
######## 	174 	116 	37 	28 	116.22 	87.36 	81.12 	88.14 	228 	0.84 	14.07 	201 	0 	16.47 	75.48 	0 	2156.25 	0 	1.54 	3 	141 	2.91
######## 	174 	116 	37 	28 	116.22 	87.36 	81.12 	88.14 	228 	0.06 	14.07 	201 	0 	18.43 	81.77 	0 	2156.25 	0 	2.3 	5 	141 	2.91
######## 	170 	116 	35 	28 	116.22 	87.36 	81.12 	103.74 	228 	0.02 	14.07 	201 	1 	23.14 	157.25 	0 	2125 	0 	3.33 	7 	141 	2.91
######## 	175 	112 	32 	28 	116.22 	87.36 	81.12 	125.58 	228 	0.04 	14 	201 	9 	27.84 	220.15 	0 	2125 	0 	4.86 	11 	141 	2.91
######## 	166 	116 	26 	28 	116.22 	87.36 	81.12 	147.42 	228 	0.12 	14.07 	201 	11 	29.41 	264.18 	0 	2125 	0 	5.38 	12 	141 	2.91
######## 	174 	116 	26 	28 	116.22 	87.36 	81.12 	139.62 	228 	0.86 	14 	201 	12 	29.8 	289.34 	0 	2125 	0 	5.63 	12 	141 	2.91
######## 	174 	112 	25 	28 	116.22 	87.36 	81.12 	123.24 	228 	0.86 	14 	201 	12 	29.8 	301.92 	0 	2125 	0 	5.63 	12 	141 	2.91
######## 	171 	116 	25 	28 	116.22 	87.36 	81.12 	106.08 	228 	0.76 	14 	201 	12 	29.8 	308.21 	0 	2156.25 	0 	5.63 	12 	141 	2.91
######## 	175 	112 	24 	28 	116.22 	87.36 	81.12 	105.3 	228 	0.72 	14.07 	201 	12 	29.8 	320.79 	0 	2187.5 	0 	5.63 	13 	141 	2.91
######## 	171 	116 	24 	28 	116.22 	87.36 	81.12 	91.26 	228 	0.27 	14 	201 	12 	29.8 	333.37 	0 	2187.5 	0 	5.89 	13 	141 	2.91
######## 	175 	112 	24 	28 	116.22 	87.36 	81.12 	92.04 	228 	0.72 	14 	201 	12 	29.8 	333.37 	0 	2218.75 	0 	5.89 	13 	141 	2.91
######## 	167 	116 	24 	28 	116.22 	87.36 	81.12 	101.4 	228 	0.8 	14 	201 	12 	29.8 	339.66 	0 	2250 	0 	5.89 	14 	141 	2.91
######## 	175 	116 	24 	28 	116.22 	87.36 	81.12 	85.8 	228 	0.58 	14 	201 	12 	29.8 	345.95 	0 	2250 	0 	5.89 	14 	141 	2.91
######## 	174 	116 	24 	28 	116.22 	87.36 	81.12 	90.48 	228 	0.76 	14 	201 	9 	17.65 	264.18 	0 	2281.25 	0 	2.82 	6 	142 	2.91
######## 	175 	244 	37 	28 	116.22 	87.36 	81.12 	74.1 	228 	0.96 	14.07 	201 	0 	18.43 	75.48 	5.1 	2343.75 	0 	1.02 	2 	142 	2.91
######## 	172 	112 	31 	28 	116.22 	87.36 	81.12 	59.28 	228 	0.06 	14 	201 	27 	40 	484.33 	0 	3093.75 	0 	6.4 	21 	142 	2.91
######## 	173 	116 	24 	28 	116.22 	87.36 	81.12 	98.28 	228 	0.47 	14 	201 	43 	80 	710.77 	0 	3156.25 	0 	12.54 	42 	143 	2.91
######## 	172 	116 	18 	28 	116.22 	87.36 	81.12 	99.84 	228 	0.94 	13.93 	201 	68 	81.18 	1025.27 	0 	3343.75 	0 	17.15 	61 	143 	2.91
######## 	162 	116 	15 	28 	116.22 	87.36 	81.12 	99.84 	228 	0.94 	13.85 	201 	68 	81.18 	1195.1 	0 	3593.75 	4 	17.41 	66 	144 	2.91
######## 	164 	116 	15 	28 	116.22 	87.36 	81.12 	99.84 	228 	0.94 	13.85 	201 	68 	81.18 	1245.42 	0 	3750 	4 	17.92 	71 	143 	2.91
######## 	173 	112 	17 	28 	116.22 	87.36 	81.12 	99.84 	228 	0.94 	13.85 	201 	65 	75.29 	1333.48 	0 	4000 	3 	18.18 	77 	142 	2.91
######## 	172 	116 	17 	28 	116.22 	87.36 	81.12 	99.84 	228 	0.97 	13.93 	201 	35 	13.33 	427.72 	0 	3906.25 	0 	2.05 	8 	142 	2.91
######## 	174 	244 	41 	28 	116.22 	87.36 	81.12 	78 	228 	0.74 	14.07 	201 	8 	10.2 	106.93 	0 	3937.5 	0 	0 	0 	141 	2.91
######## 	175 	240 	41 	28 	116.22 	87.36 	81.12 	99.84 	228 	0.74 	14.07 	201 	0 	10.2 	37.74 	0 	3906.25 	0 	0 	0 	142 	2.91
######## 	175 	244 	40 	28 	116.22 	87.36 	81.12 	99.84 	228 	0.8 	14.07 	201 	0 	10.2 	31.45 	0 	3218.75 	0 	0 	0 	142 	2.91
######## 	174 	240 	39 	28 	116.22 	87.36 	81.12 	99.84 	228 	0.64 	14.07 	201 	0 	10.2 	25.16 	0 	2781.25 	0 	0 	0 	143 	2.91
######## 	174 	244 	39 	28 	116.22 	87.36 	81.12 	99.84 	228 	0.02 	14.07 	201 	0 	10.2 	25.16 	0 	2812.5 	0 	0 	0 	143 	2.91
######## 	174 	244 	39 	28 	116.22 	87.36 	81.12 	99.84 	228 	0 	14.07 	201 	0 	10.2 	18.87 	0 	2781.25 	0 	0 	0 	143 	2.91
######## 	175 	244 	39 	28 	116.22 	87.36 	81.12 	99.84 	228 	0 	14.07 	201 	0 	10.2 	18.87 	0 	2750 	0 	0 	0 	143 	2.91
######## 	174 	240 	38 	28 	116.22 	87.36 	81.12 	99.84 	228 	0 	14.07 	201 	0 	10.2 	18.87 	0 	2718.75 	0 	0 	0 	144 	2.91
######## 	174 	244 	38 	28 	116.22 	87.36 	81.12 	99.84 	228 	0 	14.07 	201 	0 	10.2 	18.87 	0 	2687.5 	0 	0 	0 	144 	2.91
######## 	175 	244 	38 	28 	116.22 	87.36 	81.12 	99.84 	228 	0 	14.07 	201 	0 	10.2 	18.87 	0 	2656.25 	0 	0 	0 	144 	2.91
######## 	174 	244 	38 	28 	116.22 	87.36 	81.12 	99.84 	228 	0 	14.07 	201 	0 	10.2 	18.87 	0 	2625 	0 	0 	0 	144 	2.91
######## 	175 	244 	38 	28 	116.22 	87.36 	81.12 	99.84 	228 	0 	14.07 	201 	0 	10.2 	18.87 	0 	2593.75 	0 	0 	0 	145 	2.91
######## 	174 	244 	38 	28 	116.22 	87.36 	81.12 	99.84 	228 	0 	14.07 	201 	0 	10.2 	18.87 	0 	2593.75 	0 	0 	0 	145 	2.91
######## 	174 	244 	38 	28 	116.22 	87.36 	81.12 	99.84 	228 	0 	14.07 	201 	0 	10.2 	18.87 	0 	2562.5 	0 	0 	0 	145 	2.91
######## 	174 	244 	38 	28 	116.22 	87.36 	81.12 	99.84 	228 	0 	14.07 	201 	0 	10.2 	18.87 	0 	2531.25 	0 	0 	0 	145 	2.91
######## 	175 	244 	38 	28 	116.22 	87.36 	81.12 	99.84 	228 	0 	14.07 	201 	0 	10.2 	18.87 	0 	2531.25 	0 	0 	0 	145 	2.91
######## 	174 	240 	38 	28 	116.22 	87.36 	81.12 	99.84 	228 	0 	14.07 	201 	0 	10.2 	18.87 	0 	2500 	0 	0 	0 	145 	2.91
######## 	175 	240 	38 	28 	116.22 	87.36 	81.12 	99.84 	228 	0 	14.07 	201 	0 	10.2 	18.87 	0 	2437.5 	0 	0 	0 	146 	2.91
######## 	175 	240 	38 	28 	116.22 	87.36 	81.12 	99.84 	228 	0 	14.07 	201 	0 	10.2 	18.87 	0 	2375 	0 	0 	0 	146 	2.91
######## 	174 	244 	38 	28 	116.22 	87.36 	81.12 	99.84 	228 	0 	14.07 	201 	0 	10.2 	18.87 	0 	2343.75 	1 	0 	0 	146 	2.91
######## 	175 	240 	38 	28 	116.22 	87.36 	81.12 	99.84 	228 	0 	14.07 	201 	0 	10.2 	18.87 	0 	2281.25 	0 	0 	0 	146 	2.91
######## 	174 	244 	37 	28 	116.22 	87.36 	81.12 	99.84 	228 	0 	14.07 	201 	0 	10.2 	18.87 	0 	2250 	0 	0 	0 	146 	2.91
######## 	175 	240 	37 	28 	116.22 	87.36 	81.12 	99.84 	228 	0 	14.07 	201 	0 	10.2 	18.87 	0 	2187.5 	0 	0 	0 	146 	2.91
######## 	174 	240 	37 	28 	116.22 	87.36 	81.12 	99.84 	228 	0 	14.07 	201 	0 	10.2 	18.87 	0 	2156.25 	0 	0 	0 	146 	2.91
######## 	175 	244 	37 	28 	116.22 	87.36 	81.12 	99.84 	228 	0 	14.07 	201 	0 	10.2 	18.87 	0 	2125 	0 	0 	0 	146 	2.91
######## 	175 	244 	37 	28 	116.22 	87.36 	81.12 	99.84 	228 	0 	14.07 	201 	0 	10.2 	18.87 	0 	2093.75 	2 	0 	0 	146 	2.91
######## 	174 	244 	37 	28 	116.22 	87.36 	81.12 	99.84 	228 	0 	14.07 	201 	0 	10.2 	18.87 	0 	2093.75 	0 	0 	0 	146 	2.91
######## 	174 	244 	37 	28 	116.22 	87.36 	81.12 	99.84 	228 	0 	14.07 	201 	0 	10.2 	12.58 	0 	2062.5 	1 	0 	0 	145 	2.91
######## 	174 	116 	37 	28 	116.22 	87.36 	81.12 	99.84 	228 	0 	14.07 	201 	0 	14.12 	44.03 	0 	2062.5 	0 	0 	0 	145 	2.91
######## 	174 	112 	37 	28 	116.22 	87.36 	81.12 	99.84 	228 	0 	14.07 	201 	0 	20 	94.35 	0 	2093.75 	0 	2.3 	5 	145 	2.91
######## 	175 	116 	35 	28 	116.22 	87.36 	81.12 	99.84 	228 	0.02 	14.07 	201 	0 	21.57 	138.38 	0 	2031.25 	0 	2.82 	6 	145 	2.91
######## 	175 	112 	33 	28 	116.22 	87.36 	81.12 	99.84 	228 	0.02 	14 	201 	0 	21.57 	144.67 	0 	2031.25 	0 	3.07 	6 	144 	2.91
######## 	172 	116 	33 	28 	116.22 	87.36 	81.12 	99.84 	228 	0.04 	14.07 	201 	0 	21.57 	150.96 	0 	2062.5 	0 	3.07 	6 	144 	2.91
######## 	174 	116 	33 	28 	116.22 	87.36 	81.12 	99.84 	228 	0.06 	14.07 	201 	0 	21.57 	157.25 	0 	2062.5 	0 	3.07 	6 	143 	2.91
######## 	174 	112 	33 	28 	116.22 	87.36 	81.12 	105.3 	228 	0.1 	14.07 	201 	0 	21.57 	157.25 	0 	2062.5 	0 	2.56 	5 	143 	2.91
######## 	166 	240 	36 	28 	116.22 	87.36 	81.12 	99.06 	228 	0.92 	14.07 	201 	0 	10.2 	37.74 	0 	2062.5 	0 	1.28 	2 	143 	2.91
######## 	174 	244 	37 	28 	116.22 	87.36 	81.12 	99.84 	228 	0.8 	14.07 	201 	0 	10.2 	25.16 	0 	2031.25 	0 	0 	0 	143 	2.91
######## 	175 	240 	37 	28 	116.22 	87.36 	81.12 	99.84 	228 	0.02 	14.07 	201 	0 	10.2 	18.87 	0 	1937.5 	0 	0 	0 	144 	2.91
######## 	174 	244 	33 	28 	116.22 	87.36 	81.12 	99.84 	228 	0 	14.07 	201 	0 	10.2 	18.87 	0 	1906.25 	0 	0 	0 	144 	2.91
######## 	175 	244 	31 	28 	116.22 	87.36 	81.12 	99.84 	228 	0 	14.07 	201 	0 	10.2 	18.87 	0 	1875 	0 	0 	0 	144 	2.91
######## 	174 	244 	31 	28 	116.22 	87.36 	81.12 	99.84 	228 	0 	14.07 	201 	0 	10.2 	18.87 	0 	1843.75 	0 	0 	0 	144 	2.91
######## 	174 	244 	30 	28 	116.22 	87.36 	81.12 	99.84 	228 	0 	14.07 	201 	0 	10.2 	18.87 	0 	1812.5 	0 	0 	0 	144 	2.91
######## 	175 	244 	28 	28 	116.22 	87.36 	81.12 	99.84 	228 	0 	14 	201 	0 	10.2 	18.87 	0 	1781.25 	0 	0 	0 	144 	2.91
######## 	174 	240 	28 	28 	116.22 	87.36 	81.12 	99.84 	228 	0 	14.15 	201 	0 	10.2 	18.87 	0 	1750 	0 	0 	0 	145 	2.91
######## 	175 	112 	27 	28 	116.22 	87.36 	81.12 	99.84 	228 	0 	14.07 	201 	0 	11.37 	18.87 	0 	1718.75 	0 	1.28 	2 	145 	2.91
######## 	175 	116 	27 	28 	116.22 	87.36 	81.12 	99.84 	228 	0.02 	14.07 	201 	0 	14.51 	50.32 	0 	1687.5 	0 	1.54 	2 	145 	2.91
######## 	175 	116 	27 	28 	116.22 	87.36 	81.12 	99.84 	228 	0.78 	14.07 	201 	0 	19.22 	94.35 	0 	1687.5 	0 	2.56 	4 	144 	2.91
######## 	175 	116 	27 	28 	116.22 	87.36 	81.12 	99.84 	228 	0.08 	14.07 	201 	0 	21.96 	138.38 	0 	1687.5 	0 	3.58 	6 	144 	2.91
######## 	171 	116 	26 	28 	116.22 	87.36 	81.12 	99.84 	228 	0.04 	14.07 	201 	0 	22.35 	157.25 	0 	1687.5 	0 	3.84 	6 	144 	2.91
######## 	174 	112 	26 	28 	116.22 	87.36 	81.12 	105.3 	228 	0.04 	14 	201 	0 	22.35 	163.54 	0 	1718.75 	0 	4.1 	7 	144 	2.91
######## 	175 	116 	26 	28 	116.22 	87.36 	81.12 	120.9 	228 	0.68 	14.07 	201 	0 	22.35 	176.12 	0 	1718.75 	0 	4.1 	7 	143 	2.91
######## 	175 	116 	26 	28 	116.22 	87.36 	81.12 	108.42 	228 	0.84 	14.07 	201 	0 	22.75 	176.12 	0 	1718.75 	0 	4.1 	7 	143 	2.91
######## 	175 	116 	25 	28 	116.22 	87.36 	81.12 	95.16 	228 	0.6 	14.07 	201 	0 	22.75 	182.41 	0 	1750 	0 	4.1 	7 	143 	2.91
######## 	174 	116 	25 	28 	116.22 	87.36 	81.12 	104.52 	228 	0.72 	14.07 	201 	0 	22.75 	182.41 	0 	1750 	0 	4.1 	7 	143 	2.91
######## 	174 	116 	25 	28 	116.22 	87.36 	81.12 	92.04 	228 	0.33 	14.07 	201 	0 	22.75 	182.41 	0 	1781.25 	0 	4.1 	7 	143 	2.91
######## 	175 	116 	25 	28 	116.22 	87.36 	81.12 	102.96 	228 	0.84 	14 	201 	0 	22.75 	188.7 	0 	1781.25 	0 	4.1 	7 	143 	2.91
######## 	175 	116 	25 	28 	116.22 	87.36 	81.12 	91.26 	228 	0.27 	14 	201 	0 	22.75 	188.7 	0 	1812.5 	0 	4.1 	7 	143 	2.91
######## 	167 	116 	26 	28 	116.22 	87.36 	81.12 	95.16 	228 	0.82 	14.07 	201 	0 	22.75 	188.7 	0 	1812.5 	0 	4.1 	7 	143 	2.91
######## 	175 	116 	26 	28 	116.22 	87.36 	81.12 	86.58 	228 	0.18 	14.07 	201 	0 	22.75 	194.99 	0 	1812.5 	0 	4.35 	8 	143 	2.91
######## 	174 	116 	25 	28 	116.22 	87.36 	81.12 	92.04 	228 	0.76 	14.07 	201 	1 	23.92 	201.28 	0 	1843.75 	0 	4.35 	8 	143 	2.91
######## 	174 	116 	25 	28 	116.22 	87.36 	81.12 	97.5 	228 	0.1 	14.07 	201 	3 	24.71 	226.44 	0 	1843.75 	0 	4.61 	9 	143 	2.91
######## 	172 	116 	25 	28 	116.22 	87.36 	81.12 	98.28 	228 	0.82 	14 	201 	28 	45.1 	333.37 	0 	1906.25 	0 	6.66 	13 	143 	2.91
######## 	175 	116 	19 	28 	116.22 	87.36 	81.12 	99.84 	228 	0.92 	14 	201 	33 	45.1 	358.53 	0 	1937.5 	0 	8.45 	17 	143 	2.91
######## 	175 	244 	21 	28 	116.22 	87.36 	81.12 	94.38 	228 	0.96 	14.07 	201 	14 	10.2 	106.93 	0 	1968.75 	0 	1.79 	3 	143 	2.91
######## 	174 	244 	33 	28 	116.22 	87.36 	81.12 	99.84 	228 	0.94 	14.07 	201 	0 	10.2 	56.61 	0 	1906.25 	2 	0 	0 	144 	2.91
######## 	175 	244 	33 	28 	116.22 	87.36 	81.12 	99.84 	228 	0.72 	14.07 	201 	0 	10.2 	44.03 	0 	1906.25 	0 	0 	0 	143 	2.91
######## 	175 	244 	31 	28 	116.22 	87.36 	81.12 	99.84 	228 	0 	14.07 	201 	0 	10.2 	31.45 	0 	1875 	0 	0 	0 	143 	2.91
######## 	175 	244 	33 	28 	116.22 	87.36 	81.12 	99.84 	228 	0 	14.07 	201 	0 	10.2 	25.16 	0 	1375 	0 	0 	0 	144 	2.91
######## 	175 	244 	24 	28 	116.22 	87.36 	81.12 	99.84 	228 	0 	14.07 	201 	0 	10.2 	12.58 	0 	937.5 	0 	1.28 	1 	144 	2.91
######## 	174 	244 	16 	28 	116.22 	87.36 	81.12 	99.84 	228 	0 	14 	201 	0 	10.2 	12.58 	0 	625 	0 	1.28 	0 	144 	2.91
######## 	175 	244 	13 	28 	116.22 	87.36 	81.12 	99.84 	228 	0 	12.53 	201 	20 	10.2 	12.58 	0 	406.25 	0 	1.79 	0 	144 	2.91
######## 	175 	244 	5 	28 	116.22 	87.36 	81.12 	99.84 	228 	0 	12.39 	201 	34 	10.2 	12.58 	0 	218.75 	0 	2.82 	0 	144 	2.91
######## 	175 	244 	5 	28 	116.22 	87.36 	81.12 	99.84 	228 	0.02 	12.39 	201 	34 	10.2 	18.87 	0 	218.75 	0 	3.84 	0 	145 	2.91
######## 	174 	244 	5 	28 	116.22 	87.36 	81.12 	99.84 	228 	0 	12.39 	201 	34 	9.8 	18.87 	0 	218.75 	0 	3.84 	0 	145 	2.91
######## 	191 	244 	5 	28 	116.22 	87.36 	81.12 	99.84 	228 	0 	12.39 	201 	57 	9.8 	0 	0 	0 	0 	0 	0 	145 	2.91
######## 	191 	244 	5 	28 	116.22 	87.36 	81.12 	99.84 	228 	0 	12.39 	201 	96 	9.8 	0 	0 	0 	0 	0 	0 	145 	2.91
######## 	191 	244 	5 	28 	116.22 	87.36 	81.12 	99.84 	228 	0 	12.39 	201 	111 	9.8 	0 	0 	0 	0 	0 	0 	145 	2.91
######## 	190 	244 	5 	28 	116.22 	87.36 	81.12 	99.84 	228 	0 	12.39 	201 	111 	9.8 	0 	0 	0 	0 	0 	0 	145 	2.91
######## 	190 	244 	5 	28 	116.22 	87.36 	81.12 	99.84 	228 	0 	12.31 	201 	111 	9.8 	0 	0 	0 	0 	0 	0 	145 	2.91
######## 	190 	244 	5 	28 	116.22 	87.36 	81.12 	99.84 	228 	0.18 	8.94 	201 	111 	9.8 	0 	0 	0 	0 	0 	0 	145 	2.91
######## 	190 	180 	5 	28 	116.22 	87.36 	81.12 	99.84 	228 	0.06 	10.56 	201 	117 	9.8 	37.74 	0 	218.75 	0 	4.1 	0 	145 	2.91
######## 	175 	180 	5 	28 	116.22 	87.36 	81.12 	99.84 	228 	0.06 	11.07 	201 	103 	9.8 	113.22 	0 	1125 	0 	4.35 	5 	145 	2.91
######## 	174 	244 	23 	28 	116.22 	87.36 	81.12 	99.84 	228 	0.92 	14 	201 	74 	10.2 	75.48 	0 	1750 	0 	2.05 	3 	145 	2.91
######## 	174 	244 	29 	28 	116.22 	87.36 	81.12 	99.84 	228 	0.92 	14 	201 	72 	10.2 	50.32 	0 	1781.25 	0 	1.54 	2 	145 	2.91
######## 	173 	244 	26 	28 	116.22 	87.36 	81.12 	99.84 	228 	0.92 	14 	201 	69 	17.65 	56.61 	9.02 	1593.75 	0 	3.07 	5 	145 	2.91
######## 	174 	112 	26 	28 	116.22 	87.36 	81.12 	99.84 	228 	0.92 	14 	201 	67 	24.31 	194.99 	0 	2062.5 	4 	4.35 	9 	144 	2.91
######## 	175 	116 	28 	28 	116.22 	87.36 	81.12 	99.84 	228 	0.82 	14 	201 	65 	25.49 	207.57 	0 	1906.25 	9 	5.12 	10 	144 	2.91
######## 	175 	116 	20 	28 	116.22 	87.36 	81.12 	99.84 	228 	0.9 	14 	201 	63 	26.67 	226.44 	0 	1750 	8 	6.14 	11 	144 	2.91
######## 	170 	116 	19 	28 	116.22 	87.36 	81.12 	99.84 	228 	0.92 	14 	201 	61 	27.45 	251.6 	0 	1781.25 	7 	6.66 	12 	144 	2.91
######## 	167 	112 	19 	28 	116.22 	87.36 	81.12 	99.84 	228 	0.94 	14 	201 	58 	27.84 	270.47 	0 	1843.75 	7 	6.91 	13 	144 	2.91
######## 	175 	116 	20 	28 		87.36 	81.12 	99.84 	228 	0.94 	14 	201 	55 	28.24 	301.92 	0 	2000 	5 	6.91 	14 	145 	2.91
######## 	174 	116 	21 	28 	116.22 	87.36 	81.12 	99.84 	228 	0.94 	14 	201 	55 	28.24 	308.21 	0 	2062.5 	4 	6.91 	15 	145 	2.91
######## 	175 	116 		28 	116.22 	87.36 	81.12 	99.84 	228 	0.94 	14 	201 	53 	26.27 	301.92 	0 	2218.75 		4.61 	10 	145 	2.91
######## 	166 	116 	24 		116.22 	87.36 	81.12 	99.84 	228 	0.92 	14 	201 	46 	19.22 		0 	2.3 		145 	2.91
######## 	174 	116 	35 	28 	116.22 	87.36 	81.12 	99.84 	228 	0.88 	14 	201 	46 	13.33 	81.77 	0 	2312.5 	1 	1.54 	3 	144 	2.91
######## 	172 	116 	38 	28 	116.22 	87.36 	81.12 	99.84 	228 	0.92 	14 	201 	46 	10.59 	50.32 	0 	2250 	0 	1.28 	3 	144 	2.91
######## 	174 	244 	38 	28 	116.22 	87.36 		14.07 	201 	46
######## 		0 	1843.75 	0 	1.79 	3 	144 	2.91
######## 	175 	116 	31 	29 	116.22 	87.36 	81.12 	99.06 	228 	0.55 	14.07 	201 	48 	14.51 	75.48 	0 	1875 	0 	1.79 	3 	144 	2.91
######## 	175 	116 	31 	29 	116.22 	87.36 	81.12 	85.8 	228 	0.58 	14.07 	201 	48 	17.25 	94.35 	0 	1875 	0 	2.3 	4 	143 	2.91
######## 	172 	116 	29 	29 	116.22 	87.36 	81.12 	96.72 	228 	0.18 	14.07 	201 	48 	17.25 	106.93 	0 	1906.25 	0 	2.56 	5 	143 	2.91
######## 	170 	116 	31 	29 	116.22 	87.36 	81.12 	88.92 	228 	0.62 	14.07 	201 	48 	17.65 	106.93 	0 	1906.25 	0 	2.56 	5 	144 	2.91
######## 	174 	112 	30 	29 	116.22 	87.36 	81.12 	98.28 	228 	0.62 	14.07 	201 	48 	17.25 	106.93 	0 	1937.5 	0 	2.3 	4 	144 	2.91
######## 	175 	116 	31 	29 	116.22 	87.36 	81.12 	91.26 	228 	0.04 	14 	201 	48 	18.43 	119.51 	0 	1937.5 	0 	2.56 	5 	144 	2.91
######## 	175 	116 	31 	29 	116.22 	87.36 	81.12 	105.3 	228 	0.06 	14 	201 	48 	19.22 	132.09 	0 	2000 	0 	3.07 	6 	144 	2.91
######## 	175 	116 	34 	29 	116.22 	87.36 	81.12 	110.76 	228 	0.82 	14 	201 	48 	20 	138.38 	0 	2000 	0 	3.07 	6 	144 	2.91
######## 	166 	116 	33 	29 	116.22 	87.36 	81.12 	96.72 	228 	0.23 	14.07 	201 	48 	20.78 	150.96 	0 	2031.25 	0 	3.33 	7 	144 	2.91
######## 	174 	112 	33 	29 	116.22 	87.36 	81.12 	113.1 	228 	0.78 	14 	201 	48 	21.18 	163.54 	0 	2093.75 	0 	3.33 	7 	144 	2.91
######## 	171 	116 	32 	29 	116.22 	87.36 	81.12 	105.3 	228 	0.16 	14 	201 	48 	21.18 	169.83 	0 	2125 	2 	3.33 	7 	144 	2.91
######## 	174 	112 	32 	29 	116.22 	87.36 	81.12 	106.86 	228 	0.76 	14 	201 	48 	20.78 	169.83 	0 	2156.25 	0 	2.82 	6 	144 	2.91
######## 	175 	240 	36 	29 	116.22 	87.36 	81.12 	89.7 	228 	0.92 	14.07 	201 	48 	10.2 	56.61 	0 	2125 	0 	1.28 	2 	144 	2.91
######## 	174 	244 	37 	29 	116.22 	87.36 	81.12 	99.84 	228 	0.9 	13.93 	201 	48 	10.2 	44.03 	0 	1687.5 	0 	0 	0 	144 	2.91
######## 	174 	244 	30 	29 	116.22 	87.36 	81.12 	99.84 	228 	0.02 	14.07 	201 	48 	10.2 	37.74 	0 	1187.5 	0 	1.79 	2 	144 	2.91
######## 	175 	240 	21 	29 	116.22 	87.36 	81.12 	103.74 	228 	0 	14 	201 	48 	10.2 	37.74 	0 	1031.25 	0 	2.05 	2 	144 	2.91
######## 	175 	244 	13 	29 	116.22 	87.36 	81.12 	109.98 	228 	0.64 	14 	201 	48 	10.2 	37.74 	0 	968.75 	0 	2.05 	2 	144 	2.91
######## 	174 	244 	11 	29 	116.22 	87.36 	81.12 	104.52 	228 	0.94 	14 	201 	48 	10.2 	37.74 	0 	906.25 	0 	2.05 	1 	144 	2.91
######## 	175 	244 	10 	29 	116.22 	87.36 	81.12 	98.28 	228 	0.96 	14 	201 	48 	10.2 	37.74 	0 	906.25 	0 	2.05 	1 	144 	2.91
######## 	175 	240 	9 	29 	116.22 	87.36 	81.12 	92.04 	228 	0.94 	14 	201 	48 	10.2 	37.74 	0 	906.25 	0 	1.79 	1 	144 	2.91
######## 	175 	244 	10 	29 	116.22 	87.36 	81.12 	85.8 	228 	0.92 	14.07 	201 	39 	10.2 	37.74 	0 	906.25 	0 	1.79 	1 	144 	2.91
######## 	174 	244 	10 	29 	116.22 	87.36 	81.12 	80.34 	228 	0.92 	14 	201 	39 	10.2 	31.45 	0 	843.75 	0 	1.79 	1 	144 	2.91
######## 	175 	244 	11 	29 	116.22 	87.36 	81.12 	74.88 	228 	0.86 	14 	201 	39 	10.2 	31.45 	0 	781.25 	0 	1.79 	1 	144 	2.91
######## 	175 	244 	11 	29 	116.22 	87.36 	81.12 	70.2 	228 	0.86 	14 	201 	39 	10.2 	31.45 	0 	718.75 	0 	1.79 	1 	144 	2.91
######## 	175 	240 	13 	29 	116.22 	87.36 	81.12 	64.74 	228 	0.88 	14.07 	201 	40 	10.2 	31.45 	0 	718.75 	0 	1.79 	1 	144 	2.91
######## 	174 	240 	12 	29 	116.22 	87.36 	81.12 	60.06 	228 	0.84 	14 	201 	40 	10.2 	31.45 	0 	718.75 	0 	1.79 	1 	144 	2.91
######## 	175 	244 	10 	29 	116.22 	87.36 	81.12 	55.38 	228 	0.6 	14 	201 	42 	10.2 	31.45 	0 	718.75 	0 	1.79 	1 	144 	2.91
######## 	174 	244 	13 	29 	116.22 	87.36 	81.12 	59.28 	228 	0.08 	14 	201 	42 	10.2 	31.45 	0 	718.75 	0 	1.79 	1 	144 	2.91
######## 	175 	244 	9 	29 	116.22 	87.36 	81.12 	61.62 	228 	0.04 	14 	201 	42 	10.2 	31.45 	0 	718.75 	0 	1.79 	1 	144 	2.91
######## 	175 	240 	12 	29 	116.22 	87.36 	81.12 	63.96 	228 	0.02 	14 	201 	43 	10.2 	31.45 	0 	718.75 	0 	1.79 	1 	144 	2.91
######## 	174 	240 	9 	29 	115.44 	87.36 	81.12 	66.3 	228 	0.02 	13.93 	201 	43 	10.2 	31.45 	0 	718.75 	0 	1.79 	1 	144 	2.89
######## 	174 	244 	15 	29 	115.44 	87.36 	81.12 	68.64 	228 	0.02 	14 	201 	43 	10.2 	31.45 	0 	718.75 	0 	2.05 	1 	144 	2.89
######## 	175 	244 	10 	29 	115.44 	87.36 	81.12 	71.76 	228 	0.02 	14 	201 	44 	10.2 	31.45 	0 	718.75 	0 	1.79 	1 	144 	2.89
######## 	174 	244 	10 	29 	115.44 	87.36 	81.12 	73.32 	228 	0.02 	14 	201 	44 	10.2 	31.45 	0 	718.75 	0 	1.79 	1 	144 	2.87
######## 	175 	244 	9 	29 	114.66 	87.36 	81.12 	76.44 	228 	0.02 	14 	201 	44 	10.2 	25.16 	0 	687.5 	0 	1.79 	1 	144 	2.87
######## 	174 	244 	13 	29 	114.66 	87.36 	81.12 	78.78 	228 	0.02 	14 	201 	46 	10.2 	31.45 	0 	687.5 	0 	2.05 	1 	144 	2.87
######## 	175 	248 	10 	29 	114.66 	87.36 	81.12 	81.12 	228 	0.02 	14 	201 	61 	10.2 	31.45 	0 	718.75 	0 	2.05 	1 	144 	2.87
######## 	174 	252 	9 	29 	113.88 	87.36 	81.12 	83.46 	228 	0.02 	14 	201 	61 	10.2 	37.74 	0 	781.25 	0 	2.05 	1 	144 	2.85
######## 	174 	252 	3 	29 	113.88 	87.36 	81.12 	86.58 	228 	0.02 	14 	201 	61 	12.55 	37.74 	0 	843.75 	0 	2.3 	2 	144 	2.85
######## 	175 	124 	7 	29 	113.88 	87.36 	81.12 	89.7 	228 	0.04 	14.07 	201 	61 	17.65 	81.77 	0.39 	1218.75 	0 	3.33 	4 	144 	2.85
######## 	174 	120 	26 	29 	113.88 	87.36 	81.12 	99.84 	228 	0.02 	14 	201 	61 	25.1 	188.7 	0 	2562.5 	0 	3.58 	9 	144 	2.85
######## 	172 	112 	33 	29 	113.88 	87.36 	81.12 	130.26 	228 	0.02 	14 	201 	52 	27.45 	283.05 	0 	2906.25 	0 	4.61 	14 	145 	2.85
######## 	166 	116 	32 	29 	113.88 	87.36 	81.12 	139.62 	228 	0.88 	14 	201 	51 	25.88 	295.63 	0 	3031.25 	0 	3.84 	12 	145 	2.85
######## 	174 	116 	33 	29 	113.88 	87.36 	81.12 	115.44 	228 	0.9 	14 	201 	47 	24.31 	257.89 	0 	3156.25 	0 	3.33 	11 	145 	2.85
######## 	173 	116 	34 	29 	113.88 	87.36 	81.12 	88.92 	228 	0.68 	14 	201 	47 	24.31 	251.6 	0 	3281.25 	0 	3.33 	11 	146 	2.85
######## 	174 	112 	35 	29 	113.88 	87.36 	81.12 	109.98 	228 	0.84 	14 	201 	47 	24.31 	251.6 	0 	3375 	0 	3.07 	11 	146 	2.85
######## 	173 	116 	35 	29 	113.88 	87.36 	81.12 	106.08 	228 	0.14 	14 	201 	47 	24.31 	251.6 	0 	3500 	0 	3.07 	11 	146 	2.85
######## 	175 	116 	35 	29 	113.88 	87.36 	81.12 	94.38 	228 	0.49 	14 	201 	47 	24.31 	251.6 	0 	3531.25 	0 	3.07 	11 	146 	2.85
######## 	175 	112 	35 	29 	113.88 	87.36 	81.12 	105.3 	228 	0.82 	14 	201 	47 	24.71 	257.89 	0 	3656.25 	0 	3.07 	12 	147 	2.85
######## 	175 	112 	35 	29 	113.88 	87.36 	81.12 	111.54 	228 	0.82 	14 	201 	50 	26.27 	289.34 	0 	3750 	0 	2.82 	11 	147 	2.85
######## 	175 	116 	38 	29 	113.88 	87.36 	81.12 	90.48 	228 	0.9 	14 	201 	46 	18.43 	138.38 	0 	3687.5 	0 	1.79 	7 	147 	2.85
######## 	175 	116 	39 	29 	113.88 	87.36 	81.12 	63.18 	228 	0.35 	14 	201 	46 	10.2 	69.19 	0 	3593.75 	0 	1.28 	4 	147 	2.85
######## 	174 	240 	40 	29 	113.88 	87.36 	81.12 	99.84 	228 	0.08 	14.07 	201 	46 	14.51 	69.19 	0 	2968.75 	0 	1.54 	4 	147 	2.85
######## 	174 	116 	38 	29 	113.88 	87.36 	81.12 	89.7 	228 	0.74 	14 	201 	46 	21.57 	150.96 	0 	2093.75 	0 	3.07 	6 	146 	2.85
######## 	175 	116 	34 	29 	113.88 	87.36 	81.12 	101.4 	228 	0.14 	14 	201 	46 	21.57 	182.41 	0 	2250 	0 	3.33 	8 	147 	2.85
######## 	174 	112 	32 	29 	113.88 	87.36 	81.12 	113.1 	228 	0.82 	14 	201 	46 	21.57 	182.41 	0 	2250 	0 	3.33 	8 	147 	2.85
######## 	174 	112 	33 	29 	113.88 	87.36 	81.12 	99.06 	228 	0.29 	14 	201 	46 	21.96 	188.7 	0 	2281.25 	0 	3.58 	8 	147 	2.85
######## 	175 	116 	33 	29 	113.88 	87.36 	81.12 	111.54 	228 	0.84 	14 	201 	46 	21.96 	194.99 	0 	2343.75 	0 	3.33 	8 	147 	2.85
######## 	175 	116 	33 	29 	113.88 	87.36 	81.12 	94.38 	228 	0.43 	14 	201 	46 	21.96 	194.99 	0 	2375 	0 	3.58 	9 	147 	2.85
######## 	174 	112 	33 	29 	113.88 	87.36 	81.12 	101.4 	228 	0.78 	14 	201 	46 	22.35 	194.99 	0 	2406.25 	0 	3.33 	8 	147 	2.85
######## 	167 	116 	33 	29 	113.88 	87.36 	81.12 	104.52 	228 	0.43 	14 	201 	46 	23.92 	220.15 	0 	2468.75 	0 	3.84 	10 	147 	2.85
######## 	172 	112 	30 	29 	113.88 	87.36 	81.12 	109.98 	228 	0.04 	14 	201 	58 	30.98 	333.37 	0 	2531.25 	0 	5.89 	15 	147 	2.85
######## 	170 	116 	27 	29 	113.88 	87.36 	81.12 	124.8 	228 	0.88 	14 	201 	58 	31.37 	389.98 	0 	2687.5 	0 	6.14 	17 	148 	2.85
######## 	171 	116 	26 	29 	113.88 	87.36 	81.12 	103.74 	228 	0.84 	14 	201 	58 	31.37 	434.01 	0 	2843.75 	0 	6.14 	18 	148 	2.85
######## 	167 	112 	26 	29 	113.88 	87.36 	81.12 	81.9 	228 	0.8 	14 	201 	58 	31.37 	471.75 	0 	3000 	0 	6.14 	19 	148 	2.85
######## 	171 	116 	25 	29 	113.88 	87.36 	81.12 	81.12 	228 	0.84 	14 	201 	58 	31.37 	509.49 	0 	3156.25 	0 	5.89 	19 	149 	2.85
######## 	170 	116 	26 	29 	113.88 	87.36 	81.12 	81.9 	228 	0.53 	14 	201 	53 	27.06 	427.72 	0 	3312.5 	0 	4.35 	15 	149 	2.85
######## 	167 	112 	32 	29 	113.88 	87.36 	81.12 	73.32 	228 	0.08 	14 	201 	51 	26.67 	345.95 	0 	3406.25 	0 	4.1 	14 	149 	2.85
######## 	175 	116 	34 	29 	113.88 	87.36 	81.12 	84.24 	228 	0.9 	14 	201 	46 	20.39 	194.99 	0 	3406.25 	0 	2.05 	7 	149 	2.85
######## 	171 	116 	37 	29 	113.88 	87.36 	81.12 	58.5 	228 	0.8 	14 	201 	46 	19.22 	157.25 	0 	3375 	0 	1.79 	6 	149 	2.85
######## 	175 	116 	38 	28 	113.88 	87.36 	81.12 	60.84 	228 	0.06 	14 	201 	44 	19.61 	150.96 	0 	3375 	0 	2.05 	7 	149 	2.85
######## 	175 	116 	38 	28 	113.88 	87.36 	81.12 	77.22 	228 	0.78 	14 	201 	44 	20.78 	157.25 	0 	3312.5 	0 	2.3 	8 	148 	2.85
######## 	170 	116 	35 	28 	113.88 	87.36 	81.12 	88.92 	228 	0.04 	14 	201 	45 	23.14 	201.28 	0 	3343.75 	0 	2.82 	10 	148 	2.85
######## 	175 	116 	35 	28 	113.88 	87.36 	81.12 	117.78 	228 	0.76 	14 	201 	45 	23.53 	213.86 	0 	3343.75 	0 	2.82 	10 	148 	2.85
######## 	175 	116 	35 	28 	113.88 	87.36 	81.12 	116.22 	228 	0.62 	14 	201 	44 	19.61 	163.54 	0 	3312.5 	0 	2.05 	7 	148 	2.85
######## 	174 	116 	38 	28 	113.88 	87.36 	81.12 	97.5 	228 	0.9 	14 	201 	44 	18.82 	138.38 	0 	3343.75 	0 	1.79 	6 	148 	2.85
######## 	174 	116 	38 	28 	113.88 	87.36 	81.12 	71.76 	228 	0.64 	14 	201 	44 	19.22 	138.38 	0 	3281.25 	0 	2.05 	7 	148 	2.85
######## 	175 	112 	37 	28 	113.88 	87.36 	81.12 	95.94 	228 	0.31 	14 	201 	70 	41.96 	452.88 	0 	3343.75 	0 	6.4 	22 	148 	2.85
######## 	174 	116 	28 	28 	113.88 	87.36 	81.12 	121.68 	228 	0.86 	13.93 	201 	73 	41.57 	654.16 	0 	3531.25 	0 	9.98 	37 	149 	2.85
######## 	167 	116 	24 	28 	113.88 	87.36 	81.12 	99.84 	228 	0.96 	13.93 	201 	58 	19.22 	371.11 	0 	3656.25 	0 	1.79 	7 	149 	2.85
######## 	174 	240 	40 	28 	113.88 	87.36 	81.12 	77.22 	228 	0.86 	14 	201 	44 	10.2 	62.9 	0 	3593.75 	0 	0 	0 	149 	2.85
######## 	175 	244 	40 	28 	113.88 	87.36 	81.12 	99.84 	228 	0.76 	14.07 	201 	44 	10.2 	37.74 	0 	3593.75 	0 	0 	0 	149 	2.85
######## 	174 	240 	40 	28 	113.88 	87.36 	81.12 	99.84 	228 	0 	14.07 	201 	44 	10.2 	44.03 	0 	3437.5 	0 	1.28 	4 	149 	2.85
######## 	174 	116 	40 	28 	113.88 	87.36 	81.12 	99.84 	228 	0.02 	14.07 	201 	44 	17.25 	94.35 	0 	3406.25 	0 	1.54 	5 	149 	2.85
######## 	172 	116 	39 	28 	113.88 	87.36 	81.12 	83.46 	228 	0.43 	14 	201 	47 	24.31 	213.86 	0 	3375 	0 	2.82 	10 	148 	2.85
######## 	174 	112 	35 	28 	113.88 	87.36 	81.12 	115.44 	228 	0.06 	14 	201 	48 	25.1 	257.89 	0 	3375 	0 	3.33 	12 	148 	2.85
######## 	167 	112 	35 	28 	113.88 	87.36 	81.12 	114.66 	228 	0.84 	14 	201 	49 	25.49 	264.18 	0 	3437.5 	0 	3.33 	12 	149 	2.85
######## 	171 	116 	35 	28 	113.88 	87.36 	81.12 	98.28 	228 	0.39 	14 	201 	44 	20.39 	194.99 	0 	3437.5 	0 	2.3 	8 	149 	2.85
######## 	174 	116 	37 	28 	113.88 	87.36 	81.12 	78.78 	228 	0.84 	14 	201 	44 	18.82 	144.67 	0 	3437.5 	0 	1.79 	6 	149 	2.85
######## 	175 	112 	40 	28 	113.88 	87.36 	81.12 	54.6 	228 	0.7 	14 	201 	44 	17.25 	119.51 	0 	3406.25 	0 	1.54 	5 	148 	2.85
######## 	174 	112 	40 	28 	113.88 	87.36 	81.12 	71.76 	228 	0.84 	14 	201 	44 	10.2 	50.32 	0 	3375 	0 	1.28 	4 	148 	2.85
######## 	175 	244 	40 	28 	113.88 	87.36 	81.12 	99.84 	228 	0.47 	14.07 	201 	44 	10.2 	44.03 	0 	3250 	0 	0 	0 	148 	2.85
######## 	175 	112 	40 	28 	113.88 	87.36 	81.12 	99.84 	228 	0.02 	14 	201 	44 	14.51 	69.19 	0 	3250 	0 	1.54 	5 	148 	2.85
######## 	174 	116 	39 	28 	113.88 	87.36 	81.12 	90.48 	228 	0.9 	14 	201 	44 	17.65 	106.93 	0 	3156.25 	0 	1.54 	5 	148 	2.85
######## 	174 	112 	39 	28 	113.88 	87.36 	81.12 	69.42 	228 	0.18 	14 	201 	44 	19.22 	125.8 	0 	3093.75 	0 	2.3 	7 	148 	2.85
######## 	175 	112 	35 	28 	113.88 	87.36 	81.12 	97.5 	228 	0.04 	14 	201 	47 	24.71 	226.44 	0 	3156.25 	0 	3.33 	11 	148 	2.85
######## 	175 	116 	34 	28 	113.88 	87.36 	81.12 	133.38 	228 	0.66 	14 	201 	49 	26.27 	270.47 	0 	3156.25 	0 	3.84 	12 	148 	2.85
######## 	166 	116 	33 	28 	113.88 	87.36 	81.12 	111.54 	228 	0.82 	14 	201 	50 	26.27 	289.34 	0 	3218.75 	0 	3.84 	13 	149 	2.85
######## 	174 	116 	34 	28 	113.88 	87.36 	81.12 	87.36 	228 	0.39 	14 	201 	50 	26.27 	301.92 	0 	3312.5 	0 	3.84 	13 	149 	2.85
######## 	174 	112 	34 	28 	113.88 	87.36 	81.12 	95.16 	228 	0.82 	14 	201 	44 	20.78 	226.44 	0 	3343.75 	0 	2.3 	8 	149 	2.85
######## 	166 	116 	38 	28 	113.88 	87.36 	81.12 	71.76 	228 	0.92 	14 	201 	44 	13.73 	88.06 	0 	3250 	0 	1.28 	4 	149 	2.85
######## 	175 	112 	40 	28 	113.88 	87.36 	81.12 	47.58 	228 	0.9 	14 	201 	44 	17.25 	106.93 	0 	3312.5 	0 	1.54 	5 	149 	2.85
######## 	174 	112 	39 	28 	113.88 	87.36 	81.12 	35.88 	228 	0.04 	14 	201 	45 	23.53 	207.57 	0 	3281.25 	0 	2.56 	8 	149 	2.85
######## 	174 	112 	35 	28 	113.88 	87.36 	81.12 	71.76 	228 	0.02 	14 	201 	48 	25.1 	245.31 	0 	3312.5 	0 	3.07 	10 	149 	2.85
######## 	172 	116 	35 	28 	113.88 	87.36 	81.12 	110.76 	228 	0.8 	14 	201 	44 	21.18 	188.7 	0 	3343.75 	0 	2.3 	8 	149 	2.85
######## 	175 	112 	35 	28 	113.88 	87.36 	81.12 	87.36 	228 	0.33 	14 	201 	44 	21.18 	176.12 	0 	3343.75 	0 	2.3 	8 	149 	2.85
######## 	175 	116 	35 	28 	113.88 	87.36 	81.12 	92.04 	228 	0.78 	14 	201 	49 	25.88 	239.02 	0 	3343.75 	0 	3.33 	11 	149 	2.85
######## 	170 	116 	34 	28 	113.88 	87.36 	81.12 	116.22 	228 	0.06 	14 	201 	52 	27.45 	314.5 	0 	3406.25 	0 	4.1 	14 	149 	2.85
######## 	170 	116 	34 	28 	113.88 	87.36 	81.12 	106.86 	228 	0.84 	14 	201 	52 	27.45 	339.66 	0 	3531.25 	0 	3.84 	14 	150 	2.85
######## 	175 	116 	34 	28 	113.88 	87.36 	81.12 	95.16 	228 	0.51 	14 	201 	44 	12.16 	144.67 	0 	3468.75 	0 	1.28 	4 	150 	2.85
######## 	174 	240 	40 	28 	113.88 	87.36 	81.12 	99.84 	228 	0.88 	14.07 	201 	44 	10.59 	50.32 	0 	2937.5 	0 	1.28 	4 	150 	2.85
######## 	174 	116 	39 	28 	113.88 	87.36 	81.12 	98.28 	228 	0.92 	14 	201 	44 	15.29 	81.77 	0 	2250 	0 	1.79 	4 	149 	2.85
######## 	174 	112 	37 	28 	113.88 	87.36 	81.12 	82.68 	228 	0.92 	14 	201 	44 	15.69 	94.35 	0 	2343.75 	0 	1.79 	4 	149 	2.85
######## 	172 	112 	38 	28 	113.88 	87.36 	81.12 	67.86 	228 	0.9 	14 	201 	44 	10.98 	56.61 	0 	2343.75 	0 	1.28 	3 	149 	2.85
######## 	174 	116 	38 	28 	113.88 	87.36 	81.12 	53.04 	228 	0.8 	14 	201 	44 	12.94 	56.61 	0 	2281.25 	0 	1.28 	3 	149 	2.85
######## 	175 	116 	38 	28 	113.88 	87.36 	81.12 	38.22 	228 	0.68 	14 	201 	44 	14.12 	75.48 	0 	2250 	0 	1.54 	3 	149 	2.85
######## 	175 	116 	38 	28 	113.88 	87.36 	81.12 	26.52 	228 	0.23 	14.07 	201 	44 	16.47 	81.77 	0 	2218.75 	0 	1.79 	4 	149 	2.85
######## 	174 	116 	36 	28 	113.88 	87.36 	81.12 	44.46 	228 	0.04 	14 	201 	44 	17.25 	106.93 	0 	2250 	0 	2.05 	4 	149 	2.85
######## 	171 	116 	36 	28 	113.88 	87.36 	81.12 	62.4 	228 	0.04 	14 	201 	44 	17.65 	106.93 	0 	2250 	0 	2.3 	5 	149 	2.85
######## 	173 	116 	36 	28 	113.88 	87.36 	81.12 	80.34 	228 	0.08 	14.07 	201 	44 	10.2 	62.9 	0 	2187.5 	0 	1.28 	2 	149 	2.85
######## 	174 	240 	37 	28 	113.88 	87.36 	81.12 	73.32 	228 	0.76 	14.07 	201 	44 	10.2 	37.74 	0 	1812.5 	0 	0 	0 	149 	2.85
######## 	174 	244 	35 	28 	113.88 	87.36 	81.12 	99.84 	228 	0.02 	14 	201 	44 	10.2 	37.74 	0 	1343.75 	0 	0 	0 	149 	2.85
######## 	175 	244 	23 	28 	113.88 	87.36 	81.12 	100.62 	228 	0 	14 	201 	44 	10.2 	31.45 	0 	1000 	0 	1.79 	1 	149 	2.85
######## 	175 	240 	16 	28 	113.88 	87.36 	81.12 	107.64 	228 	0 	14 	201 	44 	10.2 	37.74 	0 	968.75 	0 	1.79 	1 	149 	2.85
######## 	175 	240 	11 	28 	113.88 	87.36 	81.12 	109.2 	228 	0.88 	14 	201 	44 	10.2 	37.74 	0 	906.25 	0 	1.79 	1 	149 	2.85
######## 	174 	240 	10 	28 	113.88 	87.36 	81.12 	102.96 	228 	0.92 	14 	201 	44 	10.2 	31.45 	0 	875 	0 	1.79 	1 	149 	2.85
######## 	175 	244 	9 	28 	113.88 	87.36 	81.12 	97.5 	228 	0.92 	14 	201 	44 	10.2 	31.45 	0 	875 	0 	1.79 	1 	149 	2.85
######## 	175 	244 	9 	28 	113.88 	87.36 	81.12 	92.04 	228 	0.9 	14 	201 	44 	10.2 	31.45 	0 	875 	0 	1.79 	1 	149 	2.85
######## 	175 	240 	10 	28 	113.88 	87.36 	81.12 	85.8 	228 	0.88 	14 	201 	38 	10.2 	31.45 	0 	875 	0 	1.79 	1 	149 	2.85
######## 	175 	244 	10 	28 	113.88 	87.36 	81.12 	80.34 	228 	0.86 	14 	201 	38 	10.2 	31.45 	0 	812.5 	0 	1.79 	1 	149 	2.85
######## 	174 	240 	11 	28 	113.88 	87.36 	81.12 	74.88 	228 	0.82 	14 	201 	38 	10.2 	31.45 	0 	718.75 	0 	1.79 	1 	149 	2.85
######## 	175 	244 	14 	28 	113.88 	87.36 	81.12 	70.2 	228 	0.76 	14 	201 	51 	10.2 	31.45 	0 	718.75 	0 	2.05 	1 	149 	2.85
######## 	175 	248 	13 	28 	113.88 	87.36 	81.12 	66.3 	228 	0.47 	14 	201 	54 	10.2 	37.74 	0 	750 	0 	2.05 	1 	149 	2.85
######## 	175 	252 	8 	28 	113.88 	87.36 	81.12 	70.2 	228 	0.06 	14 	201 	54 	10.2 	37.74 	0 	812.5 	0 	2.05 	1 	149 	2.85
######## 	175 	252 	8 	28 	113.88 	87.36 	81.12 	75.66 	228 	0.04 	14 	201 	54 	10.2 	37.74 	0 	843.75 	0 	2.05 	1 	149 	2.85
######## 	174 	252 	9 	28 	113.88 	87.36 	81.12 	78.78 	228 	0.04 	14 	201 	54 	10.2 	37.74 	0 	875 	0 	1.79 	1 	149 	2.85
######## 	175 	248 	10 	28 	113.88 	87.36 	81.12 	81.9 	228 	0.04 	14 	201 	54 	13.33 	44.03 	0 	968.75 	0 	2.05 	2 	149 	2.85
######## 	175 	124 	11 	28 	113.88 	87.36 	81.12 	88.14 	228 	0.02 	14 	201 	54 	20 	132.09 	0 	1843.75 	0 	3.07 	6 	149 	2.85
######## 	174 	116 	28 	28 	113.88 	87.36 	81.12 	105.3 	228 	0.02 	14 	201 	39 	20.39 	132.09 	0 	1656.25 	0 	3.58 	6 	149 	2.85
######## 	172 	124 	30 	28 	113.88 	87.36 	81.12 	121.68 	228 	0.08 	14 	201 	39 	20.39 	150.96 	0 	1843.75 	0 	3.58 	7 	149 	2.85
######## 	175 	112 	32 	28 	113.88 	87.36 	81.12 	120.9 	228 	0.84 	14 	201 	39 	19.61 	144.67 	0 	2000 	0 	3.07 	6 	149 	2.85
######## 	174 	116 	33 	28 	113.88 	87.36 	81.12 	105.3 	228 	0.86 	14 	201 	39 	14.9 	94.35 	0 	2062.5 	1 	2.05 	4 	149 	2.85
######## 	174 	112 	37 	28 	113.88 	87.36 	81.12 	91.26 	228 	0.9 	14 	201 	39 	14.9 	81.77 	0 	2062.5 	2 	1.79 	3 	149 	2.85
######## 	170 	116 	37 	28 	113.88 	87.36 	81.12 	76.44 	228 	0.86 	14 	201 	39 	14.51 	75.48 	0 	2031.25 	0 	1.54 	3 	149 	2.85
######## 	175 	124 	37 	28 	113.88 	87.36 	81.12 	76.44 	228 	0.1 	14 	201 	39 	13.33 	62.9 	0 	2000 	0 	1.54 	3 	149 	2.85
######## 	175 	120 	34 	28 	113.88 	87.36 	81.12 	84.24 	228 	0.84 	14 	201 	54 	14.12 	69.19 	0 	2000 	1 	1.79 	3 	149 	2.85
######## 	175 	124 	37 	28 	113.88 	87.36 	81.12 	69.42 	228 	0.78 	14 	201 	54 	14.12 	75.48 	0 	1875 	0 	1.79 	3 	149 	2.85
######## 	175 	124 	30 	28 	113.88 	87.36 	81.12 	72.54 	228 	0.08 	14 	201 	54 	14.9 	75.48 	0 	1906.25 	0 	1.79 	3 	149 	2.85
######## 	174 	120 	30 	28 	113.88 	87.36 	81.12 	85.8 	228 	0.08 	14 	201 	54 	15.29 	88.06 	0 	1906.25 	0 	2.05 	4 	149 	2.85
######## 	174 	124 	30 	28 	113.88 	87.36 	81.12 	87.36 	228 	0.86 	14 	201 	54 	16.86 	94.35 	0 	1843.75 	0 	2.3 	4 	149 	2.85
######## 	175 	124 	29 	28 	113.88 	87.36 	81.12 	81.9 	228 	0.16 	14 	201 	42 	17.25 	100.64 	0 	1875 	0 	2.3 	4 	149 	2.85
######## 	167 	112 	29 	28 	113.88 	87.36 	81.12 	81.12 	228 	0.23 	14 	201 	39 	20.39 	144.67 	0 	1968.75 	1 	3.07 	6 	149 	2.85
######## 	174 	116 	32 	28 	113.88 	87.36 	81.12 	98.28 	228 	0.06 	14 	201 	39 	20.78 	157.25 	0 	2062.5 	0 	3.33 	7 	149 	2.85
######## 	175 	116 	33 	28 	113.88 	87.36 	81.12 	108.42 	228 	0.8 	14 	201 	39 	20.78 	163.54 	0 	2093.75 	0 	3.07 	6 	149 	2.85
######## 	175 	116 	33 	28 	113.88 	87.36 	81.12 	93.6 	228 	0.31 	14 	201 	39 	20.78 	163.54 	0 	2187.5 	0 	3.07 	7 	149 	2.85
######## 	175 	116 	33 	28 	113.88 	87.36 	81.12 	100.62 	228 	0.84 	14 	201 	39 	20.78 	163.54 	0 	2281.25 	0 	2.82 	6 	149 	2.85
######## 	175 	116 	35 	28 	113.88 	87.36 	81.12 	85.8 	228 	0.9 	14 	201 	39 	10.2 	56.61 	0 	2218.75 	0 	1.28 	3 	149 	2.85
######## 	174 	244 	36 	28 	113.88 	87.36 	81.12 	70.98 	228 	0.84 	14 	201 	39 	10.2 	37.74 	0 	1875 	0 	0 	0 	149 	2.85
######## 	175 	240 	35 	28 	113.88 	87.36 	81.12 	99.84 	228 	0.06 	13.56 	201 	39 	10.2 	37.74 	0 	1375 	0 	0 	0 	149 	2.85
######## 	174 	244 	24 	28 	113.88 	87.36 	81.12 	100.62 	228 	0 	14 	201 	39 	10.2 	31.45 	0 	968.75 	0 	1.79 	1 	149 	2.85
######## 	174 	244 	18 	28 	113.88 	87.36 	81.12 	106.86 	228 	0 	14 	201 	39 	10.2 	37.74 	0 	937.5 	0 	1.79 	1 	149 	2.85
######## 	174 	244 	11 	28 	113.88 	87.36 	81.12 	110.76 	228 	0.86 	14 	201 	39 	10.2 	37.74 	0 	875 	0 	2.05 	1 	149 	2.85
######## 	175 	240 	9 	28 	113.88 	87.36 	81.12 	105.3 	228 	0.94 	14 	201 	39 	10.2 	37.74 	0 	812.5 	0 	2.05 	1 	149 	2.85
######## 	175 	244 	9 	28 	113.88 	87.36 	81.12 	99.84 	228 	0.94 	14 	201 	39 	10.2 	31.45 	0 	781.25 	0 	2.05 	1 	149 	2.85
######## 	174 	244 	8 	28 	113.88 	87.36 	81.12 	95.16 	228 	0.94 	14 	201 	48 	10.2 	37.74 	0 	812.5 	0 	2.05 	1 	149 	2.85
######## 	175 	244 	7 	28 	113.88 	87.36 	81.12 	89.7 	228 	0.92 	14 	201 	43 	10.2 	37.74 	0 	843.75 	0 	2.05 	1 	149 	2.85
######## 	174 	252 	9 	28 	113.88 	87.36 	81.12 	83.46 	228 	0.9 	14 	201 	54 	10.2 	37.74 	0 	875 	0 	2.05 	1 	149 	2.85
######## 	174 	244 	10 	28 	113.88 	87.36 	81.12 	78.78 	228 	0.86 	13.93 	201 	53 	10.2 	37.74 	0 	906.25 	0 	1.79 	1 	149 	2.85
######## 	175 	252 	10 	28 	113.88 	87.36 	81.12 	71.76 	228 	0.82 	13.93 	201 	54 	10.2 	37.74 	0 	906.25 	0 	1.79 	1 	149 	2.85
######## 	170 	252 	11 	28 	113.88 	87.36 	81.12 	66.3 	228 	0.6 	13.93 	201 	51 	10.2 	37.74 	0 	906.25 	0 	1.79 	1 	149 	2.85
######## 	174 	244 	11 	28 	113.88 	87.36 	81.12 	70.2 	228 	0.12 	13.93 	201 	39 	10.2 	31.45 	0 	875 	0 	1.79 	1 	149 	2.85
######## 	175 	248 	11 	28 	113.88 	87.36 	81.12 	74.1 	228 	0.08 	14 	201 	43 	10.2 	31.45 	0 	812.5 	0 	1.79 	1 	148 	2.85
######## 	174 	244 	11 	28 	113.88 	87.36 	81.12 	77.22 	228 	0.06 	14 	201 	39 	10.2 	31.45 	0 	781.25 	0 	1.79 	1 	148 	2.85
######## 	175 	240 	10 	28 	113.88 	87.36 	81.12 	79.56 	228 	0.08 	14 	201 	39 	10.2 	31.45 	0 	750 	0 	1.79 	1 	148 	2.85
######## 	174 	244 	12 	28 	113.88 	87.36 	81.12 	82.68 	228 	0.04 	13.93 	201 	39 	10.2 	31.45 	0 	718.75 	0 	1.79 	1 	148 	2.83
######## 	175 	240 	11 	28 	113.1 	87.36 	81.12 	85.02 	228 	0.04 	13.93 	201 	39 	10.2 	31.45 	0 	750 	0 	1.79 	1 	148 	2.83
######## 	174 	244 	8 	28 	113.1 	87.36 	81.12 	87.36 	228 	0.04 	13.93 	201 	39 	10.2 	31.45 	0 	718.75 	0 	1.79 	1 	148 	2.83
######## 	174 	244 	10 	28 	113.1 	87.36 	81.12 	89.7 	228 	0.04 	13.93 	201 	39 	10.2 	31.45 	0 	750 	0 	1.79 	1 	148 	2.83
######## 	175 	244 	8 	28 	112.32 	87.36 	81.12 	92.04 	228 	0.04 	14 	201 	39 	10.2 	31.45 	0 	750 	0 	1.79 	1 	148 	2.81
######## 	174 	244 	10 	28 		201 	39 	10.2 	25.16 	0 		0 	2.05 		148 	2.85
######## 	174 	244 	9 	28 	113.88 	87.36 	81.12 	124.8 	228 	0.04 	13.93 	201 	39 	10.2 	25.16 	0 	750 	0 	1.79 	1 	148 	2.87
######## 	174 	240 	9 	28 	114.66 	87.36 	81.12 	127.14 	228 	0.04 	13.93 	201 	39 	10.2 	25.16 	0 	718.75 	0 	1.79 	1 	148 	2.87
######## 	174 	244 	8 	28 	114.66 	87.36 	81.12 	130.26 	228 	0.04 	13.93 	201 	40 	10.2 	25.16 	0 	750 	0 	2.05 	1 	148 	2.87
######## 	174 	244 	7 	28 	114.66 	87.36 	81.12 	132.6 	228 	0.06 	13.93 	201 	40 	10.2 	25.16 	0 	750 	0 	1.79 	1 	148 	2.87
######## 	166 	244 	6 	28 	115.44 	87.36 	81.12 	134.94 	228 	0.1 	13.93 	201 	39 	10.2 	25.16 	0 	750 	0 	1.79 	1 	148 	2.89
######## 	175 	244 	8 	28 	115.44 	87.36 	81.12 	137.28 	228 	0.08 	14 	201 	39 	10.2 	25.16 	0 	781.25 	0 	1.79 	1 	148 	2.89
######## 	174 	240 	7 	28 	115.44 	87.36 	81.12 	140.4 	228 	0.14 	13.93 	201 	39 	10.2 	25.16 	0 	750 	0 	1.79 	1 	148 	2.89
######## 	174 	244 	7 	28 	115.44 	87.36 	81.12 	142.74 	228 	0.33 	13.93 	201 	39 	10.2 	25.16 	0 	750 	0 	1.79 	1 	148 	2.91
######## 	174 	240 	8 	28 	116.22 	87.36 	81.12 	141.18 	228 	0.7 	13.93 	201 	39 	10.2 	25.16 	0 	750 	0 	1.79 	1 	148 	2.91
######## 	175 	244 	8 	28 	116.22 	87.36 	81.12 	138.84 	228 	0.76 	13.93 	201 	39 	10.2 	25.16 	0 	750 	0 	1.79 	1 	148 	2.91
######## 	175 	244 	8 	28 	116.22 	87.36 	81.12 	136.5 	228 	0.41 	13.93 	201 	39 	10.2 	25.16 	0 	750 	0 	1.79 	1 	148 	2.91
######## 	175 	244 	8 	28 	116.22 	87.36 	81.12 	138.84 	228 	0.25 	13.93 	201 	39 	10.2 	25.16 	0 	750 	0 	1.79 	1 	148 	2.92
######## 	174 	240 	8 	28 	117 	87.36 	81.12 	137.28 	228 	0.74 	13.93 	201 	39 	10.2 	25.16 	0 	750 	0 	1.79 	1 	148 	2.92
######## 	174 	244 	8 	28 	117 	87.36 	81.12 	136.5 	228 	0.16 	13.93 	201 	39 	10.2 	25.16 	0 	750 	0 	1.79 	1 	148 	2.92
######## 	175 	244 	8 	28 	117 	87.36 	81.12 	138.84 	228 	0.08 	13.93 	201 	39 	10.2 	25.16 	0 	750 	0 	2.05 	1 	148 	2.94
######## 	175 	244 	8 	28 	117.78 	87.36 	81.12 	141.96 	228 	0.25 	13.93 	201 	39 	10.2 	25.16 	0 	750 	0 	1.79 	1 	148 	2.94
######## 	175 	240 	8 	28 	117.78 	87.36 	81.12 	141.18 	228 	0.8 	13.93 	201 	39 	10.2 	25.16 	0 	750 	0 	1.79 	1 	148 	2.94
######## 	175 	240 	8 	28 	117.78 	87.36 	81.12 	138.06 	228 	0.8 	13.93 	201 	39 	10.2 	25.16 	0 	750 	0 	1.79 	1 	148 	2.94
######## 	174 	244
Just out of curiosity, how did you get it to post like that? I was trying to post a log a few days ago and I couldn't figure out how to get it to do that for the life of me! Sorry to post off-topic!
How are you compensating for the hacked mas? That throws your airflow off, which messes with the fuel. That's probably why you're getting knock. If you still have the honeycombs, put them back in. Hacking the mas isn't a good mod when you don't have anything to correct for the changes.
All you have to do is type [C O D E] then paste your log then type [/ C O D E] without the spaces in between though.
I just have the silencer removed and the top of the can dremeled off. I have not touched the honeycombs.
I would do a boost leak test. Your mid and high fuel trims are indicating that the ecu is trying to pull fuel due to a rich condition. Do you have anything to tune with?
Also, you don't need to log all of those values. The only ones I find useful are: RPM, TPS, Timing, Knock, Injector Pulsewidth, O2-R, Airflow. I'll also throw in coolant temp once in a while so that I can tell if the engine was warm yet or not. Fuel trims only need to be looked at once an a while. Since they don't update very fast. It's not something to be logging all the time, more of a reference as to how your tune is sitting with the ECU than anything else.
Ok Ill give that a try, I made a boost leak tester last week so ill give it a try when it stops raining. Is it a necessity to put the engine to 30 past TDC? Thats gonna be a pain to do in the driveway but im guessing if I dont all the air im pumping in will just flow out the valves?
BTW its not smoking at all, black or otherwise. Although I am getting a kind of coughing/sputter at idle somtimes. It Idles a little low sometimes but mainly sounds like a cough.
Not a requirement. Just a suggestion. I don't ever worry about it. But then again I run my tests off of an air compressor and don't have to worry about running out of air if it's going past valves and out the exhaust. I generally don't have a problem and can pressurize my IC pipes up to 30psi with no problem. I think I'm going to do a BLT tomorrow too since I just installed new TB seals.
Good Luck... and let us know the results.
The first thing you need to do is get those FT's in line. Also, here are some suggestions for data to log, because honesty, that log is a nightmare to read. :D
Log when setting FT's:
Front O2
RPM
MAFS
All FT's
Log when tuning WOT
Front O2
RPM
Timing
Knock
IDC
That will make the log easier to read and maximize the number of samples per second.
