Newb fuel pump install question?
JayRolla
5,629
34
Feb 23, 2006
Colorado Spring, Colorado
Ok I installed a fuel pump and I was reading on vfaq about it and Im scared I was missing something.
When you pull the pump out the line what should there be in between. It mentions an o ring. I had only a red plastic sleeve that went over the pump. What else should there be??
I like how you posted this as a newb install question. haha.
JayRolla you've been on here too long, that's not a newb question LOL.
When you pull the pump out, if there's not an o ring there, then that could be a problem. But if you've got it assembled and it's not leaking then you'll be fine. Let the car idle and look underneath to see if there are anyleaks. If not then you'll be fine.
Yeah, what he said, if you are missing something your car will let you know.
The o-ring should sit on top of the plastic sleeve that goes over the end of the Walbro. The o-ring and sleeve are then pushed into the hardline. Run the positive wire and ground the black wire to the assembly. Secure the pump to the assembly, clean the upper gasket surface of rust and lube the gasket with silicone for a good seal. Verify the sock is secure. Drop it back in and go.
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
