Fuel pump install question
b-morr
190
Jul 24, 2007
Aurora, Florida
Should you do it with a low amount of gas in the gas tank? Or does it not matter?
Make sure the car is fairly level when you pull the assembly.You dont want gas everywhere if your tank is topped off;)
Yup, got myself a rewire kit. And its about 3/4 tank full. So I should be fine.
Don't be a sparky. Make sure you take the battery out before doing any work on the gas tank!
Make sure that when you put the pump back in the little floater that tells you how full the tank is can move around. I installed mine and it got stuck so had to take it all apart again
I have had my fuel pump in and out many times, the only time that gas level was ever a concern was when I pulled it directly after a fill-up.
The lower the better, it doesn't really matter as long as its not full but the lower it is the less fuel has to drip off the assembly and the lower it is the more likely you will be able to see any debris that may be in your tank, mine was pretty clean but I've seen car with all sorts of crap in their tanks.
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
