New to tuning WOT and cruise log
woodnbronze24
145
Mar 14, 2009
Flint, Michigan
Here is my 10th log. Let me know what you think and I would appreciate some advice.
Issues. Knock, (obviously). My wb gauge is reading about 1 afr more rich than its logging. For some reason and the car is cruising rich (about 12:1).
Also, I have check the lock rear o2 voltage box as advised since these logs.
It looks as if your idle tune is out of whack. bump up your 0-hertz airflow slider until the air flow per rev comes up and settles at .25 . then look at your combined fuel trim, and if it's still high then you can add some dead time to the injectors until you get it to idle around zero percent on the combined fuel trim. then go for a cruise log and post up the results.
  • Wanted GSC S2 Camshafts
    GSC S2 Camshafts
    • jmt2028
  • For sale Wideband
    • Briant91
  • Wanted 560 injectors
    • AllanL
  • For sale ACT clutch 2600
    • Briant91
