New tires and shocks fresh alignment getting wheel bounce
Murdertalon
401
90
Jul 7, 2016
East side, Washington
Koni yellow kit installed, eibach lowering springs, camber kit, new riken raptor tires and now I'm getting a tire bounce on the front end while driving over 30mph. I haven't driven the car much recently but I took it out the other day and it's got a terrible front end bounce once speed is up.
Obviously first thing I'll do next time I take it out is increase the shock adjuster to stiffen it up, next I'll check tire pressure and maybe lower slightly but I was wondering if anyone else ran into this with new tires or shocks. I don't know of it's the shocks causing it or tires but it's annoying as hell on the highway the front end dribbles like a basketball just slightly.
Was going to add the rims are basically brand new and before this set of tires my worn out last set caused no issues on these rims.
Has the shocks settled yet? Normally takes a few days to settle or did you pre load them by compressing the shock a few times?
Confirm the tires are balanced correctly aswel incase,
Bouncing does normally mean springs are over powering the shock so certainly adjust the shick rebound/compression setting a bit stiffer snd see what happens, if its still doing it then check to see if any bolts are loose incase
Other then that i cannot think of anything else to look at or consider.
