new timing belt ?
beantowntsi
Oct 8, 2005
orlando, Florida
I had to change my water pump so I figured that since the belt was off to change it.
I put the new belt on and when the car is running the belt moves back and forth on the oil pump gear.I put the old belt back on it does not move.So I was thinking maybe the new belt needs to stretch a little and it could be fine. {any answers please thank you}:confused:
I put a new belt on and when the car is running the belt moves from side to side on the oil pump gear.So I put the old belt back on and it does not move from side to side.I just wanted to know if this is normal for a new belt.Does it need to brake in before it will stop moving.Or should I just not worry about it.:confused:
ya thats weird!! your sure everthing is tight and bolted down.. is it an OEM belt? did you tension it correctly.. i found that you can use a pair of o ring plyers to help turn the tensioner pully to get best tension
It should not move. You are going to have to take it back off and reset the tension on the new belt.
Mike
I got the belt from mits. dealer.And I have changed belts from the new one to the old one and the new one always moves.I have changed the belts back and forth a number of times.
ya but how come the old one does not move and the new one does every time I change them back and forth.It is only the new one not the old one.
