BryanCenterfitt
- 45
- 0
- Mar 27, 2009
cordele,
Georgia
this is a new parts list of things i have been looking at, and i am woundering what will work and wont work, and what is a wast of time maybe some one in here can give me some insight.
FJO 341B Features.........engie man.
* Direct control of fuel delivery system with self-tuning feature
* Integrated high energy direct-fire ignition system or support for OEM Coil-on-Plug ignitions
* Easy to use graphic set-up menus and datalogging using a laptop
* User defined configuration tables
* 8 trigger inputs
* 15 sensor inputs to monitor and protect the engine
* 21 control outputs (can be used for functions such as nitrous control, boost control, VVT, etc)
* Wireless link for datalogging/tuning
* Integrated GPS
FJO 341B Benefits
* Seamless integration with other FJO products
* Free updates/upgrades to software and controller firmware for the life of the product
* In-vehicle firmware update using laptop computer
* Built for the racing environment to withstand heat, vibration, dirt and water
* Free direct technical support
FJO 341B Parts Listing Jump to top of page
Kits
K3B0400
Basic 4 Cylinder System
Includes:
341B Engine Management Unit
ICD (Injector and Coil Driver - 2 coil)
Configuration Software CD
Hardware Installation Manual
Software User's manual
341B Serial Cable
Fluid Temperature Sensor
Air Pressure Sensor (1bar)
Crank Angle Speed Sensor
6 inch Crank Target
Basic Wiring Harness Kit.
$2371.00
K3B0600
Basic 6 Cylinder System
Includes:
ICD (Injector and Coil Driver - 3 coil)
341B Serial Cable
6 inch Crank Target
$2640.50
K3B0800
Basic 8 Cylinder System
Includes:
ICD (Injector and Coil Driver - 4 coil)
341B Serial Cable
6 inch Crank Target
$2982.00
Distributor Equipped Race or Street Application, 4, 6, or 8 Cylinder. Up to 14.5:1 compression ratio, nitrous-oxide, supercharged and turbo
6000-6400 HI-6 Multi-Spark CD Ignition( fireball from cran cams)
Unorthodox Racing Ultra A Pulley Kits
DSM (Mitsubishi Eclipse, Eagle Talon, Plymouth Laser) DSM 90-94 - 4-rib Alternator $63.75
DSM 95-99 Turbo - 4-rib Alternator $67.15
DSM 95-99 Turbo - 4-rib Power Steering $101.15
DSM 90-94 - 4-rib Water Pump $169.75
DSM 95-99 Turbo - 4-rib Water Pump $169.15
4 Cyl. 1.8L (C) E.F.I., 1993-1996 WAL P565 98.93( 255 walbro fuel pump)
Eclipse 4G63 2.0L turbo 35mm compression height, 17.cc- dome volume $519.20...(Wisco Piston's)
GOP0100 - Oil Pressure Gauge
(100 psig)
Gauge can be configured for dot or bar mode display and features a max/min recall function. Includes gauge, bracket and wiring. Order SHP0100 sensor separately.
...PRICES REDUCED WHILE SUPPLIES LAST
...2 left at this price (28Nov06)
$137.75
$70.00
FJO Fuel Pressure Gauge - 100 or 200 PSI
GFP0x00 - Fuel Pressure Gauge
(100 or 200 psig)
Gauge can be configured for dot or bar mode display and features a max/min recall function. Includes gauge, bracket and wiring. Order SHP0100 or SHP0200 sensor separately.
$137.75
FJO Boost Pressure Gauge - 50, 35, or 15 PSI
GBP00xx - Boost Pressure Gauge
(50, 35, or 15 psi)
Gauge can be configured for dot or bar mode display and features automatic peak boost display and max/min recall function. When the gauge senses a transition from boost to vacuum, it will display the peak boost for 3 seconds. Includes gauge, bracket and wiring. Order SHP0050 or SHP0015 sensor separately.
...7 left at this price (28Nov06)
$137.75
$70.00
FJO Temperature Gauge - Farenheit or Celsius, Liquid
GTx0010 - Fluid Temperature Gauge
(-40° to +302° Fahrenheit or
-40° to +150° Celsius)
Gauge can be configured for dot or bar mode display and features a max/min recall function. Depending on the sensor chosen, this gauge can be used for fluid temperatures such as coolant or oil (using SFT0001 or SFT0002 sensor). Includes gauge, bracket and wiring. Order SFT0001, SFT0002, or SAT0010 separately.
$137.75
FJO Temperature Gauge - Farenheit or Celcius, Air
GTx0020 - Fast Response Air Temperature Gauge
Gauge can be configured for dot or bar mode display and features a max/min recall function. This gauge can be used for fast-changing air temperature measurements where the sensor will not come in contact with fluids (open sensor element for faster response times). Includes gauge, bracket and wiring. Order SAT0020 sensor separately.
...1 left at this price (28Nov06) $137.75
$70.00
Sensors
FJO
Pressure Sensors
(SHP0015, 0050, 0100, 0200, or 1500)
Laser-welded STAINLESS STEEL package, -40°C to +125°C calibrated, 1/8NPT-27 MALE pressure port, 7/8" HEX, 2.85" overall length
$91
FJO
SFT0001 - Fluid Temperature Sensor
(Standard Thread)
Standard, -40°C to +135°C (-40°F to +275°F), Brass,
3/8-18 NPT MALE, 3/4" HEX, 2.25" overall length
$14.75
FJO
SFT0002 - Fluid Temperature Sensor
(Metric Thread)
Metric, -40°C to +135°C (-40°F to +275°F), Brass,
M12x1.5mm MALE, 19mm HEX, 57mm overall length
$14.75
FJO
SAT0010 - Air Temperature Sensor
(Standard response)
Standard Response (encapsulated element), -40°C to +135°C (-40°F to +275°F), Polyetherimide & glass fiber, 3/8-18 NPT MALE, 3/4" HEX, 2.25" overall length
$14.75
FJO
SAT0020 - Air Temperature Sensor
(Fast response)
Fast Response (open element), -40°C to +135°C (-40°F to +275°F), Polyester & glass fiber (brass body),
$19.00
Eagle Talon 89-94 1.8L SOHC 200mmACT Clutch Kit with Heavy Duty Pressure Plate with 6-Puck Solid-Hub Race Disc $313.53
1992-1994 MITSUBISHI ECLIPSE, VSII Style Hood Picture HD9294MITEC-VSII 561.00
get back with me and tell me what you think........thankx
Bryan
* 8 trigger inputs
* Integrated GPS
FJO 341B Benefits
Kits
K3B0400
Includes:
341B Serial Cable
6 inch Crank Target
$2371.00
K3B0600
Includes:
341B Serial Cable
6 inch Crank Target
$2640.50
K3B0800
Includes:
341B Serial Cable
6 inch Crank Target
$2982.00
(100 psig)
$137.75
$70.00
(100 or 200 psig)
$137.75
(50, 35, or 15 psi)
$137.75
$70.00
$137.75
$70.00
Sensors
FJO
Pressure Sensors
$91
FJO
(Standard Thread)
$14.75
FJO
(Metric Thread)
$14.75
FJO
(Standard response)
$14.75
FJO
(Fast response)
$19.00
Bryan
