New mani, heat sheild !!
Yeah , I never really looked at the stock heat sheild that closs to notice that there was anything in it , but I beleave it is steel , because mine was starting to rust. As long as there is enough room to breath between the hot object and the sheild (not touching it all over ) it will lower the temp. surounding the hot spot.
Originally posted by stangtt
greyforestgst: that bracket is the attachment point when you remove your engine. Most of us give it the heve-ho at the first chance. LOL
Originally posted by NDgsx
Make sure you never get an exhaust manifold leak then. That piece also helps keep heat away from the timing belt cover. I once saw the top cover melt after someone took that bracket off.
To be honest, I never thought of that. Thats a good point. I guess I have been lucky on mine. Both of mine have it removed with no meltage of my timing cover. My GSX doesnt have the the heat shield on top either. LOL
