New Iac And Ecu ,still Not Turning On Help!!!
blkout1104
Nov 12, 2004
Long Island , New York
I need some serious help fellow dsm'rs. I replaced idle air control motor, and got my ecu remanufactured. my car still not starting. i even sprayed starting fluid in the intake and car still wouldnt fire. checked for sparks and its there. seems like the fuel pump works cause there was fuel on the fuel rail when i checked the fuel rail. my friend and i came to the conclusion that it was the injectors. when i first replaced the idle air control motor, the car ran fine for like 45 minutes. when i turned the car off and let it sit for an hour it didnt want to start. at that point i was told that my ecu needed to be replaced. thats when i got it remanufactured. I installed the "new" ecu and still not turning on. please help .
what do the plugs look like upon removing them after you have cranked it over....??
Are they wet??
Are they black??
try changing the plugs and see what it does then...
have you messed with the timing at all on the car have you messed with turning the engine by hand?? check your timing make sure its still on and check the belt too then then get back to us.Oh yeah one more thing check the coolant temp sensor...if thats bad the sensor will tell the ECU that the car is 176.4 degrees and then dump more fuel into the sytem which in turn will cause plug failure and then engine not to start
