New Fuel Lines Needed with Bigger Pump
98GSX-WI
131
Jun 6, 2004
Kenosha, Wisconsin
Newbie question...is it necessary to install new fuel lines if I upgrade to a Walbro
255lph Fuel Pump (High Pressure)? Also, does anyone know what the flow limitation of the stock injectors in a 98GSX are?
Thanks.
Thanks.... For flow limitations, I think I was just looking for the 450cc number. I'm not sure if there is any way to know for sure with a Big28 turbo and everything ported, with 3" exhaust what the maximum boost that I could set and have the injectors not keep up....
but I could be wrong...I'm just not sure if you can figure this kind of thing with any exactness...
Not with any exactness unless you could measure injector duty cycle (i.e. DSMlink)
I would say no more than 15 IF you have a larger fuel pump. But that might be pushing it.
You can run 17-18PSI no problem on stock injectors with a fuel pump and an adjustable fuel pressure regulator.
  • Wanted 2g 2g Hood latch support
    On the hunt for the support that holds the hood latch assembly.
    • jesse12345
  • For sale 4G63 Hallman ES Boost Controller
    Boost controller
    • jpturbotalon
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
