New engine some problems
JBDdsmer610
508
8
Mar 4, 2006
easton, Pennsylvania
ok i just put a new motor in my car ### i was down a cylinder heres what the build consits of.....Balanced rotating assembly, Crank shaft (with 70,000 miles), Weisco 8.3:1 pistons .20 over, 1g rods, ARP main studs, ARP rod bolts, ARP head studs, Mitsubishi MLHG, ACL bearings, Balance shafts removed, SS exhaust studs, Revised lifters, AND HKS 272's well i had some oil leaks there all fixed but im having problems with the car stalling out. I had it tunned when i had 90 compression but i think it might need to be retunned. I get a lean idel on my wbo2 and when im just cruising and i give it some gas it breaks up but if i really stomp on it it dosent break up. My plugs are bran new and my wires. I am tuning with a afc and 550 injectors.
