Joshky9
- 87
- 0
- Sep 18, 2005
Canal Fulton,
Ohio
Hello all please help if you can. I have been trying to get this talon back together(1990 Eagle Talon TSI AWD), new engine, with same transmission that was in before. Anyways, I have installed now an ACT 2100 with street disk and Mitsubishi OEM Throw out bearing. I greased the TOB before putting it on and put a new TOB clip on it from Mitsubishi as well as a new clutch fork and pivot ball, flywheel was resurfaced by someone recommended by Shep. When I try to let out on the clutch in First gear it starts to chatter or make a vibration noise from the front passenger side. If I give it a little more gas and slip the gas the sound disappears. When going in reverse the sound is barely audible or almost non existent. In all other gears the sound is really not audible and I do not notice any clutch slippage, also when I push the clutch in or out in neutral no noise is made only when letting out mainly in first gear. Could bad Clutch Master or Slave cylinder be the issue or is it just some clutch problem with ACT needing to be broken in or worse? I really don't want pull the tranny off again but have looked in through the clutch fork boot and don't see anything banging around in there. Any help would be greatly appreciated I have really put a lot of time and money into this car and would really like it to be drivable. Thanks for reading and hope it wasn't all to long.
