dzolcali
- 146
- 0
- Apr 8, 2005
Charlotte,
North Carolina
I just had a new clutch installed...the mechanics swear up and down they did everything right and refuse to back and check it. the minute I drove off the lot I got a misfire...now i'm getting several misfires in fifth gear cruising about 3200rpm 75-80 mph...it seems to happen if i accelerate and then take off the gas.
can anyone link this to something done during a clutch install? Car is fairly new with no prior issues what so ever.
I also get a sorta rattling noise when letting off the gas pedal at higher rpms, around 3500rpms in all gears.
someone mentioned CVjoint or something, with an awd it has to have some pressure on the engine when slowing down or something and one could be bad causing a misfire.
any help would be much appreciated
Ima try to buy some plug wires and see if that fixes it.....if not I will save up for a diagnosis...
