99gst_racer
Moderator
- 11,982
- 1,557
- Apr 5, 2003
Coloma,
Michigan
Hey guys,
I've had a chance to prototype a few new 1G products lately, and I wanted to chime in to share and also to gather some opinions. I still need to test this stuff on a few cars before it's available. But once available, I will have ads in the Freelancer section.
I'm working on a 1G rear upper control arm. These will offer a greater adjustment range and also save around 1.5 lbs weight on the car. These are similar to the Afco DIY kits that some people have been using. The differences are that my arms will have a stronger tube, a much better heim joint, and properly fitting standoffs that won't require modification. The inboard end will feature a chromoly, teflon-lined heim. The outboard end will be a very nice Moog tie rod end (booted and zirked). The tube itself is a large OD extruded aluminum tube. Very strong due to it's hex shape, and reasonably lightweight as well. Pricing will probably be around $200 shipped for the set.
I'll also be offering a 1G active toe eliminator kit. These will feature a chromoly, teflon-lined heim. I'll also be including 4 small round caps to use to weld over the factory bolt holes. I'm hoping to be around $150 shipped for the kit, so reasonably competitive.
And last but not least, I'll be jigging up a 1G rear subframe in the coming weeks. I'll be designing and building a prototype tubular rear subframe very soon. And there will be options for a 1G rearend or 3000GT rearend. I'm very much looking forward to this project. I hope some of you guys still want something like this.
Anyway, that's all I have for now. Feel free to post any suggestions or opinions you may have. I welcome any constructive criticism. And if there's another 1G rearend product you want, let me know.
Thanks!
Thanks!
