neeed help!!!!!!!!!!!
1g_dsm_toker
31
Apr 28, 2010
oshkosh, Wisconsin
i ordered and fidanza flywheel for my 92 eclipse non turbo fwd 7bolt i went to put it in today and the stock bolts for the flywheel that i have isn't all the way flush with the flywheel, sense the fidanza one is a little thinner then stock can someone please help me and give me some information on how to make it fit do i need to order new flywheel bolts or what?
The 7 bolt flywheel bolts are 1mm shorter than the 6 bolt. Make sure you have the right ones. 6 bolt are 22.5mm from just under the shoulder of the bolt to the end. 7bolt is 21.2mm. Personally, I would keep everything and buy a 7 bolt A/T spacer plate. That way it takes up the extra slack AND protects the face of the flywheel from getting chewed up.
  • Wanted 6 bolt NT water pipe
    • chrisman287
