need your input on o2 housing with external wastegate recirculated
My favorite is the free flow designed merge colector to reduce turbulance, I'm guessing thier talking about the recirc merge and um last time I check 90° flow merger creates turbulance not reduceses LOL
I use that housing. i have a whole review on it on here. ive had mine on now for a while with no issues yet. i even use godspeeds wastegate LOL. the housing has been on my daily for a few months now, it fit perfect and hasent cracked or discolored yet. all in all it was a good buy for me!
Im sure a simple piece like that would be perfectly fine. The only downside is you cant bolt up a true 3" DP to it. But 2.5" is enough for quite a bit of power.
May i ask whats the problem with internal gating?
oh ya and do your self a favor if you get it. have someone weld the down pipe bolts to it because they are a pain to try and nut and bolt it all together while your laying on the ground. and my 3 inch down pipe bolted right up to it. the flange was big enough to cover the down pipe and i had no leaks.
Good info, i thought it wouldnt bolt up. Id buy it for sure then. Its good to go. I see the OP is on a 16g though and im wondering why not just port the hell out of the stock o2 housing. You'll get every gain you would from this mod with a 25$ carbide bit and a die grinder
unless he has the same problem i did. ebay 16g turbos some times have a messed up accuator that dosent open all the way no matter what you do or how much you port you still get boost creep. if thats the case i would just get a mhi. im saving for one right now. LOL.
thanks for the info and input, I get boost creep even porting my o2 housing and hot side of the turbo, so my next thing in mind is o2 dump or external wastegate. the only thing I don't like about o2 dump is too loud on boost, so looking really to recirculated o2 housing with external wastegate. PR is way too expensive for me. i just want to get rid of my boost creep when running low boost.
