Need to source a 20G wheel
zdrux
79
Jun 7, 2003
Mississauga,
My 20G recently ate something through the compressor wheel and it has a chipped blade, and also the shaft is seized, which is another different problem. Now my question is this, do I have to go in and get a 20G wheel from Mitsu and get raped on the price or is there a Garret equivelant to that wheel? Where can I get myself a wheel so I can do a rebuild?
Also, since the center-section is seized, does the 20G share the same one as an 18G? Can I use my 18G catrdige and stick a 20G wheel on it? Are they interchangable? Thanks for your time, I appreciate any help.
Forcedperformance.com sell a 20g comp. wheel. I got mine for $99 on Ebay, price may vary.
As for the 18g, all td05/td06 share the same chra with differences in watercooled / non-watercooled. The td05/tdo6 have the same turbine shaft thickness so the 20g comp. wheel will fit on the two of them.
But if you put a 20g wheel on your 18g cartridge, you'll have to get it machined since the 20g has a bigger exducer.
Hope it helped! :thumb:
  • For sale 2g VRSF 2g FMIC.
    Bar and plate. 28x10x3.75. 2.5 inlet and outlet. 36.5 on center inlet and outlet Pretty...
  • For sale 2g Eclipse/Talon Passenger Side Fenders
    95-99 Eclipse/Talon Passenger Side Fenders
    • Sdcryan1
  • Wanted Driver Side Front Side Skirt End for 97-99
    Looking for the driver side skirt end molding. Bonus if it has the mud/rock guard.
    • ProjectDSM
  • For sale 1997 Eagle talon esi
    runs and drives located in Oklahoma City
    • Nii
  • For sale 2 bare 7 bolt motors
    bare 7 bolt bottom ends
    • Nii
