Need some help with cels
Niteninja01
167
Nov 18, 2009
Milwaukee, Wisconsin
I scaned my car today and a couple codes came up and I was woundering what they are and what I need to fix them.
Po170-fuel trim malfunction bank 1
po125 clad loop fuel ctrl
insuffecent coolant temp
the last two came up under the same code, any help would be great thanks.
Start by checking anti freeze level. It may be low. If it still throws the codes replace coolant temp. sensor. That may fix the other code. If it doesnt then you may want to buy a new front o2 sensor
Your coolant temp sensor is shot. Make sure when you order one, you tell them that you need the sensor that feeds the ECU, not the one for the gauge. There are actually two different sensors for coolant temp, so the dash gauge may be reading right, but the one for the ECU is shot. If I remember correctly, when I got mine it was $26 from the dealer.
After you replace the sensor, reset the ECU to drop the FT's back down where they should be.
Ok I'll order one next week, I thought it was going to be crazy expensive but 30 bucks isn't bad
What is the fuel trim code?
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
